Why is the speed of light exactly exactly 299 792 458 meters per second ?
In summary: What's the name of this "ampere" constant ?In summary, the speed of light is exactly 299 792 458 meters per second due to its definition as the distance light travels in 1/299792458 second. This definition was chosen based on the theory of relativity and experimental measurements. The value of the speed of light is also related to the definition of the meter, which was chosen based on the distance between two scratches on a specific beam in a controlled environment. The speed of light is also affected by the constants of permittivity and permeability, which are defined exactly and are a result of the chosen units of measurement. The constant of the ampere is also related to the permeability of free space
  • #36
You can go about this in so many ways, its easy to get confused. Keep in mind science involves a lot of intrinsically circular reasoning, the big difference from usual propositional logic is that at the end of the day we have experiment to ensure the consistency of the model.
Its really no different than picking an axiomatic system, and then choosing extra axioms that are really related by theorems to former ones, eg they are not necessarily independant.
In the original work of Einstein, the constancy of the speed of light/information is an axiom. You are of course free to not do this and pick another axiom as fundamental, and for instance classical field theory (Landau/Lifschitz) more or less does this and instead rederives the former as a theorem.
  • #37
DaleSpam said:
The value of the permeability of free space is a result of the http://www.bipm.org/en/si/si_brochure/chapter2/2-1/ampere.html" . And then (together with the definition of the meter which defines the speed of light) the permittivity of free space is also defined exactly.
Dale. I took a look at your web link and found this:
"The ampere is that constant current which, if maintained in two straight parallel conductors of infinite length, of negligible circular cross-section, and placed 1 metre apart in vacuum, would produce between these conductors a force equal to 2 x 10–7 Newton per metre of length."
Did I understand you correctly that the velocity of light is defined in terms of the permeability and permittivity of the vaccum? If these a dependent upon the ampere we seem to have circular standards.
But you bring up a nice topic: The pedigree of standard units--dependencies, basically. I have never seen it sorted out. For instance, does permittivity depend on constructing two plates of known dimensions, etc?
  • #38
The velocity of light and permeability of space are numerically-defined constants. The vacuum permittivity is defined to be [tex]1/(\mu_0c^2)[/tex].
  • #39
The purpose of physics is to both explain how things work (say via math) and also why they work. We are not so good at the latter as the former, I think.
This is a lay mischaracterization of science.
Maybe in the opinion of some, yet I just finished reading a Nobel Prize acceptance speech a few days ago...that was part of the physicsts comments addressing the audience...
  • #40
Lightarrow posted:
one supposes that the influence that one particle, say, exerts on another can not be transmitted instantaneously. Hence, there exists a theoretical maximal speed of information transmission,which must be invariant and it turns out that this speed coincides with the speed of light in vacuum.
I have that book (Theoretical Physics 2: "Field Theory") but I sincerely have never been able to understand that phrase.
Before Maxwell's equations and Einsteins relativity such a "supposition" would have been deemed rather radical I think.
Thanks for the background but, darn, I was really hoping there was a rational reason... interesting question...
  • #41
neopolitan said:
Hi Naty1,
I'm going to conveniently ignore the context of your question (ie in terms of the text you quoted) and provide my explanation of why the speed of information transmission must be invariant.
I put it down to the structure of spacetime. If there is a quantum unit of time and a quantum distance, then there is going to be a maximum distance something can travel in a minimum amount of time. Such granularity of spacetime will result in a universal speed limit.
Proving that might not be easy. I think of it this way: any particle can conceptually have a minimum distance traveled (in a given frame), that would be not moving at all - being at rest, v=0. (Note that such a frame may not be strictly valid.)
Otherwise, a particle could move one quantum distance in one quantum unit of time. I would argue that in one quantum unit of time, a particle could not move more than that because it would imply two "location changes" in one quantum unit of time, and further imply that the quantum unit of time is divisible.
That would mean that the maximum speed for a particle is one quantum distance over one quantum unit of time, and that just happens to be the speed of light, and the speed of information transmission.
A final option is for a theoretical particle to move, but at rate less than one quantum distance per quantum unit of time. Here is where the movement would be statistical, you'd never know precisely which quantum cube a subluminal particle is in. However, when the positions are averaged out and the time elapsed measured you would end up with x quantum distances traveled in t quantum units of time (where x < t).
Since this sort of subluminal motion pertains to masses, you would really average out the positions of a large number of particles to find that the mass as a whole moves at less than one quantum distance per quantum unit of time. I suspect that at the quantum level the basic constituents of the mass would move at lightspeed, but not consistently in one direction as photons tend to.
cheers,
neopolitan
woops,
I obviously have too much hassle going on the background.
This was not so much about why the speed of information is invariant and more about why there is an upper limit to the transmission of information.
There is a further step you have to take to explain why information travels at that upper limit.
If you look at galilean relativity, if you want to call it that, you can see that there is also an assumption of invariant speed of information transmission. It just that in the galilean boosts information is assumed to be transmitted instantaneously. If you remove that assumption, you can arrive at the Lorentz transformations.
You have to keep the assumption of invariant speed of information transmission and I suppose you might want to explain it. I do think that people probably thought about it another way. Information travels really fast, not instanteously, even though it might seem like it. So, they would then be looking for what holds the transmission of information back. Well, we found something in the upper speed limit inherent in the universe.
The only reason then that information would _not_ be invariant would be if there were to be some reason why information doesn't travel at the upper speed limit. I don't have such a reason, they didn't and I don't think anyone else has either (if I recall correctly even the "in a vacuum" is a bit of a misnomer, because photons do travel at c whenever they travel, but they get slowed down when not in a vacuum because they tend to get absorbed and reemitted.)
cheers,
neopolitan
  • #42
Wow, this debate was very good and interesting! :-)
Now a little on the side of what this debate is about:
For 2.5 months ago I sent an article to the AstroPhysical Journal. The article is a summary of my research last 10 years. The respons so far from the editorial board is that it is in progress. But is it usual that the treatment at the APJ takes so long? If they conclude that my findings are completely wrong, they should be able to reject it immediately! Here is something going on, I believe :-))))))))
  • #43
neopolitan said:
Hi Naty1,
cheers,
neopolitan
Just to say, Thank you. As an educated layperson, I really liked the explanation.
I like the 'if / then / otherwise, approach at the options when the base unit is Plancks quantum. It seems a very Integer based scaling system.
- as an aside and a follow up question;
I remember an article in Sci Am a few years ago about the Planck scale and how there was a gap in the scale from quark to atom ( ?? hazy memory - If anyone knows the issue, a link or pointer is most welcome, and would save me a search ) something like that.
The question is.
Is this gap in the spectrum, a lack in theory or a gap in measurement technology?
Just curious.
  • #44
I don't know APJ's usual timeline, but 2.5 months is not unusual for most of the journals where I have had manuscripts published. Even much longer is not unusual if the first two reviewers disagree and it has to be sent to a third reviewer. I wouldn't make any assumptions at this point.
By the way, the likely best response is that it needs significant revisions before it is accepted. Don't argue the point, just make the requested revisions. That is a normal part of the peer-review process.
  • #45
Dalespam posted:
As you mention, a complete Theory Of Everything would eliminate the current 26 fundamental dimensionless constants. That does not apply to dimensionful physical constants like c, which would still be defined by arbitrary man-made conventions even within a complete Theory of Everything.
And since I believe Cephid and Me Jennifer agrees, looks like Strangerone and I have some "adjustments" to make in our thinking...at least I do...
Now I understand the distinction that was being made, but not quite it's significance...
Wikipedia does cover this..for starters, Dimensionless Quantity...
http://en.wikipedia.org/wiki/Dimensionless_quantity
http://en.wikipedia.org/wiki/Dimensionless_physical_constant
but "bells" of insight did not sound as I skimmed ...
be back after some reading...have to take my new dog to the vet for a checkup first.
Thanks, guys,girls!
  • #46
Okay, thank you for a good and detailed response.
I apologize if my English is not so good. (I'm not from an English-speaking country)
Have a nice evening :-)
  • #47
Well, yes, of course. The precise value of any constant depends upon the units in which you are measuring. The "physical" information, from experiment rather than simply "made up" is that the speed of light is independent of the speed of the one observing the light, not the specific value in a given system of units.
  • #48
It is not circular, but I think the "pedigree" is an appropriate description. The http://www.bipm.org/en/si/si_brochure/chapter2/2-1/" explicitly.
Finally, it should be recognized that although the seven base quantities – length, mass, time, electric current, thermodynamic temperature, amount of substance, and luminous intensity – are by convention regarded as independent, their respective base units – the metre, kilogram, second, ampere, kelvin, mole, and candela – are in a number of instances interdependent. Thus the definition of the metre incorporates the second; the definition of the ampere incorporates the metre, kilogram, and second; the definition of the mole incorporates the kilogram; and the definition of the candela incorporates the metre, kilogram, and second.
So there are really 3 "great-grandparent units": the second, the kilogram, and the kelvin. These units are completely independent of the others. Then there are the "grandparent units": the meter (child of the second), and the mole (child of the kilogram). Finally there are the "parent units": the ampere and the candela (children of the meter, kilogram, and second). Then all of the remaining SI units, like the watt or the Newton are children of these "fundamental" units.
  • #49
Congratulations on your new dog!
Please read up a bit until you get some concrete questions and then don't hesitate to ask. I think this topic is reasonably important to understand, so I am glad to follow-up as best as I can since I am sure that this initial exposure is not self-explanatory.
  • #51
Fluidistic: Thanks for the thread referenced in post #50 here...I found something, which if accurate, was a big help.
there, HallsofIvy posted:
(And lightarrow seems to have said the same thing here in post # 25)
To clarify- it is NOT the "speed of light" that has been "defined"- as you say that is a constant of nature and we cannot just "define" it to be a specific value.
(my boldface)
This is all I was trying to say here in earlier posts. It seems self explanatory enough for me as long as the current posters in this thread agree its correct. Whether it's quoted in km/sec or mph or any other units makes little difference to me as long as both the magnitude and units are given.
Light is not instantaneous for a reason; it is constant for a reason, and it propogates at a given value for a reason (pick any unit in which you want to measure)...
For my own interest I'm going to read further about dimensionless and dimensionful constants but right now the distinction sounds like one some math wizards concocked during a binge! but maybe there are subtlies I'm missing...wouldn't be the first time!
As a matter of interest, if a theoretical foundation were found for all the "fundamental constants" in the standard model (currently independent inputs) and also for gravity (if there are any) and some/any were found to be different, (say, for example, in the twentieth decimal place beyond current measured accuracy) I'd be interested if any would then cause the speed of light to be ever so slightly refined.
  • #52
Hello all
This extract is taken from Rindler – Relativity, Special,General and Cosmological. Second Edition. Page 41. I do not know if this is still the current situation but it is interesting nontheless.
-----First of all, we need universal units of time and of length. In this age of atoms it makes good sense to fall back on atomic frequencies and wavelengths to provide these units. Thus in 1967 the (international) General Conference of Weights and Measures (CGPM-1967) defined the second as follows: ‘The second is the duration of 9192631770 periods of the radiation corresponding to the transition between the two hyperfine levels of the ground state of the cesium-133 atom’. The international standard of length had been defined back in 1960 in terms of the wavelength of a certain line in the spectrum of krypton-86. More recently, however, it has become clear that the precision available from the kryrton-86 line is surpassed by the precision with which, on the one hand, the second, and, on the other hand, the speed of light are determinable. Thus, demonstrating its complete confidence in special relativity, CGPM-1983 re-defined the meter as the distance traveled by light in vacuum in a time interval of 1/299792458 of a second. Note that, consequently, the speed of light is and remains precisely 299792458 meters per second ; improvements in experimental accuracy will modify the meter relative to atomic wavelengths, but not the value of the speed of light!-----
This is, i hope, relevant to Naty 1's last line of the last post #51
Matheinste
  • #53
Cepheid posted
Huh? Okay, first of all your analogy is flawed, because scientists don't accept that it is not possible to cure the common cold in principle, they only accept that it is not possible to cure it in practice, given our current level of scientific understanding.
My analogy is 'flawless'...you need to reread it...we, in fact, agree completely (i concur with your statement and was using analogous faulty logic to illustrate the faulty logic of the original post.)
  • #54
In post # 19 Strangerone repeated his original question:
What is the exact physical reality behind these observed constants. There is, as far as I know, no published theory that can tell this. There is only math related to these observed constants. But why does scientists accept this?
I agree,,,no theory I have seen either...it's not really "accepted", just the best we can do so far.
Having reread all the posts here I am led to the conclusion we did not provide a direct answer to Strangerone's question very well, or maybe it would be better to say we sure took a round about way. What someone asks "Why does a baseball fly off a typical major league hitter's bat at about 98 mph?" getting into a discussion of dimensions is not the way to go to aid the questioner.
At least I found the Wikipedia result I quoted was misleading at best.
HallsofIvy, Dalespam, and Lightarrow I think helped clarify what was for me the subsequent confusing dialogue among posters about units/dimensionlesss/dimensionful but the language can sure be confusing.
I think Lightarrow posted:
and that's enough clarification for me.
Seems maybe had the original question been something like "Is there a theoretical reason the experimentally measured value for the speed of light is 300K m/sec instead of, say, 400K m/sec"...we might have been more succinct in replies.
  • #55
Hi Naty1,
Sorry about the delay. I wanted to explain in more detail why the dimensionless quantities are considered more fundamental than the dimensionful quantities. I thought it might help to see an example of what it would mean to change a dimensionful quantity without changing any of the dimensionless quantities, and it took a while to work it out. Specifically, I wanted to work out what would be the experimental result if the speed of light doubled but the fine structure constant was unchanged.
The fine structure constant [tex]\alpha =\frac{e^2}{2 h c \epsilon _0}[/tex] has several terms, but if we suppose additionally that mass and charge do not change then we see that if c is doubled then the vacuum permittivity must be halved. And since [tex]c^2=\frac{1}{\epsilon _0 \mu _0}[/tex] the vacuum permeability must also be halved. So, basically we have just c doubling and the permittivity and permeability halving and no other changes.
Now, let's determine what we measure. The http://en.wikipedia.org/wiki/Hyperfine" energy is proportional to c² which is quadrupled. So, if E for the Caesium hyperfine transition goes up by a factor of 4 then by E=hf the frequency also goes up by a factor of 4 meaning that our new seconds are a quarter of our old seconds.
Now, our new meters are equal to the distance that light travels in 1/4 of an old second and since c is doubled that distance is 1/2 of an old meter. Note that this definition of the meter leaves the numerical value of c in new meters per new seconds unchanged. This is not terribly surprising because it is a direct result of the definition of the meter, but let's use our new meters to measure the length of a bar that was 1 old meter long prior to the change in c.
Due to the doubling of c, the Bohr radius [tex]a_0=\frac{h}{2 \pi m_e c \alpha }[/tex] is halved. This means that our 1 old meter bar has shrunk to 1/2 of an old meter. As we discovered above this is also the length of our new meter. In other words, a bar that was previously measured to be 1 old meter is now measured to be 1 new meter, despite the fact that c doubled and our new meter is defined based on this doubled c.
So, although our new seconds reduced by a factor of 4 and our new meters reduced by a factor of 2 when c doubled, we cannot tell any difference. Things that used to be 1 old meter long are still measured to be 1 new meter long even though all of our measurements are now distorted as are the objects themselves. This is why dimensionful parameters are not considered fundamental. A change in c (without a change in the fine structure constant) wouldn't change any physical measurement we could make. Only changes in the dimensionless parameters have physical significance.
Likes Drarp
  • #56
First I would like to say well done to Dale, that was a brilliant, cogent approach to a deceptively simple topic.
Then my two cents.
I think the simplest way to explain that light has a specific speed, and not another (I gather that this was the OP's thrust, rather than why the defined speed is a round number), is to point out that the speed of light is a really the ratio between one fundamental division of space and one fundamental division of time. We could say it is 1:1 or one Planck length per Planck time, or one light year per year, or 299792458 m/s depending on the units we find most convenient to work with.
So, the figure we come up with is really more reflective of the number of fundamental units of space that fit in the unit of space we find convenient and the number of fundamental units of time that fit in the unit of time we find convenient.
(Strictly speaking, it is the ratio of those numbers, since while Planck units are certainly convenient, I cannot say categorically that they are truly fundamental.)
cheers,
neopolitan
  • #57
Going back to Dale's post: since if we were to somehow change the relative speed of light, by for example, traveling towards a photon, then in the axis of that motion the decreased speed of light would result in the changes you listed such that we would measure the speed of the photon as being c, yes? At the very least, there would be no way to tell if the relative speed of light has been reduced by our motion towards the photon, which admittedly makes it impossible to say that we are moving towards the photon without bringing in another observer who is notionally at rest. But let's say we do that.
What I find interesting is that, because there could be a photon coming at us from behind (according to the introduced observer), the changes you listed would be directional, ie velocity based rather than speed based. Again it would have to be from the perspective of the notionally at rest observer.
I note that this is not what is referred to as "frame drag" but it is a description which came to mind when I thought of it. Basically the observer watching us heading towards one photon and away from another could calculate that vacuum permittivity and permeability are decreased in the direction of our motion (analogous to a fluid's resistance against motion through it?) and increased behind us (analogous to reduced pressure in a fluid behind a vehicle?).
Further, if we were to face "forwards", our time divisions are shorter Tfw=(t.c2/(c+v)2) and our spatial divisions are shorter Xfw=(x.c/(c+v)) - assume we chose dimensions so that x/t=c. This means that in our inertial dimensions the closing velocity according to the observer (c+v) will be X/T according to us. In other words, we won't be able to measure any speed for the photon other than c. If we face "backwards", our time divisions are longer Tbw=(t.c2/(c-v)2) and our spatial divisions are longer Xbw=(x.c/(c-v)) but the closing velocity according to the observer (c-v) will still be X/T according to us.
The overall effect, according to our observer would then seem to be a form of root mean square:
x' = ct' = sqrt (Xfw . Xbw) = sqrt ((x.c/(c+v).(x.c/(c-v))
= sqrt (x2.c2/(c2-v2)
= x.sqrt (1/(1-v2/c2)
The figures seem to work out ok.
Is there any validity to them? Perhaps it is all too ethereal?
cheers and Merry Christmas,
neopolitan
  • #58
Thanks neopolitan!
neopolitan said:
What I find interesting is that, because there could be a photon coming at us from behind (according to the introduced observer), the changes you listed would be directional, ie velocity based rather than speed based. Again it would have to be from the perspective of the notionally at rest observer. ...
That is interesting, I hadn't considered that since it took me a couple of days just to work out the part that I did, but you could be right. The thing that would worry me is that the factors are different than the regular relativistic gamma factor, and they are different for time and space. But you are right, it is very much like the Lorentz aether theory in the sense that clocks and rulers change to make a change in c undetectable.
Merry Christmas to you too!
  • #59
Just a quick response, note that I used x where x=ct and x'=ct' and the unprimed frame is the notionally at rest frame. I didn't make that clear enough.
If I was deriving the length contraction equation, I would have had to use different notation, probably L and L', and would be using a different frame as my starting point.
The equation I provided could be used for deriving time dilation.
cheers,
neopolitan
  • #60
How about terafurlongs per fortnight? That makes c=1.8, nice easy number to work with.
  • #61
Hello all.
Pre SR light could have any value (assuming non quantization) depending on the velocity of the observer.
Let us for now agree that in SR light speed has one value for all in all directions. It is what it is. The numerical value is dependent on the units and definitions, which are man made. It is what it is because it cannot be anything else, nature made it that way. It is exactly 299,792,458 M/S, with no decimal parts because that is how it is currently (i believe) defined.
Matheinste.
  • #62
matheinste posted:
More recently, however, it has become clear that the precision available from the kryrton-86 line is surpassed by the precision with which, on the one hand, the second, and, on the other hand, the speed of light are determinable. ... Note that, consequently, the speed of light is and remains precisely 299792458 meters per second ; improvements in experimental accuracy will modify the meter relative to atomic wavelengths, but not the value of the speed of light!-----
I don't think so ,but you may be right...it appears to me the "fixed" value of light is merely the standard so other stuff would be expected to vary due to those being less precise...but it seems that could conceptually change if some newer, more accurate measure for light, say to five more decimal places, were discovered.
  • #63
Helo Naty1
The quoted passage (not my words but those of Rindler, a respected author) says that the speed of light is fixed by defintion.
Matheinste
  • #64
Math...
I understand(??) and agree with your quote but I don't necessarily reach quite the same interpretation...here is another slightly different view...
There is, as yet, no intuitive explanation to why the universe should act like this. Since Maxwell's work, numerous experiments have been performed to test the prediction that electromagnetic radiation travels at the same speed for all observers - and none have failed. Instead of being a prediction from theory, it now became to be used as an assumption to build theories upon. Einstein was so convinced of its truth that he modified Newton's theory of gravity to encompass the constancy of light. Likewise, in the 1940s, Feynman, Tomomaga, Bethe and others incorporated the idea into Quantum Mechanics. The resulting theories, General Relativity and QED, are probably the most accurately tested to date - and they require that the speed of light is constant.
(I misplaced the source, sorry)
So I still have the intuitive feeling science has missed something...and that further fundamental study might yet uncover remarkable aspects of this universe and light speed in particular. As I understand Maxwell's work, his findings were originally understood within the context of "aether"...nobody realized that the speed of light was fixed as we understand that today...so despite his brilliance in formulation, he did not understand the implication, the physical interpretation, of what he had done...That took Einstein...and this is not so uncommon in mathematical physics...maybe analogous to Feynman's "sum over paths" which, if I recall correctly, he saw as a sort of "hokus pokus" which remarkably enough worked quite well! (When Wheeler explained the approach to Einstein in Princeton, Einstein thought it "crazy")
I can't help wondering why lightspeed and electric charge are fixed (constant) yet mass, time and distance vary by reference frame...truly astonishing...who would have believed this say 100 years ago??
  • #65
Hello Naty1.
Your quote refers to the constancy of the speed of light for all observers and does not refer to it's defined numerical value in the quote from Rindler in #52. What this quote says quite specifically (as far as i interpret it) is that the meter is defined as the distance traveled by light in vacuum in a time interval of 1/299792458 of a second and so a change in the accuracy of the measurement of light speed would not change its numerical value.
I am of course willing to admit the possibility that my interpretation of Rindler's words may be wrong, i am just explaining again, for clarity, what my interpretation is.
Of course if the definition quoted by Rindler no longer stands then all i have said is irrelevant. Perhaps there is a newer definition of light speed? Perhaps someone could clarify this.
Matheinste.
  • #66
Hello again
I have just looked up the current definition of light speed. According to Wiki the meter is defined such that the speed of light in vacuum is exactly 299,792,458 meters per second. Their quoted source is the International Bureau of Weights and Measures 2006.
Matheinste.
  • #67
I think you would do well to look at https://www.physicsforums.com/showpost.php?p=2011753&postcount=55". Dale may not have arrived at it first, but he does show that constancy of c is the result of the ratios between dimensionless quantities. You may not like that, I suppose, if you take it that dimensionless quantities are the result of theories which have "c is a constant" as an axiom.
However, if you look further back, someone stated that it is possible to take other axioms and arrive at the conclusion that c is a constant (even I had a hack at explaining it).
If you accept that neither space or time is infinitely divisible, then you arrive at the conclusion that there must be a maximum speed limit (see https://www.physicsforums.com/showpost.php?p=2005236&postcount=35"for the logic). Such a maximum speed limit would turn up all over the place in physics, even in contexts where you aren't really talking about anything moving (E=mc2, as a simplified example). Think about the characteristics of that which could travel at the maximum speed. It could not be a mass, which consists of many particles interacting. It would be moving from fundamental division of space to another in one fundamental division of time, therefore it would have to "fit" into one fundamental division of space, so (at least roughly speaking) you are talking about a fundamental particle. Then, ask yourself, how fast do these things move?
cheers,
neopolitan
  • #68
Just to follow-up on this. Originally I took the fine constant and used it, together with the standard definition of the second and the meter, and the Bohr radius to determine that the "optical" meter and the "bar" meter were still the same after doubling c and halving the vacuum permittivity.
I expanded on this idea and included also the gravitational coupling constant and a "pendulum" second so that I could have something to compare to the "atomic" second. I then allowed c, h, G, and the vacuum permittivity to be multiplied by the factors {1/2, 1, 2} (81 possible permutations) and calculated the resulting impact on the fine constant, the gravitational constant, and observables like the ratio of a "pendulum" second to an "atomic" second and the ratio of an "optical" meter to a "bar" meter.
I found that, for all combinations, the observables (pendulum/atomic and optical/bar) were a function only of the dimensionless parameters. It is not a general proof, but after this exercise I feel pretty confident that the dimensionless parameters are the only ones with any physical meaning beyond our choice of units.
  • #69
Have we reached a consensus on this thread?
If it is helpful I summarize my view saying it is rather a false question within present physical understanding but becomes a scientific one when turned upside down.
E.g. the question why is the speed of light that? becomes, when the Kr-86 line was the length standard, why is this Kr-86 line that long, a scientific question that can be answered by a theory that has c as one of its inputs.
Likewise the question on another thread 'why is light so fast?' can be transformed into questions like why are we so slow, or better why can we usually achieve relative velocities so small compared with c, why are we and atoms the size they are? which are scientific questions that can find an answer.
Analogously why is the Boltzmann constant Boltzmann constant exactly 1.3806503 × 10-23 m2 kg s-2 K-1 . or why is the degree centigrade exactly what it is in terms of the Boltzmann constant is a sort of non-question unless inverted in which case it is a question answerable in terms of molecular forces and statistical mechanics of water.
Or why does the sun come overhead at Greenwich exactly at midday is a non-question about the sun, but in different form answerable as a scientific question if we call history a science.
  • #70
epenguin said:
Analogously why is the Boltzmann constant exactly 1.3806503 × 10-23 m2 kg s-2 K-1.
The Boltzmann constant does not have a defined value. It has a relative uncertainty of about 1.7×10-6, see http://physics.nist.gov/cgi-bin/cuu/Value?k. The Boltzmann constant is defined as k=R/NA, where R is the gas constant and NA. The uncertainty in k results primarily from the uncertainty in R.
The degree Kelvin is exactly 1/273.16 of the triple point of water, see http://www.bipm.org/en/CGPM/db/13/4/. In particular, it is not defined in terms of the Boltzmann constant.
This is a very real question about the Earth's rotation rate and the nature of time.
The Sun does not "come overhead at Greenwich exactly at midday." The second is no longer defined by the rotation of the Earth. There are three reasons why the Sun does not "come overhead at Greenwich exactly at midday." First, there is a difference between apparent http://en.wikipedia.org/wiki/Solar_time" .
I gave wikipedia references because wikipedia a pretty good job of describing these concepts in lay terminology. For the official descriptions, see http://www.iers.org or http://tycho.usno.navy.mil .
9K
