What's wrong with this local realistic counter-example to Bell's theorem?
In summary, the local realistic counter-example to Bell's theorem is flawed because it assumes that hidden variables can explain the correlations between entangled particles. However, experimental evidence has shown that these correlations cannot be explained by local hidden variables and instead support the principles of quantum mechanics, which Bell's theorem seeks to disprove. Additionally, the counter-example relies on the assumption of "free will," which is not a scientifically proven concept and introduces more complexity to the already complex issue of entanglement and quantum mechanics. Therefore, the local realistic counter-example fails to disprove Bell's theorem and further supports the validity of quantum mechanics.
  • #36
JenniT said:
Is there a simple way to format tables on PF, please ... ??
while I'm still in the editing phase .. ??
Best way would probably be to do it with LaTeX, go to yuiop's [post=2945088]post #5 on this thread[/post] and click the table he posted to see its LaTeX code, hopefully you can figure out how they work from that.
  • #37
JenniT said:
With apologies for the formatting; this DRAFT being hurried on-line to address serious concerns above.
Since this draft appears to address none of the concerns I raised in posts #29 and #30, I would appreciate it if you would respond to those posts individually when you have the time (along with the question involving the diagram in post #35)
  • #38
JenniT said:
ROc: Angles ac, bc. Bi-angle: ab = ca + cb, or ab = ca – cb; 2Pab = the average over the bi-angle.
(C1) +++ ––– P1 = Cca.Ccb/2. Pac++ = P2 + P4 = Sac/2. (Z1) Pab++ = P3 + P4 = (Cac.Sbc + Sac.Cbc)/2.
(C2) ++– ––+ P2 = Sca.Scb/2. Pac+– = P6 + P8 = Cac/2. (Z2) Pab+– = P1 + P2 = (Cac.Cbc + Sac.Sbc)/2.
(C3) +–+ –+– P3 = Cca.Scb/2. Pac–+ = P1 + P3 = Cac/2. (Z3) Pab–+ = P7 + P8 = (Sac.Sbc + Cac.Cbc)/2.
(C4) +–– –++ P4 = Sca.Ccb/2. Pac–– = P5 + P7 = Sac/2. (Z4) Pab–– = P5 + P6 = (Sac.Cbc + Cac.Sbc)/2.
(C5) –++ +–– P5 = Sca.Ccb/2. Pbc++ = P2 + P6 = Sbc/2.
(C6) –+– +–+ P6 = Cca.Scb/2. Pbc+– = P4 + P8 = Cbc/2.
(C7) ––+ ++– P7 = Sca.Scb/2. Pbc–+ = P1 + P5 = Cbc/2.
(C8) ––– +++ P8 = Cca.Ccb/2. Pbc–– = P3 + P7 = Sbc/2.
PS: I will be away from the web for a week or more, starting tomorrow.
Happy studying,
JenniT
I highlighted what we need: Pac++, Pab++ and Pcb++=Pbc--
Pac++ is what is measured on monday, and equals 0.073... in agreement with your numbers
Pab++ is what is measured on tuesday, and equals 0.25. Your number gives 0.125
Pcb++=Pbc-- is what is measured on thursday, and equals 0.073 in agreement with your numbers.
You will NEVER be able to get Pab++ equal to 0.25 (you actually have 0.125), simply because it can't be larger than (Pac++) + (Pbc--) which equals 0.146...
Note that indeed, your number (0.125) is, as it can't be otherwise, smaller than 0.146.
Simply because this 0.146 is made up of your 4 positive numbers P2 + P3 + P4 + P7 as you give it yourself, and Pab++ is equal to only P3+P4 (your 0.125). You ADD to your 0.125 still your P2 and P7 to obtain 0.146, so it has to be smaller (as indeed it is).
Now, QM predicts not 0.125, but rather 0.25. It is bigger. So it can't come from numbers P1...P8 in this way.
There's nothing more to say about this.
  • #39
Dear vanesch, thank you,
And apologies for where my exposition has been unclear; especially re bi-angles. [I personally think of them as BI-angles, where BI = Bell Inequalities.]
However, as I wrote: They are important, IMHO, to any local-realistic analysis of BT.
To recap: I brought my model here, responding to a post of yours, to see if it was in error. Very much appreciating the correspondence here, I believe that the model is not in error.
To support this view, I am attaching a one-page PDF. I am of the view that the model is both valid and important. I am of the view that it addresses the challenge provided by your post.
PS: If you and Jesse would be OK with this: I would like to open another thread, asking the question: Bell's theorem refuted?
I believe that such should be in order. As you will see from the PDF, there is published, peer-reviewed material on the subject. (One reviewer quite famous.)
The OP would have this PDF attached, possibly with amendments that you and Jesse might suggest.
With thanks again to you both,
please excuse me if spasmodic replies soon follow for a while -- I will soon be away from ready access to the net -- for a week or more,
JenniT
  • Bell theorem refuted-draft1.PDF
  • #40
I would not be OK with this, I think you are using this forum as a platform for advertising a crackpot theory that you are already totally confident is right, rather than just exploring the issue in an open-minded way that acknowledges the strong likelihood that it is you who have made an error somewhere in your analysis, and making a sincere effort to listen to critiques in order to identify likely errors. You have not given any coherent explanation of what you intend the probabilities P1-P8 to actually represent, despite my asking this question repeatedly; it is clear they do not have the standard meaning that they do on the Sakurai's Bell inequality page if you both reject the idea of predetermined values for each of the three angles, and also reject the idea that P(a+, b+) = P3 + P4 and P(a+, c+) = P2 + P4 and P(c+, b+) = P3 + P7. So I would recommend not starting any new threads until you have provided clear answers to these questions, along with the others I brought up in posts #29, 30, and 35.
  • #41
Dear Jesse,
AS ALWAYS, your contributions are, for me, fantastic. And, here, above, I so very much appreciate that offer of time. Whew! I've been in a time-bind for some time -- soon to get worse -- so time is what I need.
Time-poorness is also a small part of some missed answers to you; for which I apologize.
(BUT I also found your questions quite complex -- with so many on a page! If you break questions into a one-at-a-time sort of thing, that will be much easier for me; and easier for you to point to answers I might accidently miss providing. I AM committed to answer any and every question on the model and its development; perhaps too often hoping that answers given on one matter may help the questioner see the answer on another matter.)
However, responding to vanesch above, you will see that I have attached a one-page PDF file. I am hoping it will go a long way to providing all the answers that you seek. I am also hoping it will help us develop a common 'lingo' -- me being fairly jargon-based and not over-familiar with QM.
Have a look at it, please. Then point me to questions that you would like answered; in the model's context, please, if possible.
Thank you, again ... and did you ever reply to my question re acknowledgment? (Do so privately, if you wish.)
JenniT
  • #42
OK; thank you; your post came in as I was posting my last.
Q: Do you not see that all the sums that you could possibly require are included in -- or easily derived from -- the base-data in the PDF.
Q: I left many more sums for the reader to complete. Do you want to see any of them?
NB: I ABSOLUTELY REJECT:
IF IT IMPLIES: P3 + P4 = P3 + P4 + (POSITIVE NUMBER)!
(XXX)
Q: Seriously: In case I misinterpret: Is equation (XXX) what you want me to accept?
Please: Is this not the very SUM that I specifically included as the worked example in the PDF?
Q: You suggest crackpot theory? OK. But would my question be ruled out by a fair interpretation of PF rules? Just as i started this thread with a question; a sincere one; with helpful answers.
PS: I believe in my theory; and QM; and I will answer every question.
Perhaps some of your confusion arises because I did not understand a question, or I answered wrongly or inconsistently.
You mentioned a game, which had me confused. I had hoped that the PDF showed my response to ANY game played with EPRB?
  • #43
Would you see, please, if the PDF shows that I finally get to an interpretation of, and use of, angles correctly.
As an engineer, I'm confident that I do,
I have probably made a big mistake in talking about BI-angles. That is what I used personally, to get my head around BT -- me believing BT was wrong the instant I read a Mermin account of it.
It probably reflects my approach to engineering, now I think about: Explaining my thinking, believing the results speak for themselves.
Considering the PDF, the result, may I take it that post #35 is satisfactorily answered now?
And that the answer is not crackpot?
If not, give me another crack at it.
Thanks.
  • #44
JesseM said:
I don't know what you mean by "Bell type probability" since you have said that you aren't calculating the probabilities that the source will emit particles with different combinations of predetermined results for each angle; or did I misunderstand you there? You certainly haven't provided a "counterexample" to Bell in the form of a local realistic physical model, i.e. one where you can give us some local hidden variables associate with the particle and rules for how the variables together with the polarizer angle determine (in a probabilistic or deterministic way) the outcome of each measurement, with the rules obeying locality (so that all values of variables and other events can only be causally influenced by values/events in their past light cone). If you had an actual local realist physical model you would be able to use it to meet the challenge I offered earlier:
But you said you wouldn't be able to win at this challenge. So please don't continue to assert you have a local realist model or a counterexample to Bell if you don't even understand the notion of "local realism" well enough to see what this would actually entail. As you know this forum is not meant to be a platform for people who think they have made some brilliant discovery which destroys some mainstream result, when you asked if I thought it would be appropriate to start a thread like this I offered the opinion that it would be OK if you were here in a spirit of learning and being willing to listen to explanations as to why your argument doesn't falsify Bell's theorem, if you aren't willing to do that and just want to confidently assert that you have done so, then I don't think the discussion should continue on this forum.
As I said in my previous post #25, I would like you to use the standard type of notation for angles, where individual angles are defined relative to some fixed coordinate angles and differences between two angles are defined in some fixed way, like ab=a-b. If you think the terminology of "bi-angles" still makes sense in this context, then please explain clearly what you mean, hopefully using a numerical example where we have definite angles for a,b,c and can thus calculate any angles like ab and ac. If you're just saying that the probabilities of certain observable results may be identical for some combinations of angles, then certainly I agree, for example if we pick a=240, b=120 and c=0 then the probability of ++ for any combination of these angles will be 3/8 according to equation (7) on the Bell inequality[/url] page. But if you're saying something more than that, please explain more clearly.
Can you be more specific? What precise outcome does P1 give the probability of? And likewise for P2, P3, P4, P5, P6, P7, and P8? And do you understand that this is not what P1-P8 are defined to mean on the Sakurai's Bell inequality page, that there they are supposed to be probabilities for different combinations of predetermined results determined by hidden variables, not probabilities of observable outcomes?
Also, if P1-P8 are simply probabilities of observable outcomes, then why is it that you still seem to calculate P(a+, c+) = P2 + P4 and P(c+, b+) = P3 + P7? These equations make perfect sense if P1-P8 are predetermined results as on the wiki page, but I have no idea why an observable outcome like P(a+,c+) would be the sum of the probabilities of two other observable outcomes.
Of course, that's why I keep asking for clarification on your terms, and asking for numerical examples, and saying things like "this thread would be a lot more productive if you would respond to my requests for clarification and numerical examples instead of just repeating the same impenetrable terminology which seems to make sense only to you". You can't just refer me back to the OP because your explanations there were no use to me!
Not in any way that makes sense to me, just with some incomprehensible jargon that seems to be your own private language, not any standard mathematical terminology I'm familiar with. For example, you say "This follows from the topological fact re spatial relations here: ab may be constructed in two ways"...what is a "topological fact re spatial relations", and what does it mean to "construct" ab? Isn't ab just the angular difference between two polarizers at angles a and b, i.e. isn't it just a-b? That's what an angular difference is normally defined to mean by everyone I've ever seen talking about the "angle between" two things!
Why? What physical or geometric considerations lead you to think P(a+, c+) = P2 + P4 and P(c+, b+) = P3 + P7, but that P3 + P4 is only "one-half the average"? Again since you seem to be defining P1-P8 in a totally different way than on the wikipedia page, it would really be helpful if you would tell us what observable outcomes P1-P8 are each supposed to give the probability of.
This average could also be derived from the QM average, calculated over each angle value; i.e., directly from QM's one-angle calculations, done twice, one for each value of the 2-valued ab.
Your notion of "focusing" on 2 angles or "reference angles" are similarly incomprehensible to me, I'm just talking about angles in the standard way that physicists always talk about angles, defining them relative to some fixed coordinate system, see post #25. As I requested there, I would like you to start using this sort of standard definition of angles as well, if your argument really revolves around saying there is something fundamentally flawed about defining angles relative to a fixed coordinate system and that we must use your incomprehensible alternative definitions, then your argument really is hopelessly crackpot and I am not interested in continuing.
Really? What angles do you think QM can't handle? If you have trouble with the standard notation for defining angles, could you draw a picture of polarizers at different orientations and show graphically what angles in the picture you think QM can't describe?
Again it's pretty clear you don't understand what "local and realistic" even mean, if you admit you can't answer my simulation challenge above but still think you have a local and realistic "model". Again if you are here in the spirit of learning rather than just here to proclaim your glorious victory over Bell, please stop making such claims and admit there may be some fault in your understanding of the notion of local realism. For example, did you completely understand the definition of local realism I gave in my [post=3154224]post #20 to Avodyne[/post]? If not we might use that as a starting point.
No, I have no idea what either of these terms mean, that's why I keep asking for clarifications. Please explain using either a numerical or diagrammatic example, not just strange abstract verbal discussions and equations where you haven't explained the meaning of the terms (like your using equations with P1 or ab without explaining what these mean physically) or where the equations come from (like why you think it should be true that ab = ac + bc and ac = ac - bc).
If the experiment is with a Stern-Gerlach apparatus this is pretty straightforward since the apparatus creates a magnetic field and "up" would just mean in the direction of magnetic North while "down" would mean in the direction of magnetic South. With photons, I believe + or - tells you whether the photon passed through the polarizer and was detected by the detector behind it, or whether it was reflected by the polarizer and detected by the other detector (see the diagram of the "two-channel polarizer" on the CHSH inequality page)
If you use a standard notation for labeling orientations with angles, then each orientation has a unique angle. If your argument is that it is somehow impossible or forbidden to use this type of standard notation where there's a one-to-one relation between orientations and angles, then it seems to me you're just confused about basic geometry and at the very least I want to see a diagram of an orientation that you think cannot be assigned a unique angle using the standard procedure (make sure to draw both the orientation and the x-axis of the fixed coordinate system).
Um, how could you possible get that from my comment above? I said that QM only fails to give the Ps in the table if those Ps are understood to have the standard meaning of predetermined results for each possible angle[/b], but you have said this is not what the Ps in your model mean at all, with comments like (from post #10) "I am providing the Ps for different outcomes under the defined tripartite setup; introducing the third orientation to be consistent with Bell and Sakurai; recognizing that we can only test for one angle (two orientations) in anyone physical test." As I keep telling you, the Ps on the wiki page aren't supposed to represent measured outcomes at all, rather they represent predetermined facts about what the results will be for each of the 3 possible angles, these predetermined facts based on hidden variables which human experimenters have no way of knowing. What's more, in a more recent post I asked you:
And in the post of yours I am responding to right now (post #24) you responded:
Your "next post" did not actually explain your disagreement...but look, if you disagree with point #1, then you disagree that there are predetermined answers for all three angles, so you cannot possibly be defining your Ps in the same way as the wikipedia page! On the wikipedia page, P1-P8 specifically refer to the probabilities of different combinations of hidden predetermined results for all three angles! How many times do I have to repeat this, and how many times do I have to ask you what you mean when you write P1-P8 before you will give me a straight answer? If they are supposed to represent probabilities of some observable results, then your comment "So QM does not give the Ps in the Table, and the model does" is clearly wrong, since as I already stated very clearly in the quote you were responding to there, "QM certainly delivers probabilities for all measurable outcomes."
Huh? Again, if you disagree with my point #1 above, then you disagree that there are hidden "predetermined results" for each possible angle, so how can you possibly think you can "identify the Ps in the BI" when these are supposed to be the probabilities of different predetermined results for each possible angle?
No, it certainly doesn't. You have denied that you think the hidden variables associated with each particle after emission give it predetermined results for each possible angle, and if you changed your mind and accepted this, it would be very trivial to show it must be true that P(a+, b+) = P3 + P4 and P(a+, c+) = P2 + P4 and P(c+, b+) = P3 + P7.
Please stop behaving like a crackpot and confidently proclaiming you have overturned Bell while ignoring all possibility that all the criticisms (such as the criticism that you don't seem to even understand what 'local realism' means) have any validity. Again, if you're here to learn and try to understand why the argument might be flawed that's fine, if you're just here to announce your earth-shattering discovery please use another forum.
What does "each ab" even mean, geometrically or physically? I know of only one ab, the angle between the polarizer (or Stern-Gerlach device) which is at angle a relative to some fixed axis, and the polarizer (or Stern-Gerlach device) which is at angle b relative to the same axis.
Jesse, I hoped that my later "tabulated" example, and the PDF (for sure), would address everyone of these points.
Would you cut and paste into separate posts questions remaining after you've studied the PDF, please?
I can see that my jargon has not helped. EG: By "Bell-type probability" I meant any that relate to EPRB and Bell. So I sure meant the examples in the Sakurai-wiki. I was just not wanting to go beyond that scenario, here.
  • #45
JesseM said:
(reply to post #24, continued)
If you're saying you disagree with #1, are you changing your mind from our earlier exchange in post #9 and 10? There I said:
To which you responded:
Have you changed your mind, or did you misunderstand my question, or do you not actually disagree with point #1?
OK, suppose the "large number of trials" in #3 is 900 trillion. And if we are omniscient beings who know all the hidden variables associated with Alice's particle on each trial, and therefore know what predetermined results each particle sent towards Alice had before it actually reached the polarizer, then we can know exactly how many trials in total there were where the particle sent towards Alice had some set of predetermined results, like (a+,b+,c-). Suppose this number is 90 trillion, which would mean P2 is 90 trillion out of 900 trillion, or 1/10. What 3 is saying is that if the hidden variables sent out by the source on each trial have no correlation with the choice of angles Alice and Bob made on that trial, then this same P2 should also give us the fraction that had predetermined results (a+,b+,c-) in the subset of trials where Alice picked angle a and Bob picked angle c. If Alice and Bob each select their angle randomly, then we'd expect a 1/3*1/3=1/9 chance of any given combination of polarizer angles on each trial, so out of 900 trillion total trials, we'd expect that there were about 100 trillion trials where Alice chose angle a and Bob chose angle c. So 3 is saying that within this subset P2 still gives the fraction of trials where Alice's predetermined results were (a+,b+,c-), so the total number of trials where Alice chose a and Bob chose c and Alice's predetermined results were (a+,b+,c-) should be (1/10)*100 trillion = 10 trillion.
To sum up, what 3 is saying is just that the probability the source will send out particles with a given combination of hidden results on a given trial is uncorrelated with what polarizer angles Alice and Bob happened to choose on that trial. If you agreed with #1 and #2 (which apparently you don't), then I don't see how you'd be able to disagree with #3 unless you thought the source had some sort of precognitive knowledge of what settings Alice and Bob were going to choose on that trial, after the two particles had already been emitted.
I believe the PDF should now provide the best answers that I can give to all these questions.
I believe that because I think the PDF moves me closer to QM terms, and hence closer to your field. The maths should be at one with the Sakurai table -- and against the Sakurai-Bell inequality in the Sakurai wiki.
Please, let me know if this answer is not now satisfactory.
  • #46
But the sums are physically meaningless if you don't explain basic definitional questions like what you mean the probabilities P1-P8 to be the probabilities of. You obviously don't mean them to be probabilities of different predetermined states according to the chart on the wiki page, because then you wouldn't say:
If you accepted the standard meaning of P1-P8 you would have to accept this; for example, P3 and P4 are the probabilities of the only two predetermined states where Alice is predetermined to get + if she chooses angle "a" and Bob is predetermined to get + if he chooses angle "b".
JenniT said:
IF IT IMPLIES: P3 + P4 = P3 + P4 + (POSITIVE NUMBER)![/B] (XXX)
Not if you use the standard definition of P1-P8. I have no idea what you mean the probabilities P1-P8 to be the probabilities of, and thus no idea why you think the previous line would "imply" this silly equation.
Forget about particle experiments for a second and consider this simple analogy. Suppose we have a machine that periodically prints out pairs of scratch lotto cards, and sends one card to Alice and one to Bob. Each card contains three squares labeled "a", "b", and "c", which are covered by a silvery substance you have to scratch to see what's underneath, and anytime a square is scratched it will reveal either a + or - underneath. Suppose Alice and Bob choose randomly which square to scratch each time they receive a card, and after many trials we observer that on every trial where they choose to scratch the same square, they get opposite results (+- or -+). Wouldn't the natural local realist conclusion be that each time the machine prints a pair of cards and sends them, then before Alice and Bob choose which box to scratch there is already either a + or - under each square, with the machine always making sure to make each member of the pair the opposite of the other, so for example the hidden symbols on Alice's card are a+,b-,c+ then the hidden symbols under Bob's must be a-,b+,c-? In this case, over many trials the source will print each type of card with some well-defined frequency, so we can define the following probabilities:
P1 = Probability that source sent card (a+,b+,c+) to Alice and card (a-,b-,c-) to Bob
P2 = Probability that source sent card (a+,b+,c-) to Alice and card (a-,b-,c+) to Bob
P3 = Probability that source sent card (a+,b-,c+) to Alice and card (a-,b+,c-) to Bob
P4 = Probability that source sent card (a+,b-,c-) to Alice and card (a-,b+,c+) to Bob
P5 = Probability that source sent card (a-,b+,c+) to Alice and card (a+,b-,c-) to Bob
P6 = Probability that source sent card (a-,b+,c-) to Alice and card (a+,b-,c+) to Bob
P7 = Probability that source sent card (a-,b-,c+) to Alice and card (a+,b+,c-) to Bob
P8 = Probability that source sent card (a-,b-,c-) to Alice and card (a+,b+,c+) to Bob
Can you see that in this example, it must be true that if Alice scratches square a and Bob scratches square b, P(a+,b+) must be P3 + P4? Likewise if Alice scratches square a and Bob scratches square c, P(a+, c+) = P2 + P4, and if Alice scratches square c and Bob scratches square b, P(c+, b+) = P3 + P7. But in no way does this "imply" your strange equation saying that P3 + P4 = P3 + P4 + (POSITIVE NUMBER), here P3 + P4 = P3 + P4 and nothing more. Do you agree that all this is true of this specific example involving scratch lotto cards, ignoring for the moment your weird ideas about particle experiments and angles? Please give a clear yes/no answer here.
If you agree with this, then understand that the probabilities in the Sakurai's Bell inequality page are meant to be exactly analogous, they simply represent predetermined results (determined by the hidden variables associated with the particle, which might be arbitrarily complex) for each of the three allowed orientations of the polarizers or Stern-Gerlach devices. So if you mean the probabilities to represent something different, and this difference leads you to odd conclusions like the "implication" P3 + P4 = P3 + P4 + (POSITIVE NUMBER), you need to explain what you mean the probabilities P1-P8 to represent physically, if they are not intended to have the same meaning as on the Sakurai Bell inequality page. If you don't explain what the physical meaning of P1-P8 are supposed to be, then the "reasoning" behind your statements is going to be totally incomprehensible to anyone but yourself, it's as if you're speaking your own private language that no one else understands. But I suspect that the problem may be deeper, that even you don't really have any clear notion of what P1-P8 are supposed to represent, and that you've just invented some rather arbitrary mathematical rules for yourself without bothering to think about what the physical meaning of the symbols is actually supposed to be.
Why did it have you confused? The rules were fairly simple, you play the role of the source, then you can load any information onto the two flash drives on each trial (representing the hidden variables associated with the two particles created by the source on a given trial), then the two flash drives are sent to Alice and Bob. They then have a choice of whether to press A, B, or C (representing three orientations of simulated polarizers or SG devices), and their computers will simulate the "laws of physics" (these laws can be anything you want them to be, you programmed the rules in advance), taking into account both the variables associated with the particle on the flash drive and the simulated orientation selected by the experimenter, to produce either + or - as output. To "win" this game, you just have to produce statistics analogous to those in QM, meaning that on every trial where Alice and Bob chose the same button to press they always got opposite results, but on trials where they chose different buttons, the frequency they both got + is the same as in QM (and can thus violate the Bell inequality). Is there any aspect of this game you find unclear? If not, do you think that the PDF shows a strategy that would allow you to "win" at this game?
  • #47
Just to be clear on my earlier reply: You are adding over a limited sample. The sample where 2 angles only (in my terms) are clearly defined.
To check any SUM that you (rightly) want to test you MUST sum over all three examples. Then take the average by dividing by 3.
That is what the PDF does. If you think it does not, please say so.
Please see what I say about P1-P8 in the PDF. It CONFIRMS THE QM PREDICTIONS for any outcome that you could wish for; though I have only completed one example: ALL the results for Pab.
Do you disagree with any of the 4 Pab results, please?
  • #48
The PDF doesn't say anything about how you define angles, nor does it say what P1-P8 are supposed to represent physically. If they represent the probabilities of different predetermined results for a given particle like (a+,b-,c+), then logically this would imply that P(a+, b+) = P3 + P4 and P(a+, c+) = P2 + P4 and P(c+, b+) = P3 + P7...see my previous post #46 with the analogy of the scratch lotto cards if you still aren't clear on this. If you use any different formula for calculating P(a+,b+), P(a+,c+) or P(c+,b+), then it's clear P1-P7 must represent something totally different than what they do on the Sakurai Bell inequality page.
With all your confusing comments on bi-angles, I am also unclear on what symbols like ab and bc mean in your pdf...see post #35, do you agree that we can assign a unique angle to each orientation by using a fixed coordinate system, and that the angle between two orientations can simply be calculated by subtracting the angle of one from the angle of the other, so ab=a-b, ac=a-c, bc=b-c, cb=c-b etc.? If you don't agree please address post #35 directly.
  • #49
Taking just the first part of your post:
I am confused.
In the PDF, the P1-P8 are the probabilities that attach to the outcomes that are in the two Bell-table columns to their left.
In equation (1), directly below the table, I directly derive Pab by summing over P3 and P4 (as you suggest).
I get the QM correct result, Sab/2.
In the same way: Any correct QM result may be obtained from the model.
I seem to be missing something; me thinking the table (and the consequent results), was an OK result.
Re games: I do not expect any classical game (eg, cards, balls) to deliver the correct results that are to be associated with EPRB.
I thought (was I wrong) that the so-called silly equation was mentioned somewhere in relation to this thread? I thought someone related it to BI?
Suggestion: Could we please take one key, QM-EPRB based (not classical card games etc) question at a time? One initiating post at a time?
Is there another Pxy sum that might help? I'm concerned/confused that it is not?
Is the above-quoted sum, (1) in the PDF, wrong?
  • #50
YOU say "logically this would imply that
From the PDF; and in its terminology (which is consistent with yours):
Pab++ = P3 + P4. See PDF eqn (1).
Pac++ = P2 + P4; from direct observation in the PDF!
Pcb++ = P3 + P7; from direct observation in the PDF!
As DrC often says: Where's the beef?
Your logical implication agrees with the PDF.
Did you check and think that it did not?
Does this rare agreement between us cause you to reconsider your questions and their focus?
Did you not see in the OP under ANGLES: ab = the angle between orientations a and b?
Are we now further agreed about angles, especially as they appear in the PDF?
  • #51
I am confused.
But those cannot possibly be observable outcomes because they specify + or - for three different angles, whereas on each trial there are only two experimenters who can each get a result at only one angle. Do you understand that on the Sakurai's Bell inequality page, notation like + - + in the "Alice" column is intended to mean that on a given trial, the source sent a particle to Alice whose hidden variables predetermined (even before she chose what angle to set her polarizer to) that if she chose angle "a" on that trial she was guaranteed to get +, if she chose angle "b" on that trial she was guaranteed to get -, and if she chose angle "c" on that trial she was guaranteed to get +? And do you understand that there is no way we can actually know what predetermined results were associated with Alice's particle on each trial, that + - + represents a hidden set of predetermined results, with P1-P8 representing the hidden probabilities that the source sends out each possible set of predetermined results? Please tell me, yes or no, if you understand and agree that this is the meaning of P1-P8 on the Sakurai's Bell inequality page.
If you do understand and agree with this, then are P1-P8 on your table intended to have exactly the same meaning? If not, what do they mean? For example, suppose on one trial Alice chooses angle a and got result +, while Bob chose angle c and got +. How are we supposed to know whether this trial corresponded to the "outcome" [Alice: +--, Bob: -++] or if it corresponded to the "outcome" [Alice:++-, Bob: -++]? Both of these have a + in the "a" slot for Alice, and a + in the "c" slot for Bob. Is the "outcome" of each trial supposed to be something determined by experiment, or is it supposed to be a "hidden" fact which we imagine could be known by an omniscient observer even if it's not known by us, as on the Sakurai's Bell inequality page?
Then why did you say that you "absolutely reject" the claim that P(a+, b+) = P3 + P4 and P(a+, c+) = P2 + P4 and P(c+, b+) = P3 + P7? Which one of these do you reject? I won't be able to understand why you reject it unless you give me a straight answer to what P1-P8 are supposed to be the probabilities of, certainly all three of these equations must be true if P1-P8 have the meaning on the wiki page which I discussed above, do you disagree?
Do you include the type of computer-simulation game I mentioned as a "classical game"? If so, I'd say that shows you don't understand what "local realism" means, since the laws of a local realist universe should be possible to simulate (at least approximately, to any desired degree of accuracy) on a collection of computers where each computer is calculating what should happen in each local region of spacetime, with each computer only having access to the output of other computers which simulated local regions in the past light cone of that one. If you don't see why this should be true and want to discuss it, read over the definition of local realism I gave in [post=3154224]post #20 to Avodyne[/post] and tell me if you don't understand it or don't see how it would imply the idea that a local realist universe should be possible to simulate on a network of local computers each figuring out what happens in a small unit of space in each small increment of time (like a cellular automaton)
I was referring to this equation: P3 + P4 = P3 + P4 + (POSITIVE NUMBER). I'm sure no one seriously suggested a sum of two probabilities could fail to be equal to itself.
It gives the correct answer but without an explanation of what the symbols P3 and P4 are supposed to mean, it is physically meaningless.
  • #52
The PDF does not give any formulas for Pac++ and Pcb++, so I don't know what you mean by "from direct observation". And if that's the case, why did you say in post #42 (after you had posted the PDF) the following?
I was just taking you at your word that you "absolutely reject" that. In any case, if you do agree with these equations, then would you not also agree that since P2, P3, P4, and P7 are all non-negative, it must be true according to your formulas that P3 + P4 ≤ P2 + P4 + P3 + P7, and thus Pab++ ≤ (Pac++) + (Pcb++) for all possible values of a,b,c?
  • #53
Jesse,
1: You appear to have been mislead by an incorrectly placed full stop; possibly from a cut-and-paste. I've fixed this. But am unsure what you think my qualifying clause attached to. And why it is not mentioned in your critique?
May I take it that you do not require me to deliver one of your terms being equal to the sum of two others?
Am concerned there's a subtlety here that I do not want to gloss or miss. Do you require any manipulation of the 3 terms?
2. Re games: Excuse my being guarded here until we are clear about the PDF. Flash-drives etc are classical devices; I doubt they could encode entanglement. It might be that you just want to encode the PDF? Is it the God's-eye distribution that some look for?
PS: Could I have one question per post for a while, please.
Here's mine: Do you require any manipulation of the 3 terms that you keep citing, please?
  • #54
JesseM said:
A: The PDF does not give any formulas for Pac++ and Pcb++, so I don't know what you mean by "from direct observation".
I meant "by looking at the table".
JesseM said:
B: And if that's the case, why did you say in post #42 (after you had posted the PDF) the following?
Please see the qualifying sentence immediately beneath
JesseM said:
C. I was just taking you at your word that you "absolutely reject" that. In any case, if you do agree with these equations, then would you not also agree that since P2, P3, P4, and P7 are all non-negative, it must be true according to your formulas that P3 + P4 ≤ P2 + P4 + P3 + P7, and thus Pab++ ≤ (Pac++) + (Pcb++) for all possible values of a,b,c?
Help please. Could you explain the physical significance of this SUM?
Is it the case that the inequality holds (or is relevant) for some logical or physical reason?
I think explanation here might make it clearer to me where I have confused you. Or where I have erred.
Thanks.
  • #55
JenniT said:
Jesse,
I thought "if it implies" was just a rhetorical phrase, like "I reject Obama's healthcare plan if it implies people are mandated to buy insurance", where the person saying this knows that Obama's plan does include such a mandate. Are you saying you are genuinely unsure as to whether the equations P(a+, b+) = P3 + P4 and P(a+, c+) = P2 + P4 and P(c+, b+) = P3 + P7 hold, or whether P3 + P4 = P3 + P4 + (POSITIVE NUMBER) would be an implication of this? I don't know what possible argument would "imply" that the second would be a consequence of the first, seems like a total non sequitur to me. And in any case, if you aren't even sure how to calculate P(a+, b+) and P(a+, c+) and P(c+, b+) then you obviously can't claim that you have a well-defined "model"!
If by this you mean P(a+, b+) = P3 + P4 and P(a+, c+) = P2 + P4 and P(c+, b+) = P3 + P7, then this is an automatic consequence of the definitions of P1-P8 on the Bell inequality page, if you don't think all three of these equations hold then you need to explain what your physical definitions of P1-P8 are (as I keep asking over and over) and how you calculate P(a+, b+) and P(a+, c+) and P(c+, b+).
Don't know what you mean by "manipulation".
A "local realist" model of QM would be a classical model in the sense that Maxwell's laws are classical, it would explain everything without recourse to superpositions or spooky-action-at-a-distance. Again it seems doubtful to me that you really understand the meaning of "local realism" if you don't see that local realist models should be possible to simulate to arbitrary accuracy on classical computers.
If you want to pick your strategy in the game by "encoding the PDF" be my guest. For example, on each trial you could load the flash drives with a set of predetermined results like a+,b-,c+, with the probabilities of different predetermined results on each trial being determined by P1-P8 in your PDF. Then each computer's algorithm for generating a "result" on each trial would just be to take the button pressed by the user (Alice or Bob), then look at the corresponding slot on the predetermined results on the flash drive, and give the symbol in that slot as output (for example, if Alice chooses button "b" and her flash drive contains the predetermined results a+,b-,c+, then the output would be -). But this strategy would not be a "win" for you, because the statistics over many trials would not match those of QM.
Again I don't know what you mean by "manipulation", perhaps you could give an example? Anyway, my main question right now would just be how you would propose to calculate P(a+, b+) and P(a+, c+) and P(c+, b+), whether you would use the formulas P(a+, b+) = P3 + P4 and P(a+, c+) = P2 + P4 and P(c+, b+) = P3 + P7, with P2,P3,P4,P7 all defined as in the PDF, or whether you would use some different formulas.
  • #56
Your table does not give any formulas for calculating Pac++ and Pcb++.
It would hold in a local realist theory where each particle pair has hidden variables that predetermine what result it would give to any of the possible polarizer angles, with P1-P8 giving the probabilities of different sets of predetermined results as shown in the wiki page's table. But Pab++ ≤ (Pac++) + (Pcb++) does not hold in the theory of quantum mechanics for certain values of a,b,c. Therefore the theory of QM cannot be explained by a local realist theory.
  • #57
OK; so we're clear on what I meant.
We appear to agree re non sequiturs.
I am sure of my calculations and reject the non sequitur.
Did I not answer this? https://www.physicsforums.com/showpost.php?p=3158191&postcount=50
The model is well-defined ... at least in so far as it agrees with your logical implication.
Jesse, I'm sure that I calculate them the same way you do, using P1-P8 per the PDF.
If you refer to the calculation of each of P1-P8; they are derived from local realistic considerations. Just before this post of yours I was about to post this:
Thinking hard about our differences, does this help: Are you confusing my model with naive realism? With EPR elements of physical reality, interpreted in the naive tradition?
I AM NOT in the naive tradition in any way. My HVs are perturbed by the measurement interaction. To my mind, via spin axes following gyroscopic-like trajectories. The tricky word in EPR eprs is "corresponding".​
OK. I meant equating the 3 of them in some way.
Oh! Oh! Is your requirement realistic?
I'm pretty sure that entanglement cannot be simulated on classical computers: spherical symmetry etc.
I am confident that my LR ideas cannot be simulated. You seem to be limiting LR to naive realism, in some of these phrases. My LR, primitive or cumbersome as it may seem, delivers the PDF. Your question below relates to that. LET US NOT get carried away by discussing LR now. If the PDF fails, my LR fails.
My model would require us to go beyond the encoding of gyroscopes, no two gyroscopes the correlated, except pair-wise; observers freely setting measurement orientations at random, ... Let's not digress; just yet.
Manipulation addressed above.
I think I answered the next one: No difference between you and me here. Have you run a few lines using the PDF example below the table?
You do see that each result there is in total agreement with QM?
My question: Has anyone, presumably from the so-called Bell community, delivered the values for P1-P8 that the table requires? I'd be keen to see where they differ from mine.
  • #58
"Using P1-P8" is still vague, do you use all of the equations P(a+, b+) = P3 + P4 and P(a+, c+) = P2 + P4 and P(c+, b+) = P3 + P7, yes or no? If you do then your probabilities will obey the inequality Pab++ ≤ (Pac++) + (Pcb++)! The whole point of the proof is that QM violates this inequality, therefore it cannot be compatible with local realism! If you use the equations P(a+, b+) = P3 + P4 and P(a+, c+) = P2 + P4 and P(c+, b+) = P3 + P7 then your model disagrees with QM, do you not understand this?
  • #59
Could you just use your formula; or the evident formula that I used in the worked example.
Why not do Pac++ and Pcb++?
Here's my answer: Sac/2, Scb/2. The QM results, I believe?
By predetermined; do you allow the HV to respond to each SGM that it encounters?
I'm wondering if this is the key difference between us. Explaining your focus on card-games? Card games cannot deliver the PDF table!
My calculation would yield: Pab++ = Sab/2 ≤ 1/2.
Which MUST hold in QM.
For I have Pac+– and Pbc+– added to the RHS of what you offer above.
My one question: Is it not the case that they too deliver: a = +; b = +; and so must be included in any rational study?
Thanks, as always,
JenniT
  • #60
JesseM said:
"Using P1-P8" is still vague, do you use all of the equations P(a+, b+) = P3 + P4 and P(a+, c+) = P2 + P4 and P(c+, b+) = P3 + P7, yes or no? If so then your probabilities will obey the inequality Pab++ ≤ (Pac++) + (Pcb++)! The whole point of the proof is that QM violates this inequality, therefore it cannot be compatible with local realism! If you use the equations P(a+, b+) = P3 + P4 and P(a+, c+) = P2 + P4 and P(c+, b+) = P3 + P7 then your model disagrees with QM, do you not understand this?
We are cross-posting.
I use all, and maybe more, in the equation of yours above.
(This is what I meant by "manipulation, in its + sense, please understand!)
MY PDF violates this inequality, and agrees with QM, as explained in my just sent post.
  • #61
Jesse, my replies will be spasmodic for a week or more. I will try to keep in touch because I think that we are getting to the meat of the differences between us.
XO, JenniT
  • #62
And how did you calculate these answers?? I just want a yes or no answer to the question of whether you use the formulas Pab++ = P3 + P4 and Pac++ = P2 + P4 and Pcb++ = P3 + P7, I won't discuss any further issues if you continue to be evasive on this simple question. It's obvious that if you do use these formulas, you will not get the QM predictions of Pab++=Sab/2, Pac++=Sac/2, and Pcb++=Scb/2 (if you think you will, you have made a math error somewhere)
edit: and speaking of math errors, your derivation in the PDF for Pab++=P3+P4=Sab/2 doesn't work. I'm fine up to the step where P3+P4=(2Sab + Cac.Sbc + Sac.Cbc)/6, but how do figure that this would be equal to (2Sab + 2Pab++)/6? That's clearly wrong if you substitute some actual angles, like the earlier example of a=240,b=120 and c=0. In this case we have:
Sab=sin^2 ((a-b)/2) = sin^2 (60) = 0.75
Cac=cos^2 ((a-c)/2) = cos^2 (120) = 0.25
Sbc = sin^2 ((b-c)/2) = sin^2 (60) = 0.75
Sac = sin^2 ((a-c)/2) = sin^2 (120) = 0.75
Cbc = cos^2 ((b-c)/2) = cos^2 (60) = 0.25
So, Pab++=P3+P4=(2Sab + Cac.Sbc + Sac.Cbc)/6=(2*0.75 + 0.25*0.75 + 0.75*0.25)/6 = 1.875/6 = 0.3125
But if Pab++ = 0.3125 using your formulas with the specified angles, then clearly it is not true that Pab++=Sab/2 according to your formulas, since Sab/2 = 0.75/2 = 0.375 (and this would be the answer predicted by QM, so if Pab++=P3+P4 and we use the values of P3 and P4 in your table, we get an answer which differs from QM here). Nor are either of these equal to (2Sab + 2Pab++)/6, this would be equal to (2*0.75 + 2*0.3125)/6 = (1.5 + 0.625)/6 = 2.125/6 = 0.3541666... So, you must have goofed in the step where you equated (2Sab + Cac.Sbc + Sac.Cbc)/6 to (2Sab + 2Pab++)/6.
edit #2: Perhaps the reason for this erroneous substitution of Cac.Sbc + Sac.Cbc = 2Pab++ is that you were using 2Pab++=2P3 + 2P4 combined with the original definitions of P3 and P4 in your original post on this thread? But that will not do, because the definitions of P3 and P4 in your original post are incompatible with the definitions of P3 and P4 in the PDF table. For example, in the original post you define P3 = Cac.Sbc/2, which for the angles a=240, b=120 and c=0 is equal to 0.25*0.75/2 = 0.09375...whereas in the PDF table you define P3 = [Sab.Cac + Sab.Sbc + Cac.Sbc]/6, which for the same angles is equal to [0.75*0.25 + 0.75*0.75 + 0.25*0.75]/6 = 0.15625. So you have to pick one or the other, you can't use both definitions for P3.
  • #63
Indeed, I fully agree with this. Remember that there was "permission to post your 8 numbers" for pedagogical reasons, but there seems not to be much pedagogy happening.
So, to be clear: NO, JenniT, you are NOT allowed to open yet another thread on this same subject.
  • #64
I've been following this thread and haven't wanted to post in it so as not to disrupt it's thematic flow (such as it was), however since JenniT has said that she will be off the internet for several days, then I hope it's ok. Nothing Earth'shaking, but some progress in my understanding -- I think.
I hadn't until recently understood the significance of DrChinese's Local Realistic (LR) dataset requirement wrt evaluating proposed LR models of entanglement. Comments in this and other recent threads have helped to clarify my thinking on this subject -- which has led me to a better understanding of why explicitly local hidden variable models of entanglement can't possibly reproduce the range of the qm statistical predictions.
Wrt what constitutes an LR model, it might be phrased that it's the explicit representation of locality (which entails an explicit representation of the local hidden variables that are relevant wrt the production of the local facts of individual measurements, which in turn imposes a constraint on the range of the predictions that any such model of entanglement can produce) that defines a model as LR, and not only whether the model satisfies Bell's inequality (BI).
However, insofar as Bell's LR model is the archetypal LR model1 of entanglement, a necessary condition for a model to be considered LR is that it must satisfy BI.
Hence, any proposed LR model that violates BI is, by definition, not an LR model. On the other hand, it's been definitively shown that any proposed LR model that satisfies BI can't possibly reproduce the qm predictions (or, as has also been definitively demonstrated2, be in agreement with experimental results).
So, there doesn't seem to be any point in considering any proposed LR model of entanglement.
Exactly what BI is implying or has to do with the deep reality underlying instrumental results is another question, the answer to which is, imho ... nothing. BIs are statements about the constraints on the relationship between joint polarizer settings and joint detection attributes (where individual detection attributes are limited to values of 0 and 1) given certain formal, LR, requirements.
1Bell's ansatz is the archetypal LR model of entanglement because it encodes both an explicit expression of locality and an explicit expression of the hidden variables which produce the local experimental facts.
2There's some disagreement about this, but the experimental loophole considerations have, imho, turned out to be strawman or superfluous considerations wrt the correct interpretation of the physical meaning of Bell's theorem.
  • #65
(XXX)
Of course not.
That is NOT what the Bell inequalities imply.
What the Bell inequalities imply is the following:
IF YOU ASSUME that all of the emitted the pairs have PREDESTINED responses to 3 possible measurements on both sides independent of which of these three measurements is actually going to be performed (this is the LOCAL REALISM ASSUMPTION), THEN there exist 8 numbers P1...P8 such that
P(a+,b+) = P3 + P4
P(a+,c+) = P2 + P4
and P(c+,b+) = P3 + P7
The 8 numbers P1...P8 come from the 8 different possibilities to predestine responses.
IF that is the case, then it is simple arithmetic to show that:
P(a+,c+) + P(c+,b+) = (P2 + P4) + (P3 + P7) = P3 + P4 + P2 + P7
= P(a+,b+) + P2 + P7.
And from this follows that IT WILL BE IMPOSSIBLE to find 8 such numbers and to obtain that P(a+,b+) is larger than P(a+,c+) + P(c+,b+), no matter what funny theory GENERATES these numbers. You cannot have that P3 + P4 is LARGER than P3 + P4 + positive number.
Now, quantum mechanics DOES NOT assume that the pairs are predestined, so in quantum mechanics there is no such a priori existence for 8 such numbers.
AND it turns out that for specific experiments with pairs of electrons, we can find 3 measurements on both sides such that the QM predictions for P(a+,c+), P(c+,b+) and P(a+,b+) are such that P(a+,b+) is larger than the sum of P(a+,c+) and P(c+,b+).
Note that in QM, P(a+,b+) must not be equal to some P3 + P4. It is only if you claim that you have an EQUIVALENT LOCAL REALISTIC THEORY which predestines the pairs that these numbers P1...P8 have a meaning, and then you run in the impossibility that you should have that these numbers satisfy that P3 + P4 > P3 + P4 + positive number (namely P2 + P7).
Now, YOU CLAIMED that you could provide us with 8 such numbers. Clearly you haven't. (and clearly it is impossible). You asked if you could show them. For sake of pedagogy, you were allowed to "show" us those impossible numbers (I told you so).
Your numbers do NOT reproduce the QM predictions. They do so for 2 out of 3 (you can ALWAYS do it for 2 out of 3) and they fail (of course) for the 3rd prediction, because if they wouldn't, they'd satisfy impossible conditions.
Now, you have been talking A LOT here, not learning a lot.
Up to now, you haven't.
Your PDF doesn't show anything, except for a specific calculation of 8 numbers, 8 numbers which DO NOT correspond to the predictions of QM.
  • #66
vanesch said:
Of course not.
P(a+,b+) = P3 + P4
P(a+,c+) = P2 + P4
I hope this addresses the issues above:
Let us take: ab = 90, ac = bc = 45.
From the PDF, I derive in the given worked example:
Pab++ = Sab/2 = 0.25.
In similar manner, I derive (and will add as an addendum when I get back)
Pac++ = Sac/2 = 0.0732
Sbc++ = Sbc/2 = 0.0732
I thought that these were the QM predictions?
PS: I'm learning a great deal, and am sorry if I'm trying your patience. But can you see here why I must ask another question?
So please: Let me have the next specific question that now arises from you, re the above. For it seems to me that the problem must be somewhere else.
PS: If you doubt my calculations; well, when I put them into an Appendix you will see the same method as in the PDF example, and the same answers that I have given above.
Q: I might ask: Why do you say that the PDF numbers are wrong? I thought that QM had no such predictions for the table?
I've asked to see them, but so far have not.
Thank you.
  • #67
The Pab++ example can be checked right now. It is the worked example in the PDF.
A math error there will be repeated in an addendum that I'll add when I get back; giving the other workings, and those values I have already given to you.
This is rushed, but are you looking at the right table. The PDF has the correct result. The 3 earlier labels, as explained, had one angle not specifically specified. A problem resolved when the 3 were amalgamated to give the PDF.
The PDF amalgamates the 3 earlier tables; all angles are there specific.
Just off the cuff, [for now] as above, the 3 earlier tables were required by my model to produce the PDF. The PDF is the model; the others were steps in the model building because I could not handle my "angle" problem any other way.
The substitutions that you query are given in post #33.
There you will see: Pab++ = P3 + P4 = (Cac.Sbc + Sac.Cbc)/2.
And all the other such.
That is where the queried substitution comes from.
Excuse rush.
  • #68
I must interject here. Either the mentors and science advisors are capable of explaining clearly and succincltly why prospective LR theories are pointless, or they aren't capable of doing that. There's nothing to be learned by this nitpicking -- imho.
Refer back to DrC's post. (#2?, iirc)
If the proposed LR model doesn't produce an LR dataset (and therefore satisfy BI), then it isn't an LR model. Period.
And if it does produce an LR dataset then it can't agree with qm (and, so far and presumably, with experimental results). Period.
There's nothing else to consider. LR models of entanglement are impossible. Period.
What does this tell us of the underlying reality? Nothing. Period.
  • #69
Pac++ = Sac/2 = 0.732
Sbc++ = Sbc/2 = 0.732
Clearly, it can't. (there's a typo for Pac++ and Pbc++ where the values are 0.0732, but I guess this is a typo).
I didn't check your pdf in detail, but in your pdf, you (correctly) define:
Pab++ = P3 + P4
You work this out to something (I didn't check the goniometric algebra), but it equals P3 + P4.
You didn't work out the rest, but if it is done correctly, you should also have:
Pcb++ = P3 + P7
and
Pac++ = P2 + P4.
It is a pity that you didn't work it out.
Now, I can assume that the numerical value of P3 + P7 doesn't change between when you write it as P3 + P7, and when you work out the goniometric algebra :wink:
(otherwise you made a mistake in your algebra, right ?)
Now, give me please the NUMERICAL VALUES for a vertically, c 45 degrees towards the window, and b horizontal towards the window (so 90 degrees), for all 8 values P1, ... P8 and then for your calculation of Pab++ , Pac++ and Pcb++.
Because it should be obvious that if all your values P1...P8 are positive numbers, and if Pab++ = P3 + P4 and so on as you claim (correctly), that you CANNOT obtain numerically Pab++ = 0.25 and Pac++ = Pcb++ = 0.073...
So in order to show you this, you should work out, for the given angles, the numbers P1 up to P8, and then Pab++ = P3 + P4 and also according to your algebra Sab/2 and Pcb++ and Pac++.
  • #70
Well this thread is the result of a request by JenniT that he/she COULD generate 8 numbers P1...P8 such that it corresponded to the quantum predictions. This is clearly impossible, but up to now JenniT has been claiming otherwise.
His/her first attempt gave:
QM: 0.25, 0.073, 0.073 (for spin-1/2 particles and axes 0 degrees, 45 degrees and 90 degrees) and JenniT produced a first set of 8 numbers such that the numbers that came out were 0.125, 0.073 and 0.073, and there was a lot of hot air about a claim that these WERE the right results because of "an average that had to be taken over two different angles" without ever having cleared this up.
Now we seem to have ANOTHER proposal by JenniT where he/she claims this time to HAVE produced 8 numbers such that the predictions come out to be:
0.25, 0.073 and 0.073
after some algebra.
As this is algebraically impossible, we ask him to give us the 8 numerical values, and show how they comply with the above calculation.
You're right, but we're dealing with somebody who claims he knows how to make one.
  • Quantum Interpretations and Foundations
12K
  • Quantum Physics
  • Quantum Physics
