- #1
Kricket
- 14
- 0
Probably an easy one...
So, I understand the idea of precession on a gyroscope: we've got the angular velocity vector, the angular momentum vector (same direction but times the inertia tensor), then a torque is applied => change in L in the direction of torque.
I'm thinking of the example where you have the spinning bicycle wheel, with one end of the axle attached to a rope hanging from the ceiling (the axle is horizontal, the wheel vertical). The wheel, instead of falling down, stays upright and rotates around the rope. Let's say the L vector points away from the rope, and the torque vector (caused by the rope's offset from the wheel's center-of-gravity) points perpendicular to the rope and the L vector.
So, as time passes, L moves along in the direction of torque. What I don't understand is, why does the center-of-gravity of the wheel move? It seems to me that since L is basically the axis of rotation, changing L should result in the axis becoming offset from the axle, with the effect that the wheel should start to have an increasingly wobbly spin - but this shouldn't necessarily cause the "body" (the wheel/axis) to move linearly.
I'm guessing this has something to do with the end of the rope being somewhat fixed, but can somebody give me a more robust explanation?
Thanks
Thanks
