- #1
Starwatcher16
- 53
- 0
Is there a minimum value for how small a wavelength can become?
Starwatcher16 said:Is there a minimum value for how small a wavelength can become?
Naty1 said:Absolutely!
The limit on wavelength and frequency is limited by the discrete nature of space and time itself. Space and time are not continuous and that means some restrictions apply.
You can't get shorter than Planck time frequency nor shorter than Planck length wavelength, about 10-43 seconds and 10-35 meters.
There are energy limitations as well, a corollary to frequency/time stemming from de Broglie relationships...via E = hf for example...so frequency is proportional to kinetic energy...I assume Planck scale energy provides Planck scale wavelengths...
Another way to consider energy limits is via black hole formation: put too much energy into a finite particle, say accelerating a particle to Planck energy, and a black hole will form via mass energy equivalence.
are the ideas that you express about the Planck length true enough to warrant such a confident answer?
...At the Planck scale, the strength of gravity is expected to become comparable to the other forces, and it is theorized that all the fundamental forces are unified at that scale, but the exact mechanism of this unification remains unknown.
Any photon energetic enough to precisely measure a Planck-sized object could actually create a particle of that dimension, but it would be massive enough to immediately become a black hole (a.k.a Planck particle), thus completely distorting that region of space, and swallowing the photon.
At this (Planck) scale, the concepts of size and distance break down, as quantum indeterminacy becomes virtually absolute.
...The wavelength of a photon (and therefore its size) decreases as its frequency or energy increases. The fundamental limit for a photon's energy is the Planck energy, for the reasons cited above.
Naty1 said:...so I checked Wikipedia and found:(since I had no direct sources for my original reply)
...at the Planck scale, the strength of gravity is expected to become comparable to the other forces, and it is theorized that all the fundamental forces are unified at that scale, but the exact mechanism of this unification remains unknown.
These are the ideas I had in mind, maybe I did not express them clearly??
anyway, I'll stick with my answer for now.
Civilized said:These ideas are part of laymen's physics folklore, not mainstream theoretical physics e.g. string theory. The notion that spacetime is discrete is mostly found in unpublished manuscripts by amateurs, unreviewed web 2.0 writings e.g. wikipedia or comments on blogs etc.
Civilized said:OK, but then you are doing religion instead of science.
In conventional, ordinary, non-science fiction physics, frequency is a frame-dependent quantity. An electromagnetic wave can have any possible frequency, depending on the coordinate system you use to describe it.
...let there be no doubt that spacetime in the standard model and in string theory is a smooth manifold --- which a layperson would call "continuous" --- and is no way made of discrete pieces
The problem with Quantum Field Theory (QFT) is that it is based on the idea that space and time (are continuous)...In fact most versions for QFT go haywire and produce nonsense...The remarkable fact is that string theory is quintessentially a holographic theory describing a pixelated universe...
The spectrum of particles does not terminate at the Planck mass. It continues on to indefinitely large mass in the form of black holes...like ordinary particles only discrete masses are possible.
..on scales short than Planck distances and durations quantum uncertainty renders the fabric of the cosmos so twisted and distorted that the usual conceptions of space and time are no longer applicable...the smaller the scale of observation the larger the uncetainty and the more tumultous the quantum fluctuations become...Einstein's relativity (with) gently curving geometrical shape runs smack into the core principle of quantum mechanics, the uncertainty principle, which implies a wild turbulant...environment on the smallest of scales.
GR is background independent (bi)...this means spacetime is dynamical; nothing is fixed...a quantum therory of gravity should also be bi...space and time should arise from it, not serve as a backdrop for the actions of strings...string theory is not currently formulated as a bi theory...this is it's chief weakness...
The Planck length is in some sense the smallest thing that can be observed...will all observers agree on what this shortest length is?...there appears to be conflict between the idea of Planck length and special relativity...
The concept of a photon was introduced by Max Planck in 1900...(existing theories)predicted a hot body would instantaneously radiate all its energy into light waves of arbitrarily high frequencies...Planck resolved this conflict...by introducing the assumption light is not a continuous wave but instead comes in discrete energy packets.
The short wavelength photon behaves as if it were a particle and the impact on electrons is similar to what happens when one billard ball; strikes another...Long wavelength light...is ineffective (in ejecting electrons)... because each photon carries too little energy
So where does the extra energy go in a situation in which, for example, Doppler shifting or gravitational blue shifting would otherwise shorten a wavelength to less than the Planck length?
Civilized said:Discrete spacetime is not compatible with one of the best tested symmetries in nature, lorentz symmetry, ...
Naty1 said:excellent question(s) ! I do not know the answer(s).
I'll keep your questions in mind and see if any insights pop up...or you could post them in the quantum mechanics or relativity forums...I can never decide which forum to use...
maybe someone will be able to answer.
Naty1 said:hmmmm...seems Civilized and Vanadium have stopped making accusatory comments.
I gave the answer. Electromagnetic wave frequency is a frame dependent quantity, so you can always find a frame where it's bigger. That's the answer, and it's not worth arguing about. You can either accept it, or not.
i have trouble to find the smallest and the longest wavelength ever measured/ produced...
(appears) is my addition.Down to about 10-34 meter the quantum universe at large is well described by classical...geometry...althought quantum fluctuations become increasingly significant. That one can trust the classical approximation to such short distances is rather astonoishing. On still shorter scales quantum fluctuations of spacetime become so strong that classical, intuitive notions of geometry breakdown...the number of dimensions (appears) to drop from four to ABOUT two.
Naty1 said:No, you gave the (correct) CLASSICAL answer. Anyone who thinks all there is to physics is classical relativity will miss a lot.
..In quantum mechanics it turns out energy comes in little, indivisible steps...the size of a quantum unit depends on the frequency...Planck and Einstein discovered for light quanta the quantum of energy is E = hf...you will never notice the quantization of energy in orfinary experience...increasing the the energy of an electromagnetic wave by one step is the same as adding a single photon to a light beam...the fact that energy can be added only in indivisible quanta seems illogical (to a classically wired brain) but that is what quantum mechanics implies..
No, he's saying light comes in the form of discrete photons rather than a continuous wave. He's saying that, for monochromatic light of a given frequency f, the energy comes in integer multiples of hf.Naty1 said:Sounds like Susskind is saying frequency f is a restricted, quantized entity??
you say potato, I say potato...Naty1, that is not a frequency constraint, it is a General Relativity principle regarding Equation of State called causality.
Wikipedia said:Very high-frequency photons, which cycle at once per Planck time or faster, could potentially swallow themselves up in black holes from their own energy density, which would make it difficult or impossible to probe this time scale. In the quantum theory, this would mean that the Planck time should be the smallest unit of time physics can reason about in a meaningful way.
Frequency refers to the number of occurrences of a repeating event per unit of time. It is measured in hertz (Hz) and is commonly used to describe the rate at which waves, such as sound or electromagnetic waves, oscillate.
Technically, there is no maximum frequency as it can continue to increase infinitely. However, there are practical limitations due to the capabilities of measuring equipment and the physical properties of materials. In addition, frequencies in the range of 10^24 Hz, known as the Planck frequency, are considered to be the theoretical limit of frequency.
The highest frequency that humans can hear is approximately 20,000 Hz. This range decreases with age and can vary from person to person.
Yes, high frequencies can be harmful to humans and other living organisms. Exposure to high frequency electromagnetic waves, such as X-rays and gamma rays, can cause damage to cells and tissues. In addition, exposure to loud sounds at high frequencies can lead to hearing loss.
The higher the frequency, the higher the energy of the wave. This is because frequency and energy are directly proportional. As frequency increases, the wavelength decreases, resulting in a higher energy density per unit of time. This relationship is described by the formula E = hν, where E is energy, h is Planck's constant, and ν is frequency.
