- #1
- 10,877
- 423
##\newcommand{\dmu}{\ \mathrm{d}\mu}##
I'm using Friedman to try to learn some integration theory. I got the impression that all books start by defining integrals of simple functions in the same way, and then there are several different ways to generalize the definition to more interesting functions. This book's approach is based on the idea that if there's a sequence ##\langle f_n\rangle## of simple functions such that ##f_n\to f## in some sense, then it might make sense to define
$$\int f\dmu=\lim_n\int f_n\dmu.$$ This idea is so simple that I got quite fond of it at first, but things soon get complicated. I'm wondering if other approaches are easier, or if I'm just wrong about how hard this one is.
The idea described above only makes sense if the precise meaning of "##f_n\to f##" is such that the limit on the right always exists, and is independent of the sequence used. The book chooses that meaning by defining f to be integrable if there's a sequence ##\langle f_n\rangle_{n=1}^\infty## that's Cauchy in the mean, and has the property that ##f_n\to f## almost everywhere. It's easy to show that "Cauchy in the mean" implies that the limit exists. The hard part is to prove that it's independent of the sequence. These are some of the statements we'll have to prove to accomplish that, if we follow the book's path: (I'm not going to be very careful with the details in these statements).
So is this as easy as it gets, or can the theory be made simpler?
- If ##\langle f_n\rangle## is Cauchy in the mean, ##\lim_n\int_E f_n\dmu## exists for all E.
- The function ##\lambda## defined by ##\lambda(E)=\lim_n\int_E f_n\dmu## for all E is countably additive.
- Now suppose that ##\langle f_n\rangle## and ##\langle g_n\rangle## are two Cauchy sequences in the mean that both converge almost everywhere to f. If E is σ-finite, then ##\lim_n\int_E f_n\dmu=\lim_n\int_E g_n\dmu## for all E. (This one uses the result that these sequences also converge to f in measure. I'm putting that on a separate list).
- The previous result implies that ##\lim_n\int f_n\dmu=\lim_n\int g_n\dmu##.
- "Cauchy in the mean" implies "Cauchy in measure".
- A sequence of measurable functions that's Cauchy in measure has a subsequence that converges almost uniformly.
- If ##f_n\to f## almost uniformly, then ##f_n\to f## in measure.
- Corollary of the previous two: A sequence of measurable functions that's Cauchy in measure converges in measure. (When we get to this point, we know that if f is integrable and ##\langle f_n\rangle## is a Cauchy sequence in the mean that converges to f almost everywhere, there's a function g such that ##f_n\to g## in measure, but it doesn't seem obvious that f=g a.e. The next theorem should take care of that).
- If ##f_n\to f## almost uniformly, then ##f_n\to f## almost everywhere.
