- #36
Oxymoron
- 870
- 0
Ok, so I am pretty sure I understand what covariant and contravariant tensors are. A covariant tensor or type (0,2) is a map
[tex]T:V\times V \rightarrow \mathbb{R}[/tex]
Now if you take, say a two dimensional vector space [itex]V[/itex] which has two basis components [itex]\{e_1,e_2\}[/itex] then the dual vector space [itex]V^*[/itex], which (as robphy and pervect pointed out) has the same dimension as [itex]V[/itex], then has two basis components. Now am I correct in assuming that the basis components of the dual space is written in Greek? As in, [itex]\{\epsilon_1,\epsilon_2\}[/itex]?
So a vector [itex]\omega \in V^*[/itex] may be written as a sum of it's basis components: [itex]\omega = \alpha\epsilon_1 + \beta\epsilon_2[/itex]?
Extending this idea to [itex]n[/itex]-dimensional vector spaces we have that [itex]e_1,e_2,\dots,e_n[/itex] is a basis for [itex]V[/itex] and [itex]\epsilon_1,\epsilon_2,\dots,\epsilon_n[/itex] is a basis for [itex]V^*[/itex].
As we have already discussed I assume that when writing, say, the product of the two basis vectors [itex](\epsilon)(e)[/itex] and by including the indices we would write
[tex]\epsilon^i(e_j)[/tex]
So I would write the [itex]i[/itex] index superscripted because the [itex]\epsilon[/itex] basis vector came from the dual vector space, and the [itex]j[/itex] index is subscripted because [itex]e_j[/itex] came from the vector space. Is this the reason for superscripting and subscripting indices - to make a distinction about which space we are in? Because after all, they are by no means identical bases, even if the vector space and its dual are equal?
My last question for now is, why is the product
[tex]\langle \epsilon^i,e_j \rangle = \delta_j^i[/tex]
equal to the Kronecker delta? The Kronecker delta equal 1 if the indices are the same, and zero if the indices are different. Let's say that the vector space, [itex]V[/itex] has [itex]n[/itex] dimensions and the dual space, [itex]V^*[/itex] has [itex]m[/itex] dimensions. Then,
[tex]\delta_j^i = 1 + 1 + \dots + 1 + 1^* + 1^* + \dots + 1^*[/tex]
where there are [itex]n[/itex] 1's in the first sum and [itex]m[/itex] 1*'s in the second sum. Therefore
[tex]\delta_j^i = n + m = \dim(V) + \dim(V^*)[/tex]
which should equal the product of the basis vectors, [itex]\epsilon^i[/itex] and [itex]e_j[/itex]. Could this be the reason?
