Accelerated expansion without Dark Energy?
In summary, there is a model that explains the accelerated expansion of the universe without the need for dark energy, but it goes against the Copernican Principle and needs more evidence to convince other cosmologists. Some argue that there is no need for dark energy and that the current data can be used to refute its existence. However, others argue that dark energy is necessary to account for the expansion of space between galaxies. The term 'energy' in this context refers to a miniscule force, not the traditional type of energy. There is ongoing debate and research on this topic in the scientific community.
phsopher
180
There was an article in the Proceedings of the National Academy of Sciences where the authors derived a model which explained the accelerated expansion of the Universe without needing the ad hoc assumption of Dark Energy. I haven't really done any cosmology yet so I can't really appreciate the argument. What do you guys think? It seems that their theory goes against the Copernican Principle, which doesn't seem promising.
Here's the article:
http://arxiv.org/PS_cache/arxiv/pdf/0901/0901.1639v1.pdf"
Space news on Phys.org
The shockwave model of Smoller and Temple is a valid one mathematically, but to perceive accelerated expansion our galaxy must be in a rather unlikely place. It might be, but to convince other cosmologists they'll have to point to other observational evidence that their model explains better than the Lambda-CDM standard model. Not an easy task.
If the gravity behaved differantly at interglatic distances than it does on smaller scales, then there would not be a need to consider dark energy to explain the accelerating expansion of the universe.
Dark energy is not an 'ad hoc' contribution to the standard model. It is based on the supernova legacy study, which is well grounded. It is difficult to refute the dark energy proposition without new physics. No such models have been proposed to date.
Chronos;
Could you explain what supernova legacy lead to the necessity of dark energy?
My impression has been that it's the acceleration of the universe's expansion that leads to the need for dark energy.
Xnn said:
Chronos;
Having read and analyzed the data from the Supernovae Legacy Study, I too have my doubts about any need for 'dark energy'.
Instead, it appears to me to be a last ditch attempt to save the General Relativity Standard Model.
So exactly how is 'dark energy' said to be justified? Further, I do NOT see any need for 'new physics' in addressing this issue -- what is needed is to simply DROP this concept of a General Relativity determined cosmological redshift. All that is needed is a straightforward recession velocity expansion one.
See: http://arxiv.org/PS_cache/arxiv/pdf/0804/0804.4142v1.pdf
Here is an excerpt:
1. INTRODUCTION
The evidence for dark energy has evolved from the first
hints, for the case of a flat Universe (Perlmutter et al.
1998; Garnavich et al. 1998; Schmidt et al. 1998),
through the more definite evidence for the general
case of unconstrained curvature (Riess et al. 1998;
Perlmutter et al. 1999), to the current work which aims
to explore the properties of dark energy (for a review see
Perlmutter & Schmidt 2003). Several new cosmological
measurement techniques and several new Type Ia supernova
(SN Ia) datasets have helped begin the laborious
process of narrowing in on the parameters that describe
the cosmological model. The SN Ia measurements remain
a key ingredient in all current determinations of
cosmological parameters (see, e.g., the recent CMB results
(Dunkley et al. 2008)). It is therefore necessary to
understand how the current world dataset of SN Ia measurements
is constructed, and how it can be used coherently,
particularly since no one SN Ia sample by itself
provides an accurate cosmological measurement.
Here is an excerpt:
1. INTRODUCTION
Good dataset -- or rather the best we have.
However, the same dataset can be used to refute dark energy as unneeded. The problem is that the current data has a error that is still an order of magnitude too large to be able to choose between models.
Dark energy is still well in the speculation zone -- far from acceptable mainstream or proved. In fact, the need for General Relativity on the cosmological scale is unproved and becomes more so as the apparent flatness of the universe gets more support.
So far all I see is a declarative statement 'Dark Energy' and no compelling argument for its existence or need.
First of all, I am not a cosmologist or scientist just an old engineer that is interested in cosmology. It seems to me that if there is a very small expansion force independent of distance between particles that is overwhelmed by gravity at less than intergalactic distances could explain the expansion of the universe without the need for "dark energy".
The expansion force could be inertia from the "big bang" and be so small relative to the gravitation force in intragalactic distances that gravity keeps the galaxy together. However as the distance between galaxies increases the gravity force is too week to stop the expansion force.
I am not trying to create "new physics" just a thought without any scientific basis.
Peter Danforth
The residiuals for high redshift supernovas clearly indicate the best fit curve overshoots those.
No worries, Peter, I too am an old engineer with an interest, but no particular expertise in cosmology. Dark energy is needed to account for the miniscule force causing space to expand between galaxies in deep space [a second law of thermodynamics thing]. The term 'energy' is misleading. It is not the kind of 'energy' we are accustomed to dealing with in mundane engineering calculations.
If Newton knew what we know now would he have added another term to his gravitation equation that accounted for the expansion of the universe?
Actually he may have done something very like that. In 'The Measure of the Universe' John D North says Newton does at one point mention something which is very much like a cosmological constant. Of course Newton didn't know about accelerated expansion, he wanted to get a static universe which doesn't collapse under gravity - which is the same reason why Einstein introduced the cosmological constant.
Related to Accelerated expansion without Dark Energy?
What is accelerated expansion without Dark Energy?
Accelerated expansion without Dark Energy is a phenomenon in cosmology where the universe is observed to be expanding at an accelerating rate without the need for a mysterious force known as Dark Energy. This is in contrast to the widely accepted model of the universe which includes Dark Energy as a necessary component to explain the observed expansion.
How is this possible?
There are various theories and models that attempt to explain accelerated expansion without Dark Energy. One of the most widely accepted theories is the Modified Newtonian Dynamics (MOND) theory which proposes a modification of the laws of gravity at large scales to explain the observed acceleration. Another theory is the Inhomogeneous Cosmology which suggests that the universe is not homogeneous on large scales and this inhomogeneity can account for the observed acceleration.
What evidence supports this idea?
One of the key pieces of evidence for accelerated expansion without Dark Energy is the observation of the Hubble diagram of Type Ia supernovae. This diagram shows a deviation from the expected relationship between distance and redshift, which is consistent with an accelerating expansion. Additionally, observations of the cosmic microwave background radiation and large scale structures of the universe also support this idea.
Why is this important?
The concept of accelerated expansion without Dark Energy is important because it challenges our current understanding of the universe and could potentially lead to a better understanding of the fundamental laws of physics. It also has implications for the future of the universe and the fate of our own galaxy.
What are the limitations of this idea?
While there is evidence supporting accelerated expansion without Dark Energy, it is still a highly debated topic and there are limitations to the theories and models proposed. For example, the MOND theory has difficulty explaining the observed acceleration on very large scales. Additionally, the concept of inhomogeneous cosmology is still in its early stages and requires further testing and evidence.
