Question about spent fuel rod cooling pools in Japàn reactor
In summary, the current situation in Japan's nuclear crisis involves concerns about the cooling pools for spent fuel rods drying up and catching fire. The pools are located at the top of the concrete structure and are filled with water to cool the fuel and shield personnel from radiation. The plant personnel are working to prevent the pools from going dry and minimize damage to the cores of three units. There are also concerns about the global consequences if the spent fuel rods release their radioactive material, but it is uncertain how severe these consequences may be due to differences in reactor design between Fukushima and Chernobyl. However, limited information is available on the status of the cores, reactor pressure vessels, containments, and SFPs, making it difficult to assess the situation.
GUS
42
Could anyone who actually works on this kind of thing answer a couple of questions about the current situation in Japans nuclear crisis :
Is it true that cooling pools for spent fuel rods are stored on the rooves of these reactors ? If so we see two of these rooves have been blown off - so were there rods on it and if so what happened to them ?
What are the consequences of the cooling pools for spent fuel rods drying up and the spent fuel rods catching fire ?
In the containment systems at FK, the spent fuel pools are located at the top of the concrete structure, under the metal building part. They are below the floor level (top of concrete structure).
The pool is filled with water to cool the fuel and shield personnel from radiation.
The concern now is that water in the SFPs of Unit 4 and possibly in Units 1,2,3 might evaporate. Then the concern is that those fuel rods will overheat and release their radioactive material - thus compounding the radioactivity release at the plant and out to the environment.
The plant personnel are attempting to prevent the pools from going dry, while trying to minimize the (or prevent further) damage to cores of three units.
Thanks for the reply.
I still feel a little unclear on the answer though, Ill try and rephrase them .
Were the spent fuel rods that were stored at the top of the concrete structure blown up with the explosion ?
If the pools run dry and the spent fuel rods release their radiocative material is it true that the consequencies globally would/could be far worse than Chenobyl ?
No - as far as we know. The SFPs would have about 30 feet (10 m) of water above the spent fuel - unless they suffered some structural damage during the earthquake, and the damage caused a leak in the pool. That is unknown at this point - or at least has not been reported.
Not necessarily, but that remains to be seen. There are big difference in the reactor design. Chernobyl was a graphite0moderated reactor, which got really hot, and there was basically not containment around the damage core. The Fukushima units are LWRs, specifically BWRs, and we believe there is water in the core/pressure vessel, and the containment (reinforced concrete) is largely intact, but there are some leak paths. However, there are three units with core damage, and one unit with a spent fuel pool at risk. The three other spent fuel pools could also be at risk perhaps. Unfortunately, we do not have the techical details to do a reliable assessment of the status of the cores and SFPs. We can only monitor the activities being released.
Those of us on the outside of the plant lack the critical information and data regarding the stata of the cores, reactor pressure vessels (RPVs), containments, and SFPs - and the fuel in the cores and SFPs.
Thanks again for the reply - but I really only want an answer ot one question (hypothetically of course) I am not enquiring as to the current state of the reactors, but the potential consequences of the spent fuel pools drying out . The fact that they are not releasing such critical data would indicate that there is quite a lot of spent fuel rods . I am just trying to separate scaremongering from fact. Ill clarify :
IF the spent fuel pools dry out and their radiocative material is released into the atmosphere could the consequences be far worse than chenobyl (globally) ?
The answer is no, because at Chernobyl a large explosion and graphite fire launched radioactive material high into the atmosphere where it traveled long distances- that won't happen here as long as pressure is properly moderated in the reactors themselves.
How likely is it that they can "properly moderate the pressure in the reactors" ?
I was reading that the burning spent fuel rods release radioctivity as a gas and so it could get more or less anywhere.
My not so educated guess is that there is good hope that this won't have such largely spread consequences, because the driving force behind spreading it (a burning run-away reactor at Chernobyl, while "just" overheating fuel bars here) is smaller. However, the total amount of potential highly radioactive material is probably much larger in this case, and in both cases (Chernobyl and here) there's no, even partial, containment left to hinder this.
So in the hypothetical as of now, but not to be excluded case if the site is totally abandoned,
the potential is there for a very ugly contamination, but one can hope that it won't be spread high up in the atmosphere as in Chernobyl. This will also depend how much "recent" fuel is there, and how hot the stuff is going to become when left to itself.
In reactor #3 it looks like the spent fuel rod pool above the reactor is gone! It was located in the roof of the building that was blown off in the explosion on Monday. Why can't they see up close with a satellite to see the damage and confirm? Where are all the spent fuel rods from reactor #3? Did they explode into the air onto the ground and ocean?
Dear Astronuc (or others)
Several questions regarding the spent fuel rods;
If water is added to the dried out storage tank, will future radioactive emissions be contained? even if the protective jacket is breached?
Assuming that the outer protective jacket of the spent fuel rods have been damaged/melted, when water is added to the pond in order to cool the reaction, will the water itself be contaminated by the released radioactivity?
If this is the case, how will the contaminated water eventually be collected and contained?
In the case that the water evaporates due to the absorption of the heat, will the evaporated water vapor be radioactive?
What are the decay products in the spent fuel rods? Do they have long half-lifes?
I attach a link that illustrates the location of the storage tank. The tank is not located on the roof. However, it is located in the upper part of the concrete structure. Can anyone explain why the tanks are not designed to be built into the lower ground level? Seems to me to be a more prudent design to have the tank supported on the ground. http://www.npr.org/2011/03/15/134569191/spent-fuel-rods-now-a-concern-at-nuclear-plant
It would seem that a relatively small volume of concrete could effectively cover the tank to prevent radioactive leakage - say 2-3,000 m3. Would this be an effective way to contain the radioactive leakage?
Thanks in advance for answering my questions.
I wish good luck to those on the ground containing the problem!
If the fuel rods breach, they release fission product gases, Kr and Xe, and volatiles such as Br and I, and possibly Cs. Cs, like Na or K, is more likely to dissolve in water. Other fission products, which are more or less solid, would be retained in the fuel matrix or dissolve in water. Some UO2 may oxidize, a process occurring mostly along grain boundaries (grain size on the order of microns), and particles of fuel, either single grains or groups, can fall out of the fuel into the water. Single grains or lightest particle may become dust.
Yes, some fission products will dissolve in water, and some particulates will migrate into the water.
Very good question. I would expect that a circulation system would be established, and the particles collected on filters. The challenge will be the volume of water, the surface areas, and the mass of fuel to be collected. Not only is the SFP affected, but also the primary and secondary containments.
Noble gases and some volatiles can be carried with the steam plume.
I'll post a chart of fission products in a bit, maybe in a separate thread. Some decay in seconds, others in the fuel matrix in thousands or millions of years. Short-lived FPs decay away rapidly. In 10 half-lives, activity drops by a factor of 1000, in 20 HL, activity drops by a factor of 1M, and in 30 HL, activity drops by a factor of 1 Billion. Basically the activity drops by 2^N, where N is the number of HL.
The spent fuel pool is located near the reactor cavity so that discharge fuel can be removed under the cover of water from the reactor core to the spent fuel pool. The fuel to be reused/reinserted in the next cycle may also be placed temporarily in the SFP. The SFP is an interim storage to allow cooldown (thermally and radiologically) of the fuel until it is placed in dry storage. In some modern containments, the spent fuel pool is placed in a separate, but well protected area.
Possibly. However, it would complicate longer term plans to decontaminate and decomission the facility. It would also increase the load on the containment below the pool, and possibly increase the risk of structural failure, particularly in case of another significant seismic event.
Experts knock notion of burying Japanese reactors
http://news.yahoo.com/s/ap/20110318/ap_on_sc/us_japan_nuclear_burial
You're welcome. :smile:
Me too!
FYI -
SUBJECT: DRAFT FINAL TECHNICAL STUDY OF SPENT FUEL POOL ACCIDENT RISK AT DECOMMISSIONING NUCLEAR POWER PLANTS
http://www.nrc.gov/reading-rm/doc-collections/acrs/letters/2000/4711885.html
Fact Sheet on NRC Review of Paper on Reducing Hazards from Stored Spent Nuclear Fuel
http://www.nrc.gov/reading-rm/doc-collections/fact-sheets/reducing-hazards-spent-fuel.html
Safety and Security of Commercial Spent Nuclear Fuel Storage: Public Report (2006)
Board on Radioactive Waste Management (BRWM)
http://www.nap.edu/openbook.php?record_id=11263
"Radiological Terrorism: Sabotage of Spent Fuel Pools"
Journal Article, INESAP: International Network of Engineers and Scientists Against Proliferation, issue 22, pages 75-78
http://belfercenter.ksg.harvard.edu/publication/364/radiological_terrorism.html
Yay Mothers for Peace!
http://mothersforpeace.org/data/20010201Nureg1738Pdf/at_download/file (it may take a while to download) - 18.4 MB
Alternatively http://mothersforpeace.org/data/20010201Nureg1738Pdf/view
Thank you Astronuc for your reply.
Upon reflection, I agree with your assessment of the concrete containment. I believe, as you do, that this would further complicate the issue.
As a final question regarding the spent fuel rod cooling pools; assuming that the tanks are intact i.e. not having significant leaks, that the tanks may be refilled and kept filled, how long in terms of weeks (months) would the rods need to be submersed before they could safely be transported for permanent storage or recycling? Assume that the rods have been recently removed from the reactor.
Based on your knowledge of what's happening inside the double containment reactors, do you believe that the situation is under control? If so, how do you see the situation playing out over the next weeks and months?
As before, thanks in advance for your reply.
Xylourgos
For shipping a fuel rod or small group, a utility would allow perhaps months to a year for cooldown - more so from radiological the thermal. There are dose limits on the surface of the container. They might special containers/casks, if they wish to empth the pool sooner. And they'd need a facility to accept a relatively large quantity of fuel. However, the concern will be damage to the fuel - if the fuel was exposed.
In a BWR fuel assembly, eight of the fuel rods are tie rods. A tie rod has threaded top and bottom endplugs (i.e., the shanks are threaded). The fuel rod is fasted to the bottom cast stainless steel tie plate (or nozzle). The upper end plug shank protrudes above the top of the upper tie plate, through a lock washer, and a nut is fasted over the lock washer.
Here's an illustration of a 9x9 BWR fuel assembly. It is fabricated by NFI and is based on Siemens 9x9-9Q or Atrium-9 Design. It has 72 fuel rods surrounding a centrally located water channel. JNF makes a 9x9 design with two cylindrical water rods displacing 7 fuel rods.
NFI-9x9: http://www.nfi.co.jp/e/product/prod02.html#c
GE8x8 - http://www.world-nuclear.org/uploadedImages/org/info/GE BWR nuclear fuel assembly 2.jpg (shows 4 assemblies and control rod arrangement in core)
CFD model of BWR assembly
http://www.ansys.com/Industries/Academic/University+of+Texas+at+Austin,+U.S.A .
Refueling a core - http://www.gereports.com/from-nuclear-fuel-recycling-to-laser-enriched-uranium/ - what it is supposed to look like.
Moving forward the steps would be:
Decontamination
Assess fuel in SFPs (remote rad-resistant cameras)
Dismantle destroyed upper containments & Debris removal - need to bring in big cranes
Cover/secure SFPs or remove fuel (At unit 4, it would make sense to put the fuel back in the core - without the fresh fuel).
Somehow inspect cores - probably with submersible robots and rad-resistant cameras.
Removing the damaged fuel from core could take several years.
Depending on the contamination - the units might be mothballed for decades.
Astronuc
I appreciate your response to my questions over the past 2 days. I have learned a lot from your postings and links.
I don't have any tie to the nuclear industry. However, I have been dismayed by the sensational fear mongering exhibited by the msn. I believe the news channels have exhibited far greater meltdown in their hysterical reportage than the situation on the ground in Japan merits. I believe nuclear energy should play a larger role in energy production going forward. Lessons learned from Japan should be applied. Dispense with the hysteria and educate the public. It's going to be a hard sell.
My background is civil engineering. I have a construction company in Greece. We specialize in roads, bridges and tunnels. Should you come to Greece, let me know. I would like to buy you a retsina!
Xylourgos
What is the mechanical resistance of these rods?
I see most people here are worried about the water level in the tank, but could these rods resist the impact of large chunks of concrete falling from several meters without buckling and rupturing?
Depends on the temperature, degree of oxidation (metal loss from metal-to-oxide), and degree of hydrding. If there is significant hydriding, e.g., at the end plug or adjacent to sites of oxide spallation, then there would be little resistance - few ksi perhaps.
I suspect rupture in core, and if any occurred in the fuel in the SFP, it's ruptured hydrided areas, or perforations due to excessive oxidation.
I might as well just spit it out :
What are the chances of the entire world being drenched in dangerous levels of radiocativity as a result of this accident (on a scale of 1 - 100, 100 being likely ) ?
Dangerous is a relative term.
I'm quite sure I'm about to use up all of my GOOB cards in the next few minutes, but I don't care.
I play a http://www.funtrivia.com/private/main.cfm?tid=87626" on a daily basis, sponsored by one of the forum mentors, which a few days ago asked the question; "What is the highest and lowest incidence of melanoma, by country, on the planet".
The answer was Australia and Japan.
Given the events that had just happened in Japan, I was all ready to jump in and post these "new findings". :rolleyes:
But in order to protect my score, I kept the little know fact to myself.
Radiation, in all it's forms, is simply a fact of life. Without solar radiation, none of us would be alive at the moment discussing whether or not radiation is good or bad.
But to answer your question, my best guess is 0.00001%.
Life is fraught with danger.
And that's why Risk Management executives are at the top of my list in terms of compensation.
But to answer your question, the answer is 100%.
I am aware of that - I live in Cornwall where there is several times the normal background level of radiation quite naturally. I am enquiring about the potential of this disaster to raise radiation levels above what are considered safe levels - globally.
What I am looking for is an informed opinion (from an unbiased proffesional if possible) - due to the spent fuel rods some people are describing the potential consequences of this disaster as "chenobyl on steroids" - is this true ?
Thats all I want to know - I am not a fan of scaremongering or burying the head in the sand - I would just like a straight answer.
Are you referring to something like this?
http://www.youtube.com/watch?v=KdlguAC0rpQ&feature=youtube_gdata_player
Well, I haven't been a professional nuclear technician for about 27 years now, so I don't know how much my opinion counts.
I googled "Chernobyl on Steroids", and it appears the phrase originated with someone named Arnie Gundersen, a nuclear engineer at Fairewinds Associates. Fairewinds Associates being a two person company, Arnie and his wife Maggie. http://www.fairewinds.com/content/what-we-do" states that they are in the business of Research and Analysis, Paralegal Services, and Expert Opinions.
Other than Arnie, I can only find parrots repeating what he has said.
Here is an excerpt from the first article I ran across regarding Arnie which was written a little over a year ago:
http://atomicinsights.blogspot.com/2010/02/is-arnie-gundersen-devious-or-dumb-or.html"
Thursday, February 11, 2010
by Rod Adams
after hearing Gundersen's testimony, I thought a bit more about what he had said during the hour that he testified. He and his wife stated that they ran a business that offered the service of "expert witnesses" and that they were in front of the Senate committee in that capacity. Translation: someone was paying them to be there.
I also heard that Gundersen had been offering employed in the capacity of an "expert witness" on a number of previous occasions. Translation: Gundersen was a professional expert in court cases; these employment opportunities are often given to people with credentials who are willing to say things, in our adversarial judicial system, that are not necessarily factually incorrect, but are certainly selected facts that support the contentions in the case.
bolding mine and Rods
It is annoying that even the http://www.iaea.org/newscenter/news/tsunamiupdate01.html" doesn't know the status of the temperature in the spent fuel pool of unit 1. Maybe I'll edit my last post for a more realistic probability.
Do you consider driving a car dangerous ?
If you have an integrated dose of 60 mSv, and you use the linear model, then the probability of dying because of this dose in the coming 50 years are of the order of magnitude as the probability of you dying in a car accident in the coming 30 years (20 years latency for the illness to take you away). If I didn't make an error in my simple calculation.
The linear model essentially tells you that you have a chance of ~5% of dying in the coming 50 years for a dose of 1 Sv and is, well, linear or proportional.
Now, I have a hard time thinking that many people will receive a 60 mSv dose because of this accident, except nearbye, and except, if things really turn badly, those that are very unlucky to get a lot of fallout on their heads.
I think, if I remember correctly, that the highest doses people from the public were exposed to at Chernobyl were something like 5 mSv to 700 mSv for certain people who were within the 30 km radius, and were only evacuated 2 days after the start of the accident. Remember also that Chernobyl was a WORKING reactor, so the nastiest and quickly decaying fission products were dumped all around. Many of those are gone now at Fukushima.
However, it can be nasty on certain spots, where there is strong fallout, if really a large part of the cores in Fukushima goes airborne.
According to some reports the spent fuel pool has 40 years of spent fuel rods stored there. Would that not be considerably more radiocative material than chenobyl ?
So that's really what I would like - a slightly more technical answer.
Lets assume that 40 years of fuel rods are stored there and the catch fire - I believe various radiocative gases can be released as a result of this. So what I am trying to get answer to is how much radiation could be released in the form of these gases. What are the gases, how radioctive are they, , what are their half lives, obviously they would disperse more easily than particulates - but exactly how diffuse would they be, how easy would it be to stop such a fire if it got started, would emergency services even be able to get near it to dump concrete all over it etc etc
I guess the answer I am looking for is somewhere in the middle of "are you afraid of cars" and a detailed expose of nuclear physics that requires at least calculus level maths to understand it properly.
P.S> new and extremely well researched book out shows how Chenobyl killed at least 1 million people :
http://climateandcapitalism.com/?p=3146
so you'll excuse me if I don't find your chenobyl statistics reasuring.
No answer to my last post ?
Although I am not a nuclear engineer but this nuclear physisist seems to agree with my assesment :
FAQ: Question about spent fuel rod cooling pools in Japàn reactor
What is a spent fuel rod cooling pool in a Japanese reactor?
A spent fuel rod cooling pool is a large pool of water used to store and cool spent nuclear fuel rods from a nuclear reactor. These fuel rods have been used in the reactor and are highly radioactive, so they need to be cooled and stored safely to prevent any potential hazards.
How do spent fuel rod cooling pools work?
The cooling pool is filled with water that helps to absorb and dissipate the heat from the spent fuel rods. The water also acts as a radiation shield, protecting workers and the environment from the high levels of radiation from the fuel rods. The pools are typically deep enough to fully submerge the fuel rods and keep them cooled.
Are there any risks associated with spent fuel rod cooling pools in Japanese reactors?
While there are always risks associated with any type of nuclear facility, spent fuel rod cooling pools in Japanese reactors are designed and built to be safe and secure. However, there is always a potential risk of accidents or leaks that could lead to radiation exposure. That is why strict safety protocols and regulations are in place to ensure the proper maintenance and operation of these pools.
How are spent fuel rods disposed of from the cooling pools?
After the spent fuel rods have been cooled in the pool for a sufficient amount of time, they can be transferred to dry storage containers or reprocessed for future use. The disposal method depends on the regulations and policies in place at the specific reactor site.
What measures are in place to prevent accidents or leaks from the spent fuel rod cooling pools in Japanese reactors?
There are several measures in place to prevent accidents or leaks from the spent fuel rod cooling pools in Japanese reactors. These include regular inspections, maintenance, and monitoring of the pools and the fuel rods, as well as strict safety protocols and emergency response plans. Additionally, the pools are designed with multiple layers of protection, such as containment structures and backup systems, to prevent any potential hazards.
