Unraveling the Mystery of the Massless Photon
In summary: No, it's not. As I do not set m=0 it does not refer to my calculation. And as you noticed the limes you should be aware of that. So what's your...problem?
Quarlep
257
We know the equation E=pc or P=mc both of them are avaliable for photon.But photon is a massless particle.How can that be possible ?
Thanks
What exactly is the problem here?
And have you read the FAQ in the Relativity forum?
Zz.
Quarlep said:
P=mc
I guess you got this from p = mv which is non-relativistic. Photons are relativistic objects and therefore follow the relativistic equation ##E^2 = (mc^2)^2 + (pc)^2## where m is the invariant mass a.k.a. "rest mass" (yes, it's a silly name for the mass of a photon which is never at rest), which gives you your E = pc.
The usual equation for relativistic momentum in terms of velocity is
$$p = \frac{mv}{\sqrt{1 - v^2/c^2}}$$
but this doesn't work for photons because it gives p = 0/0 which is undefined mathematically.
There happened math error can you wrote it again please ?
Please read: https://www.physicsforums.com/showthread.php?t=511175
Yes.
False, in the case of photon $$p=\frac{h}{ \lambda}$$
Thanks
It isn't , you are making a mistake, see above.
Is it possible OP means:
P = E/c = (E/c2)c = mc ?
Thus a gross abuse of relativistic mass, and another reason it has fallen out of favor.
Are you referring to my equations? I see them OK. Are you using the PF app on a smartphone or other mobile device? I think LaTeX equations are properly visible only in a web browser. I can see them in Safari on my wife's iPad, as well as in Firefox on my main computer.
However, using the PF app on the iPad, I see only the LaTeX source code.
It is not undefined. After substitution with
[tex]E = \frac{{m \cdot c^2 }}{{\sqrt {1 - \frac{{v^2 }}{{c^2 }}} }}[/tex]
the result for the removable discontinuity is
[tex]\left| p \right| = \mathop {\lim }\limits_{\left| v \right| \to c} \frac{{E \cdot \left| v \right|}}{{c^2 }} \cdot \frac{{\sqrt {c^2 - v^2 } }}{{\sqrt {c^2 - v^2 } }} = \frac{E}{c}[/tex]
You cannot do this types of manipulations since both [tex]E = \frac{{m \cdot c^2 }}{{\sqrt {1 - \frac{{v^2 }}{{c^2 }}} }}[/tex] and [tex]p=\frac{mv}{\sqrt {1 - (v/c)^2}}[/tex] are valid ONLY for [tex]m \ne 0[/tex].
As such, the formulas cannot be applied to the photon, as you are trying to do in your calculations.
Did you noticed the limes?
Yes, I noticed, your STARTING point is wrong, i.e. your error occurs BEFORE you take the limits.
Thanks
Hopefully you've read the FAQ by now.
When we say that a photon has no mass, we mean that it has no invariant mass or rest mass. When you write P=mc, you are using relativistic mass, which is equal to E/c^2.
Thus the term "mass" is ambiguous. Modern textbooks and papers tend to use invariant mass, while older textbooks and popularizations still often use relativistic mass.
Given that we know that the "mass" in your second equation is the old-fashioned "relativistic mass", the second equation is just a restatement of the first
P = m_relativistic * c is the same as P = (E/c^2)*c = E/c which is the same as E = pc
As a side note, the general relativistic relationship between energy, momentum, and invariant mass is given by:
E^2 = (p*c)^2 + (m*c^2)^2
What exactly is wrong with my starting point?
I thought this is quite clear.
No, it's not. As I do not set m=0 it does not refer to my calculation. And as you noticed the limes you should be aware of that. So what's your point?
You CANNOT start with [itex]E = \frac{{m \cdot c^2 }}{{\sqrt {1 - \frac{{v^2 }}{{c^2 }}} }}[/itex] since it DOES NOT apply to photons. One day you'll get it.
I demonstrated how to do it. It's quite simple math. One day you'll get it.
Closed pending moderation
FAQ: Unraveling the Mystery of the Massless Photon
What is a photon?
A photon is a fundamental particle of light and other forms of electromagnetic radiation. It has zero rest mass, zero charge, and travels at the speed of light in a vacuum.
How do we know that photons are massless?
Scientists have conducted numerous experiments and observations that have consistently shown that photons have no mass. Additionally, the theories of special and general relativity, which have been extensively tested and validated, also support the idea of massless photons.
If photons have no mass, how do they have energy?
While photons have no rest mass, they do possess energy due to their wave-like properties. This energy is proportional to the frequency of the photon, meaning that photons with higher frequencies have more energy.
Why are photons considered to be massless?
Photons are considered to be massless because they have no rest mass, meaning they do not have any mass when they are not moving. This is in contrast to other particles, like electrons, which have rest mass even when they are at rest.
Could there be a situation in which photons have mass?
Currently, there is no evidence to suggest that photons have mass in any situation. However, some theories, such as the Higgs mechanism, propose the existence of a particle called the Higgs boson that would give photons mass. So far, this has not been observed or proven.
