Why is the speed of light constant regardless of perspective?
In summary, the conversation discusses the concept of relativity and the constant speed of light in all frames of reference. The "Kennedy" experiment is mentioned as a variation of the "Michaelson-Morley" experiment, which showed that space itself contracts. The participants also discuss the postulates of Special Relativity and recommend a book, "The Elegant Universe" by Brian Green, for further understanding.
Matt Jacques
81
I understand why it needs to be for relativity, but I don't understand why it is always c regardless if we're speeding toward it or away from it as some insane velocity, can someone tell me without a reference to relativity?
Science news on Phys.org
I think the short answer is a resounding "No."
cookiemonster
That is the whole point of relativity- it IS relativity so it can't "be explained without relativity". Essentially (yes, I'm leaving out a whole lot- don't jump all over me!), Maxwell's equations implied that it should be possible to determine an "absolute" speed (as opposed to only the "relative" speed implied by Gallilean physics) by measuring the speed of light relative to oneself in different directions. The "Michaelson-Morley" experiment was an attempt to do so and showed no change- that is, that the speed of light is constant from all frames of reference. Lorenze came up with a very cute theory that the change in electric fields of moving atoms themselves contracted physical objects in the direction of motion just enough to defeat the measurement. The "Kennedy" experiment, a variation of Michaelson-Morley, showed that the was NOT sufficient, leading to Einstein's theory that space itself contracts. That has met all of the experimental challenges so far.
I've never heard of this!
Can you recommend a book detailing the immediate prehistory of SR?
I would echo arildno's puzzlement here. While the MM experiment was published in 1886[1], the Kennedy-Thorndyke experiment (if that's what you meant by the "Kennedy" experiment) wasn't published till 1932.[2] This is waaaay after SR was published in 1905. So I'm not sure how the KT experiment could lead to Einstein's theory that space itself contracts.
Furthermore, the KT experiment itself doesn't have the ability to measure "space contraction". In fact, the length contraction in SR is merely a consequence of the postulates. It is several layers down and not very apparent if one simply look at the formulation and the postulates. One has to do some work in actually getting it.
Zz.
[1] A. A. Michelson and E. H. Morley, Am. J. Sci. v.34, p.333 (1887).
[2] R. J. Kennedy and E. M. Thorndike, Phys. Rev. v.42, p.400 (1932) .
I'm missing something here.
To my understanding, regarding the classic light clock example. When it is stationary the photons go vertically up and down. However, from our perspective when the light clocks are moving at some immense velocity, it appears the photons are moving diagonally. Since the speed of light is constant no matter who is observing it, the derivation of time dilation makes sense. But this is if we assume c to be constant from our perspective...hmmm
I thought SR proved c is constant, it seems rather it is a requisite for relativity to work.
SR did not "prove" c is a constant in all reference frame. SR made several POSTULATES, and this is one of them. We have no way of deriving these. They are only verified (there is a difference) either via direct experimental observations of the postulates themselves or via experimental observations of the various consequences of the postulates, which time-dilation is only but one of many.
Zz.
Can any of you reccomend a book that explains all the stuff that you said about light in the previous posts. It's all gone far over my head.
So it is all based experimental data? So I guess my pursuits of reasoning why light is constant in all frames is constant was a fruitless endeavor this afternoon. I am relieved, I thought I was missing something.
"The Elegant Universe" by Briane Green has a few good chapters on relativity, you should check that out.
Related to Why is the speed of light constant regardless of perspective?
1. Why is the speed of light constant regardless of perspective?
The speed of light is constant regardless of perspective because it is a fundamental physical constant in the universe. This means that its value is the same for all observers, regardless of their relative motion or position.
2. What is the significance of the speed of light being constant?
The constant speed of light plays a crucial role in Einstein's theory of relativity, which has revolutionized our understanding of space and time. It also serves as a fundamental limit for the speed at which anything in the universe can travel.
3. How do we know that the speed of light is constant?
The constancy of the speed of light has been extensively tested and verified through experiments, including the famous Michelson-Morley experiment. Additionally, it is a fundamental assumption in many scientific theories and has been confirmed through numerous observations and measurements.
4. Does the constant speed of light apply to all forms of light?
Yes, the constant speed of light applies to all forms of electromagnetic radiation, including visible light, radio waves, and X-rays. This is because they all travel at the same speed in a vacuum, regardless of their wavelength or frequency.
5. Can anything travel faster than the speed of light?
According to the theory of relativity, nothing can travel faster than the speed of light. This is because as an object approaches the speed of light, its mass increases infinitely, making it impossible to accelerate further. Therefore, the speed of light is considered to be the ultimate speed limit in the universe.
  • Optics
