- #36
- 15,473
- 702
A free-falling object is following a geodesic in space-time. You get a fictitious centripetal force when you use a non-inertial frame.cabraham said:The centripetal force is that of gravity.
You are using Newtonian mechanics and you are assuming that it is perfectly true. It is not. General relativity is a better (more accurate) model, and gravity is not a force in general relativity. It arises from the use of a non-inertial frame.But there is no source for centrifugal. Where does it come from? A free body diagram of the satellite includes only centripetal. In the inertial frame of the satellite there is an attractive force of gravity.
Look at it this way. Suppose you are designing a spacecraft or an airplane that uses accelerometers as a part of its inertial navigation system. The flight software will have to augment the accelerometer readings with estimates of the gravitational force to have any chance of making the propagated state reflect reality for the simple reason that accelerometers measures all real forces acting on a body except for gravity. This, of course is the Newtonian mechanics view of accelerometers. From a general relativistic viewpoint, the viewpoint is simple: Accelerometers measures all real forces acting on a body, period.
People jump out of planes on a regular basis. The free-fall period is, from what I have been told, very exhilarating. The act of free-fall itself doesn't kill. Hitting the ground sure does.As far as the despondent lovers leap is concerned "it wasn't gravity that killed him, it was normal force", my answer is "get real!"
