Why work done by a force is a scalar product
In summary, work done by a force is taken as the dot product between the force applied and the displacement caused because it allows us to calculate the component of force parallel to the displacement, which is what we are interested in. This is because energy is a scalar quantity and work is a measure of energy. The cause of the displacement is irrelevant in the definition of work. The net work is the algebraic sum of the works done by all the forces acting on an object. This definition is useful because it can be related to the work-action theorem and energy conservation in Newtonian mechanics. This is possible when the forces can be derived as the gradient of a scalar field, making them conservative forces.
saurabhjain
Why work done by a force was taken as dot product between force applied and displacement caused?
Because 1. We're interested in the component of force that points in the same direction as the motion, and 2. It's scalar because energy is a scalar quantity (and work is a measure of energy).
What about the work involved in decelerating an object?
The force doesn't have to be the cause of the displacement. The cause is irrelevant for the definition of work.
Likes kbr2020
Yes. In fact, there could be many forces acting on the body, and the body could be moving along a very complicated path because of all the forces. Each force does work, which is calculated using the standard dot product definition of work. In this process, each force could be doing positive, zero or negative work. The algebraic sum of the works done by all the forces, which we can call the net work, can also be calculated by first finding the net force, and then calculating the work by that net force.
I'm sure you meant the component of force parallel to the displacement. The force could very well be opposite to the displacement, which was Drakkith's point here:
Again, if there is one force that is reducing the speed of an object (I don't use the word deceleration), then the direction of the force is opposite to the velocity, and the work done turns out to be negative. The definition of work is still the same, it is the dot product of force and displacement.
The reason for taking this specific functional is that it is useful. As the most simple example take a single point particle moving in some external force field. Then Newton's equation of motion reads
$$m \dot{\vec{v}}=\vec{F}.$$
Then you can multiply this with ##\vec{v}## (scalar product), and you immediately see that the left-hand side is a total time derivative:
$$m \vec{v} \cdot \dot{\vec{v}}=\frac{m}{2} \mathrm{d}_t (\vec{v}^2)=\mathrm{d}_t T=\vec{v} \cdot \vec{F}$$
with the kinetic energy
$$T=\frac{m}{2} \vec{v}^2.$$
Integrating this over a time interval you get
$$T_2-T_1=\int_{t_1}^{t_2} \mathrm{d} t \vec{v} \cdot \vec{F}.$$
This is known as the work-action theorem.
As it stands, it's not so useful, because you need to know the solution of the equation of motion to evaluate the integral. But very often forces in Newtonian mechanics are derivable as the gradient of a scalar field, i.e., a potential:
$$\vec{F}(\vec{x})=-\vec{\nabla} V(\vec{x}).$$
Then the integrand becomes also a total time derivative:
$$\vec{v} \cdot \vec{F}=\dot{\vec{x}} \cdot \vec{F}=-\dot{\vec{x}} \cdot \vec{\nabla} V=-\mathrm{d}_t V.$$
Then the right-hand side of the work-action theorem becomes
$$T_2-T_1=-(V_2-V_1).$$
You don't need to know the trajectory of the particle anymore but only the positions and velocities of the particle at the initial and final time ##t_1## and ##t_2## of the motion. Writing the total energy as
$$E=T+V,$$
the above equation is nothing else than the energy-conservation law
$$E_2=E_1.$$
That's why forces which are the gradient of a time-independent scalar field are called "conservative", because they lead to energy conservation.
Related to Why work done by a force is a scalar product
1. Why is work done by a force a scalar product?
Work done by a force is a scalar product because it is the product of two scalar quantities - the magnitude of the force and the displacement in the direction of the force. This results in a scalar value, which represents the amount of energy transferred by the force.
2. What is the difference between scalar and vector quantities?
Scalar quantities have only magnitude, while vector quantities have both magnitude and direction. Work done by a force is a scalar quantity because it only considers the magnitude of the force and the displacement, while ignoring the direction of the force.
3. How is work done related to energy?
Work done is directly related to energy, as it is the amount of energy transferred by a force. When a force does work on an object, it transfers energy to the object, causing its energy to increase. In other words, work done is a measure of the change in energy of an object.
4. How is the scalar product calculated for work done?
The scalar product for work done is calculated by multiplying the magnitude of the force applied to an object with the displacement of the object in the direction of the force. This results in a scalar value, which represents the amount of work done on the object by the force.
5. What is the unit of measurement for work done?
The unit of measurement for work done is joules (J), which is the same as the unit for energy. This unit is derived from the base units of mass, length, and time - kilograms, meters, and seconds - and is used to measure the amount of energy transferred by a force to an object.
  • Calculus
  • Mechanics
  • Mechanics
  • Mechanics
