- #1
tickle_monste
- 69
- 1
What does it mean physically that the sign on the time component is opposite those of the spatial components of the Minkowski metric?
If you don't like minus signs, you can rearrange the equation so it contains none. This doesn't change the meaning of the formula, but maybe the geometrical interpretation.tickle_monste said:What does it mean physically that the sign on the time component is opposite those of the spatial components of the Minkowski metric?
The problem is, that differential equation doesn't actually define a coordinate τ.A.T. said:If you don't like minus signs, you can rearrange the equation so it contains none. This doesn't change the meaning of the formula, but maybe the geometrical interpretation.
Different signs of the time and space components mean that coordinate time is not a dimension just like the space dimensions but a bit different. If you don't like "special dimensions" you can regard proper time [tex]\tau[/tex] as the temporal dimension, and the coordinate time [tex]t[/tex] as the space-time interval. Then you have no minus signs:
[tex]dt^2=d\tau^2+dx^2+dy^2+dz^2[/tex]
But this is not Minkowski space time anymore.
I think you demand a 1:1 mapping between [tex](x,t)[/tex] and [tex](X,T)[/tex] here. But there is no such corespndence between [tex](x,t)[/tex] and [tex](x,\tau)[/tex]. An event in Minkowski space-time, doesn't have a corresponding single point in space-propertime. In Minkowski space-time you see that two objects meet at [tex](x,t)[/tex] when their worldlines cross there. In space-propertime[tex](x,\tau)[/tex] you see they meet if they are at the same [tex](x)[/tex] (but eventually different [tex](\tau)[/tex]) after traversing worldlines of the same length:DrGreg said:[tex]t=\sqrt{T^2 + X^2}[/tex]
[tex]x = X[/tex]
Fair enough, but that does mean that "space-propertime" is a very limited concept and pretty difficult to grasp. You can plot a single worldline in space-propertime, but an isolated "point", not lying on any worldline, has no meaning, and if you plot more than one worldline on the same graph it's going to get pretty confusing, as the intersection of two lines has no physical significance, and a single event in spacetime could be mapped to multiple distinct points in space-propertime on different worldlines.A.T. said:I think you demand a 1:1 mapping between [tex](x,t)[/tex] and [tex](X,T)[/tex] here. But there is no such correspondence between [tex](x,t)[/tex] and [tex](x,\tau)[/tex]. An event in Minkowski space-time, doesn't have a corresponding single point in space-propertime. In Minkowski space-time you see that two objects meet at [tex](x,t)[/tex] when their worldlines cross there. In space-propertime[tex](x,\tau)[/tex] you see they meet if they are at the same [tex](x)[/tex] (but eventually different [tex](\tau)[/tex]) after traversing worldlines of the same length:
[tex]dt=\int \sqrt{dx^2 + d\tau^2}[/tex]
A.T. said:...
It is actually just like normal Euclidian space with dimensions of the same kind, where everything 'moves' at the same rate. For layman it is not more difficult to grasp, than the pseudo-Euclidian Minkowski space-time. I see it as complimentary tool.DrGreg said:Fair enough, but that does mean that "space-propertime" is a very limited concept and pretty difficult to grasp.
It depends what you want to show. You can visualize different propertimes for two worldlines very well directly in a space-propertime graph. Like the usual twins for example. And you still see the coordiante time in the diagram, as the length of the world lines.DrGreg said:You can plot a single worldline in space-propertime, but an isolated "point", not lying on any worldline, has no meaning, and if you plot more than one worldline on the same graph it's going to get pretty confusing,
Just like in a purely spatial graph, where the intersection of two paths doesn't imply a meeting point. That was exactly the point, that propertime is just like a 4-th space dimension.DrGreg said:as the intersection of two lines has no physical significance,
If you mean two different frames of reference observing the same object: noPhrak said:OK, but does this hold true?
[tex]d\tau^2+dx^2+dy^2+dz^2 = d\tau'^2+dx'^2+dy'^2+dz'^2[/tex]
The Minkowski metric is a mathematical tool used in the study of spacetime, which combines the concepts of space and time into a single four-dimensional continuum. It is named after the physicist Hermann Minkowski and is a fundamental concept in Einstein's theory of relativity.
Negative time is incorporated into the Minkowski metric through the use of imaginary numbers. In the Minkowski metric, time is considered to be a fourth dimension, and the use of imaginary numbers allows for the concept of negative time to be included in calculations.
The implications of negative time in the Minkowski metric are still being studied and debated. Some theories suggest that it could lead to the possibility of time travel, while others propose alternative explanations for the use of negative time in the metric.
The Minkowski metric is used in various areas of physics, including special relativity, general relativity, and quantum field theory. It is a crucial tool for calculating the effects of time and space on particles and objects.
The concept of negative time in the Minkowski metric is still a topic of debate and research in the scientific community. While some theories and experiments support its existence, others propose alternative explanations for the use of imaginary numbers in the metric. Further research and experimentation are needed to fully understand the implications of negative time in the Minkowski metric.
