Linear Phase Filter Impulse Response: H(z) Calculation and Analysis
In summary: The z-transform and its propertiesThe inverse z-transform and its propertiesThe relationship between the transfer function and the frequency response of a filter.Are you familiar with any of these topics?In summary, the conversation discusses finding the z-transform for a filter with a given impulse response and determining if it is a linear phase system or a high pass filter. The conversation also delves into the relationship between the transfer function and frequency response of a filter and the necessary conditions for a linear phase characteristic in the passband.
Evo8
169
A filter with the following impulse response
h(k)=(-.75 .5 0 -.5 .75)
find H(z)
Is its a linear phase system?
Is it a high pass filter?
h=[c0, c1, c2, c1, c0] <--- I think this is valid for this problem anyway
So if i understand this properly for my H(z) I get.
[itex] H(z)=-0.75+0.52z^{-1}-0.5z^{-3}+0.75z^{-4}[/itex]
Then to find out weather or not this is a linear phase system I find my H(f) frequency response?
I get
[itex]H(f)=-0.75+0.5e^{-j\theta}-0.5e^{-3j\theta}+0.75e^{-4j\theta}[/itex]
First off, Am I on the right track here?
Thanks for the help,
Ok so I did a little more digging and I think I am going about things a little wrong here?
The given values for h(k) are as follows
H(0)=-.75
H(1)=.5
H(2)=0
H(3)=-0.5
H(4)=0.75
I need to find the z transform of this sequence. I always have a hard time with this form. "transpose"
do I do this form inspection? So I would end up with the following?
[itex]H(z)=-0.75+0.5z^{-1}-0.5z^{-3}+0.75z^{-4}[/itex]
This is what I had before though. Is my Z transform of the sequence above along the right lines?
Thanks in advance..
Your z-transform is correct.
TBH, I do not know whether this is a linear phase system or a high pass filter.
I was hoping someone else would respond before now, but obviously no one else did.
So I guess for now you're stuck with me.
The wiki pages are not clear enough as far as I'm concerned and I haven't tried to delve too deeply into other sources yet.
Do you have more information what the conditions are for both types of filters?
I can dig up some information on the types of filters and add it to the thread.
Right now I am a little stuck with the simplification of my H(f) frequency response.
This is what I have right now from evaluating my H(z) at z=j/theta
[itex] H(f)=-0.75+0.5e^{-j\theta}-0.5e^{-3j\theta}+0.75e^{-4j\theta}[/itex]
When I use eulers identity to convert to sin and cosine it becomes a mess that only makes things worse. I am sure there's something I can do to simplify and factor before i apply euler's identity. I could factor out a 0.5 but i don't see how that would help. Since the exponents in the exponentials are different how can I combine them? I am not seeing something here.
Any hints would be appreciated? As always I am stuck on the algebra.
You can take out ##e^{-2j\theta}##.
That should leave you with 2 sines using Euler's formula.
Man I am not good at this. I don't fully see it?
Something like this sort of?
[itex]H(f)=-0.75+e^{-2j\theta}(0.5-0.5e^{-j\theta}+0.75e^{-2j\theta})[/itex]
I don't think this is correct at all though. I feel like I have broken every rule in algebra even writing this? I am looking up basic algebra rules now to see if i can get this to make sense.
Hmm, that is "half" right.
I don't quite understand how you did half correct and dropped stuff off in the other half...
Anyway, it should be:
e^{-2j\theta}(-0.75 e^{2j\theta}+0.5 e^{j\theta}-0.5 e^{-j\theta}+0.75 e^{-2j\theta})
Can you recognize the sines now?
Ok after looking at what you have written and played with the numbers a bit I see where i got lost. Again basic algebra skills that are missing.
Ive used Euler's formula and but i end up with 2 sines and 1 cosine.
The exponentials in the parenthesis simplify down to [itex]-1.5jsin(2\theta)+jsin(\theta)[/itex]
When I apply Euler to the factored out [itex]e^{-2j\theta}[/itex] and add it to the above i get...
[itex]cos(2\theta)-2.5jsin(2\theta)+jsin(\theta)[/itex]
How do I get left with just 2 sines?
Thanks again for your help on this.
Not missing. I'd say not fully developed yet, but I guess that won't be long now. ;)
The expression you got is not right though. Apparently you did not properly eliminate the parentheses.
But anyway, I intended:
e^{-2j\theta}(-1.5j\sin(2\theta)+j\sin(\theta))
Which you can rewrite as:
e^{-2j\theta}e^{j{\pi \over 2}}(-1.5 \sin(2\theta)+ \sin(\theta))
= e^{j({\pi \over 2} - 2\theta)}(-1.5\sin(2\theta)+\sin(\theta))
I don't think there's much use in simplifying more.
The 2 sines form a real number now.
If you're interested in the argument of the complex number, you can read it off now.
It's ##({\pi \over 2} - 2\theta)## if the sine expression is positive.
Otherwise you need to add another pi.
Your right I didnt evaluate the parenthesis properly. Looking back I am not sure why I thought it was ok to just remove those after there were individual terms added or subtracted. I see where I went wrong. I understand now how to get the equation shown below.
e^{j(\frac{\pi}{2}−2θ)}(−1.5sin(2θ)+sin(θ))
This is actually in the correct form for me to determine weather or not this is a linear phase filter.
Looking in the section about this in my book and following an example it talks about an:
"alternate" way to characterize a linear phase filter is in terms of the frequency response which can be written in the following general for.
H(f)=A_{r}(f)e^{\alpha-2\pi\tau f}
Here the factor $$A_{r}(f)$$ is real, but it can be both posative and negative. It is referred to as the amplitude response of H(z). This is to distinguish it from the magnitude response A(f), which is never negative. Taking the magnitudes of both sides we see that a amplitude response and the magnitude response are related to one another as follows.
|A_{r}(f)|=A(f)
The points at which [itex]A_{r}(f)=0[/itex] are the points Fz, where the phase can abruptly change by [itex]\pi[/itex] as Ar(f) changes sign. Thus ghd piecewise-constant function B(f) jumps between zero and [itex]\pi[/itex] each time the amplitude response Ar(f) changes sign.
A linear phase characteristic in the passband can be achieved in the analog domain by an IIR Bessel filter. However, the linear phase feature does not survive the analog-to-digital transformation. Consequently, it is better to start with a digital FIR filter as follows.
[itex]H(z)=\sum b_{i}z^{-i}[/itex]
For an FIR filter, there is a simple symmetry condition on the coefficients that guarantees a linear phase response.
It then shows an example with similar coefficients unlike the problem that I have been working on through this thread. So now I am not 100% sure how to go about it.
If what I do have is a linear phase filter the [itex]\alpha=\frac{\pi}{2}[/itex] but I am not sure what the [itex]\tau[/itex] would be...maybe [itex]\tau=-1.5T[/itex] I dunno.
I still don't see anything in this chapter about high pass filters so I am looking into that.
Where you have written ##\theta## I think we should read ##2\pi f## (or something like that).
And I think your formula should include "j":
$$H(f)=A_{r}(f)e^{j(\alpha-2\pi\tau f)}$$
As such your ##\alpha## would be ##\pi \over 2## and ##\tau## would be ##2## (or something like that), making it a linear phase filter.
More specifically the phase changes linearly with f, with a fixed offset and a jump of pi somewhere.
I think this constitutes a linear phase filter.
Your correct I must have missed that j in there. and yes the [itex]\theta is 2\pi f[/itex]
And after reviewing the examples again I see now where that tau comes from. I guess i didnt see or recognize that it was in the exponential. So my problem here is very similar to an example in the book (the end anyway) so the [itex]\tau=2T[/itex] I think. Plus the 4 in my exponential was throwing me off I suppose.
Im still searching for high pass filter information. But the rest of this problem is MUCH more clearer now. Thank you as always for the help. MUCH appreciated.
I've helped you a couple of times now and I'd like to know a bit about who it is that I'm helping...?
Could you for instance fill in a couple of fields in your profile?
No problem. I filled in the "about me" section.
Btw thanks for the Happy New year wishes on my profile! I guess its been a while since I've visited it.
Ill see if I can dig up a picture and post.
Btw in case you were curious about determining weather if this filter is a high pass or not this is what I found out.
[itex]Z=e^{j2\pi fT}[/itex] when [itex]f=0, z=1[/itex] and when [itex]f=\frac{F_{s}}{2} , Z=-1[/itex] So if I evaluate my H(z) for this filter at z=1 and z=-1 I get 0 for a response on both ends. So it can't be a highpass or a low pass for that matter. Band pass or something like that i would assume.
so @f=0 H(z)=0
@f=fs/2 H(z)=0
Thought you might be interested in this.
Thanks again!
Thanks for the info.
It'll come in handy when next someone posts a question like this.
Cheers! :smile:
Turns out, the information you posted comes in handy sooner than I expected! :wink:
Thanks for pointing this out! I forgot we spoke about the phase response in here.
Related to Linear Phase Filter Impulse Response: H(z) Calculation and Analysis
1. What is a linear phase filter?
A linear phase filter is a type of electronic filter that produces a linear phase response, meaning that all frequencies of the input signal are delayed by the same amount of time. This results in a constant group delay, which is desirable for certain applications such as audio signal processing.
2. How is the impulse response of a linear phase filter calculated?
The impulse response of a linear phase filter can be calculated by taking the inverse Fourier transform of its frequency response. This can be done using mathematical formulas or with specialized software tools.
3. What is the significance of the impulse response in a linear phase filter?
The impulse response of a linear phase filter represents the output of the filter when a Dirac delta function is used as the input signal. It contains information about the filter's frequency response, phase response, and group delay, and is used to analyze and design the filter.
4. How can the impulse response of a linear phase filter be analyzed?
The impulse response can be analyzed by looking at its time-domain characteristics, such as rise and fall times, overshoot, and settling time. It can also be analyzed using techniques such as Fourier analysis, which can reveal the filter's frequency response and phase response.
5. What are some common applications of linear phase filters?
Linear phase filters are commonly used in audio signal processing, including equalizers, crossovers, and digital audio effects. They are also used in communications systems, radar systems, and medical imaging devices. They can also be found in various types of electronic equipment, such as amplifiers and loudspeakers.
