Transformations in vector space
Active transformations involve changing the vectors while keeping the operators unchanged, whereas passive transformations change the operator components while keeping the vectors fixed. The discussion clarifies that in active transformations, although vectors change, the basis remains the same, which means the matrix components of operators do not change. Both transformations ultimately yield equivalent results in quantum mechanics, as they affect the expectation values in the same way. The conversation also highlights the distinction between the Schrödinger and Heisenberg pictures, emphasizing that the choice of perspective does not necessitate mentioning the basis. Understanding these concepts is crucial for progressing in quantum mechanics.
Mr confusion
dear all,we know that active transformation refers to action of changing vectors keeping the operators unchanged whereas passive transformation refers to change of operator components keeping vectors unchanged.
what i cannot understand(i am just starting quantum mechanics)is in the former if we introduce change in vectors, then the basis vectors also get changed. so the matrix component of the operators will also change! how can they remain unchanged.??:cry:
thanks.
Say, we use the standard Cartesian basis. If we rotate a vector (0,2) to a vector (2,0) does the basis change? No. The basis is still (1,0) and (0,1) i.e. (2,0)=2(1,0)+0(0,1)
Let V be a vector space over \mathbb F (either the complex numbers or the real numbers). For each ordered basis E=(\vec e_1,\dots,\vec e_n)[/itex], we define a function<br /> <br /> f_E:V\rightarrow\mathbb F^n<br /> <br /> by<br /> <br /> f(\vec x)=\begin{pmatrix}x_1\\ \vdots\\ x_n\end{pmatrix}<br /> <br /> where the x_i are defined by<br /> <br /> \vec x=\sum_i x_i\vec e_i<br /> <br /> The map E\mapsto f_E is clearly bijective, so it identifies functions of this type with ordered bases.<br /> <br /> The group of invertible linear operators from V into V is called GL(V). There&#039;s an obvious <a href="http://en.wikipedia.org/wiki/Group_action#Definition" target="_blank" class="link link--external" rel="nofollow ugc noopener">left action</a> of GL(V) on V defined by<br /> <br /> (A,\vec x)\mapsto A\vec x<br /> <br /> and a slightly less obvious right action of GL(V) on the set of ordered bases defined by<br /> <br /> (f_E,A)\mapsto f_E\circ A<br /> <br /> The former is sometimes called an &quot;active&quot; transformation of V, and the latter is sometimes called a &quot;passive&quot; transformation of V. (Note that a passive transformation of V isn&#039;t really a transformation of V at all).
Fredrik said:
The former is sometimes called an "active" transformation of V, and the latter is sometimes called a "passive" transformation of V. (Note that a passive transformation of V isn't really a transformation of V at all).
How are the two transformations equivalent then? Take the expectation value of the operator X on the vector |v> after it has been transformed by A: <v|A-1 X A|v>. According to the passive transformation, |v> doesn't change under the action of A, so the expectation value is <v|X|v>. All the passive transformation seems to do is to change the coordinate labels.
thanks to all of u for helping me.
truecrimson, i think i am having a wrong concept. i am thinking that active transformation is an act of transforming all vectors,including the basis vectors. can you help me here?
frederick, i am really not an expert, i could not make out what are in those black boxes?
that is why i cannot gather what you have said.:frown:
\vec y=A\vec x
y_i=(Ax)_i=\sum_j A_{ij}x_j
\vec y=\sum_i y_i \vec e_i=\sum_i\sum_j A_{ij}x_j \vec e_i=\sum_j x_j\left(\sum_i A_{ij}\vec e_i\right)=\sum_j x_j \vec e_j{}&#039;
where I have defined
\vec e_j{}&#039;=\sum_i A_{ij}\vec e_i
The thing on the left is \sum_i x_i\vec e_i with the components changed, and the thing on the right is \sum_i x_i\vec e_i with the basis vectors changed. Both changes are induced by A in a natural way.
I don't know what you're doing here. If A|v>=|v>, A is the identity operator.
What black boxes? :confused:
I suppose we're talking about Schrodinger picture and Heisenberg picture.
Imagine you've a quantum state vector.
1. Usually we think of the state vector evolving in time by a unitary transformation U.
|x\rangle \to U|x\rangle
2. We're free to choose any basis to represent the vector as a unique linear combination of basis vectors.
That is an active transformation or Schrodinger picture.
But we can also fix the vector and allow basis vectors to evolve in time which gives an equivalent description. This is a passive transformation or Heisenberg picture. For example, if the vector rotates clockwise in Schrodinger picture, you want the basis to rotate counterclockwise in Heisenberg picture. In doing so, we can't use operators written in the old basis anymore. Since an operator acts on the right, we have to transform an operator A\to U^{\dagger} AU.
So the expectation value stays the same.
\langle x|U^{\dagger} AU|x\rangle.
When we talk about the Schrödinger picture vs. the Heisenberg picture, there's no need to mention bases at all.
Fredrik said:
\vec y=A\vec x
I got it now. An active transformation clearly changes the vector by changing the components but keeping the same basis, i.e., action under GL(V). A passive transformation implicitly changes the vector by changing the basis, as the definition
<br /> (f_E,A)\mapsto f_E\circ A<br /> says that f changes and since there is a 1-1 map between basis vectors E and f that means E changes.
The two transformations transform the vector in the same way, of course, it's just that one does so obviously and the other implicitly.
I had always thought an active transformation was a change on vectors, and a passive transformation was a change on operators. That is wrong as both change vectors. However, in the passive transformation, because the basis are changed, the operators have to be converted to another language via similarity transformation (what truecrimson said).
thanks for explaining this and clearing things up!
I see. Thanks.
i am really very sorry, frederik. it so happened that i was using an older browser version and so all the math part appeared black.i have changed it and now see them clearly.:smile:
however, please tell me what is meant by "for Heisenberg or scroedinger pics we do not need to mention a basis"
Sure. In the Schrödinger picture, state vectors are time dependent and operators are time independent. The time dependence is described by
|\psi;t\rangle=e^{-iHt}|\psi;0\rangle
Let's define U(t)=e^{-iHt} and |\psi\rangle=|\psi;0\rangle[/tex], and write the above as<br /> <br /> |\psi;t\rangle=U(t)|\psi\rangle<br /> <br /> The expectation value of an operator A in this state is<br /> <br /> \langle A\rangle_{|\psi;t\rangle}=\langle\psi;t|A|\psi;t\rangle=\langle\psi|U(t)^\dagger AU(t)|\psi\rangle=\langle A(t)\rangle_{|\psi\rangle}<br /> <br /> where I have defined<br /> <br /> A(t)=U(t)^\dagger AU(t)<br /> <br /> As you can see, the expectation value of A in the state |\psi;t\rangle is equal to the expectation value of A(t) in the state |\psi\rangle. This is why we have the option to think of the states as time-independent and the operators as time-dependent. This option is called the Heisenberg picture.<br /> <br /> As I said, no need to involve bases. The difference between the Schrödinger picture and the Heisenberg picture is a matter of where you put the parentheses:<br /> <br /> \Big(\langle\psi|U(t)^\dagger\Big) A\Big(U(t)|\psi\rangle\Big)=\langle\psi|\Big(U(t)^\dagger AU(t)\Big)|\psi\rangle
thanks. this is really a bliss to be among so many quantum experts while taking this course. this is removing the fears i had earlier that i will not understand this course at all.:redface:
<br /> fredrik, my course is in quantum mech is in full run. looking at this again, i have something to ask you. hope you will help me again.<br /> as far as i have understood, in scroedinger picture state vectors undergo a rotation (as the operator ie. the propagator is unitary) in hilbert space. <br /> but in Heisenberg picture, it is the operators change with time while state vector remains fixed.you have beautifully showed how the expectation value of observable remains the same i both pictures.<br /> but i was wondering whether time dependent scroedinger equation will remain valid in hiesenberg picture? because the state vectors are now fixed and their time derivatives will be zero! then how will i progress with my statistical calculations of observables in such a picture?<br /> i hope my question is understandable. i have built up my english quite recently.
truecrimson, will you please confirm me about this- i think i need to rotate the basis clockwise too, because then only the the state vector will appear static.if i move basis counterclock, then it seems to me that the state vector will approach me with double the speed. or am i wrong in visualisasion?
This is the first time I've heard of "active" and "passive" transformations, though Wikipedia has done a quick job of letting me know that these are calculationally equivalent changes where a state vector evolves over time, or equivalently a basis evolves over time.
I think the issue has been clouded by too much quantum mechanical machinery.
In the most comprehensible case one should simply consider vector rotations in Euclidian two-space. Rotating a vector to the left is quantitatively equivalent to rotating the coordinate system the right. These are synonymous with the Schrödinger and Heisenberg approach respectively, no?
it seems to me you are correct . but i am getting confused!
if i rotate the basis to right, ... then yes...it is equivalent to vector rotated to left.
but my book says in Heisenberg representation state vectors remain frozen. now if i rotate a basis to right at ang speed w while the vector was rotating originally to the left at w, then i will see the vector rotate with angular velocity 2w?
however i am sure the discussion is not clouded at all. my book has stressed very much on these transformations before describing scroedinger picture. and after all , it is a quantum mechanics text.:smile:
After Fredrik replied that we don't need to mention about basis at all in Schrodinger vs Heisenberg picture, I found a passage in Peres that confirms that both Schrodinger and Heisenberg picture are active transformations. My second reply is partly wrong. Sorry about that.
So your first question is about Schrodinger (change in states) vs Heisenberg picture (change in operators), not active vs passive transformation.
Edit: What is the book you're using? At first, I assumed (wrongly) that the two pictures and the two transformations are synonymous because I searched through Sakurai and found only one place where he mentions passive transformation in the context of usual rotations in vector spaces. And he discusses Schrodinger vs Heisenberg pictures before that, if I recall correctly.
truecrimson, you have truly killed me down!:biggrin:
all along my course , i am sharing the idea that in Heisenberg picture, state vectors remain frozen and the operators change. how can it be an active transformation? how?
http://electron6.phys.utk.edu/qm1/modules/m5/pictures.htm
please note:our text is a material given by our professor.he accumulates and compiles it himself. but he has referred us W. GREINER AND F.SCHWABL, i think he mainly prepares it from these two books.
Seeing that the explanation on the webpage is more or less the same as mine, I think it's a valid reasoning. The confusion probably just arises from various usages of the words "active" and "passive" transformations by different authors. Sometimes a passive transformation means the inverse of the correspending active transformation so it gives UAU^{\dagger} instead of U^{\dagger}AU.
IMO, there's nothing to worry about.
just clarify me here a bit, please.
i know i have disturbed you a lot.
but...i am slow in understanding things and always mess things up.
No! Not at all!
State vectors remaining frozen means that there is no vector "rotating originally to the left."
thanks. that cheered me up a bit.
i meant, let's say, what is time dependent scroedinger equation telling us? if i construct the propagator with the help of energy basis i will see that the propagator can be expressioned via an exponential of a hermitian matrix(hamiltonian) suggestionizing that it is a unitary matrix. this means the unitary propagator in effect rotates the ket to another one in hilbert formulasion.
this is active transformasion.
say now i want to express that rotation by changing the basis and keeping the ket fixed. then will i not have to rotate the basis by same angular velocity as the propagator rotated the ket and IN THE SAME DIRECSION?
You use a different equation. We have
and
U(t)=e^{-iHt}
(in units such that \hbar=1), so
A&#039;(t)=U&#039;(t)^\dagger AU(t)+U(t)^\dagger AU&#039;(t)=iHU(t)^\dagger AU(t)+U(t)^\dagger A(-iH)U(t)=i[H,A(t)]
The Schrödinger picture describes the time evolution of the state vector as a curve in the Hilbert space. In the Heisenberg picture, we have a single state vector and a curve in the space of unitary operators instead. Your analogy works. The Schrödinger picture is like drawing a segment of a circle on a piece of paper by moving the pen, and the Heisenberg picture is like drawing the same curve by rotating the paper instead.
I've been saying that there's no need to mention bases, and there isn't. But if U is a unitary operator and \{x_i\} is a basis, then \{Ux_i\} is another basis, so a curve in the space of unitary operators certainly defines a curve in the space of bases as well. I wouldn't say that the transformation A\mapsto U(t)^\dagger AU(t) is a passive transformation, but it certainly can be used to define a passive transformation \{x_i\}\mapsto\{U(t)x_i\}.
fredrik, i wish i had you as my tutor.
but your last line appears self contradicsionising (red mark tells me i haven't got it right, still never mind. i mean it is saying one thing and revolting the same thing). please can you explain this?
and that last query i had about basis rotations? post#23
but that commutator equation u showed in Heisenberg is reminding me of a similar relation in poisson brackets in classical mechanics, except the 'i'. i truly love these parallels. they help in reminding things.
A passive transformation is supposed to take a basis to a basis, right? But the function A\mapsto U(t)^\dagger AU(t) takes an operator to an operator. So it's acting on the wrong type of object.
The components of a vector x in a basis \{e_i\} are the x_i defined by x=x_i e_i. The i component of Ux in the same basis is U_{ij}x_j. This follows from Ux=U(x_je_j)=x_jUe_j=x_j(Ue_j)_i e_i=x_jU_{ij}e_i. The components of x in the basis e_i&#039;=Ue_i are the x_i&#039; defined by x=x_i&#039;e_i&#039;, and we have x=x_j&#039;e_j&#039;=x_j&#039;Ue_j=x_j&#039;(Ue_j)_i e_i=x_j&#039;U_{ij}e_i. So we have x_i=U_{ij}x_j&#039;, and therefore U_{ik}^*x_i=U_{ik}^*U_{ij}x_j&#039;=\delta_{kj}x_j&#039;=x_k&#039;.
In other words, when we apply the unitary transformation U to the vector x, its components changes according to
x_i\rightarrow U_{ij}x_j
and when we apply it to the basis vectors, the components change according to
x_i\rightarrow x_i&#039;=U_{ji}^*x_j
So yes, you would have to apply U^\dagger to the basis vectors to get the components to change the same way as when you apply U to the vector. (This argument probably needs some modifications to work when we're dealing with an infinite number of dimensions).
See this post for a reminder about the connection between linear operators and matrices. (This is probably the most important detail from linear algebra, so you should make sure that you understand it perfectly).
  • · Replies 61 ·
