- #36
Astronuc
Staff Emeritus
2023 Award
- 22,121
- 6,797
The upper level of containment, the metal walls and roof, was destroyed. That structure is over the inner containment, which is reinforced concrete. I believe the reinforced containment had the pressure increase, which was vented. The venting would be through those stacks (towers) that one sees behind (to the west of) the units. Venting into the upper containment would not be the case as far as I know.alxm said:NHK English is currently reporting that the hydrogen explosion didn't rupture the containment vessel. (Albeit the outer wall of the building) From what I know of these things, that's pretty much where it would be expected to happen - given that they try to vent the steam 'under the dome' rather than to the outside?
Drastic in the sense that seawater would not normally be introduced directly into the core. Salt water would corrode the stainless steel in the core. It's probably safe to say that unit 1 will not be restarted, but decommissioned. In theory though, it's life could have been extended another 20 years.Drastic mostly in terms of radiation leakage, then? I mean, I doubt they have much concern for the reactor itself at this point. They were due to be decommissioned soon even without this disaster, so I think it's safe to say these reactors will never go critical again.
