Photon interaction during refraction
In summary, in the discussion of refraction and the exchange of energy between photons and matter, there are two main interpretations: one sees photons as wave packets and the Planck energy as the characteristic energy of emission and detection, while the other sees photons as indivisible particles and the Planck energy as a true atom of energy. In the former interpretation, refraction can be explained through perturbation theory, while in the latter, a diagonalization of the interaction Hamiltonian is necessary to understand refraction. Both interpretations involve the exchange of energy between photons and matter, but the exact mechanisms may differ.
harrylin
3,875
93
This is a follow-up of the following thread on refraction:
https://www.physicsforums.com/showthread.php?t=576212&highlight=photon
In a nutshell, an optical photon that traverses a solid dielectric extends over many atoms. While the photon traverses the dielectric, it continuously transmits some of its energy into a forced oscillation of charges which return the energy by emitting secondary waves (perhaps better to say wavelets) with a slight, progressive phase delay. The result is a delayed photon.
However, in post #19 the following question came up:
Antiphon said:
How do you take some energy from a photon?
Indeed, it is no conceptual problem for those of us who regard a photon as a kind of wave packet, and the Planck energy as the characteristic energy of emission and detection.
However, it may be a problem for those who regard a photon as an indivisible particle, and/or the Planck energy as a true atom of energy, independent of observation. With such an interpretation, how does one explain refraction?
At first it should be stated that bare photons are never eigenstates of the light field in matter.
Now, the question is how one treats the difference. In the weak coupling regime one can still use perturbation theory up to second order which gives a refractive index like
[tex]n\approx 1 +\left|\sum_z \frac{\langle i|H_D|z\rangle \langle z|H_D|i\rangle}{E_z-E_i-\hbar \omega}\right|^2[/tex].
It should be emphasized that the absorption and emission processes involved lead to virtual states, not real ones. That treatment of course must fail on resonance, that means when the denominator approaches zero.
In that case, the light field and the material excitation behave light coupled harmonical oscillators in the simplest case which can exchange energy effectively, so that spontaneous emission can become reversible and you now have real absorption and emission instead of virtual ones. In that case perturbation theory must be replaced by exact bookkeeping of these interactions. What one typically does is a diagonalization of the interaction Hamiltonian via a Bogoliubov transform which leads to new eigenstates. These are now partially photon-like and partially excitation-like and typically called polaritons.
The energy is in both cases taken from the photonic mode in the time-average only which is no problem for any model, I suppose.
Thanks, I guess that one could see the photon as a particle that exchanges energy with the medium. But I'm afraid that this doesn't really address the question of Antiphon, who holds that 'the photons are absorbed and re-emitted by the phonons'.
Also in your description, at any time only some of the photon's energy is exchanged, and with a great number of electrons - thus I think that also as your picture it, less than a quantum of energy is exchanged at any time, and the maximum additional kinetic energy of each oscillating electron is again much smaller than that. Is that correct?
The point of view that photons are generally being absorbed and re-emitted by photons is plain wrong and leads to inconsistencies - unless of course absorption to virtual states is implied. The FAQ of these forums already has an entry on that: https://www.physicsforums.com/showpost.php?p=899393&postcount=1 where it is written that "So the lattice does not absorb this photon and it is re-emitted but with a very slight delay." Although I must admit that the term re-emitted is a bit off as it is explicitly stated that absorption does not happen.
Real absorption and reemission processes happen way too slow to explain refraction and should also randomize the direction in which light is traveling.
On very short timescales as implied by uncertainty the "total" photon energy can go to other modes. However, the energy of the photon is of course not too well defined on these timescales and as transitions to these modes are not allowed due to energy mismatch the energy will stay in the photon mode in the long run. Averaging over timescales longer than the typical timescales on which uncertainty is important then gives you an effective portion of energy that goes into these transitions on average, but that does not mean that at some instant the photon loses only some percentage of its energy.
Related to Photon interaction during refraction
1. What is refraction and how does it affect photon interaction?
Refraction is the bending of light as it passes through a medium with a different density. This change in density alters the speed of the light, causing it to change direction. This can affect photon interaction by changing the path of the photons and potentially altering their energy levels.
2. How do photons interact with matter during refraction?
When photons pass through a medium during refraction, they can interact with the electrons in the material. This interaction can cause the photons to be absorbed and re-emitted, or it can change the direction of the photons. The type and strength of the interaction depends on the properties of the material and the energy of the photons.
3. Can refraction affect the color of light?
Yes, refraction can affect the color of light. This is because different colors of light have different wavelengths and speeds, so they are affected differently by the change in density during refraction. This is why a prism can split white light into its component colors.
4. How does the angle of incidence affect photon interaction during refraction?
The angle of incidence, or the angle at which the light enters the medium, can affect the amount of bending and interaction that occurs. The greater the angle of incidence, the greater the change in direction and potential interaction with matter. This is why objects may appear distorted when viewed through a glass of water at an angle.
5. Can refraction be used to manipulate photon interactions for practical applications?
Yes, refraction can be used for a variety of practical applications, such as lenses in glasses and cameras, fiber optics for communication, and even in medical imaging techniques. By understanding how photons interact during refraction, scientists and engineers can design and create technologies that make use of these interactions for various purposes.
  • Quantum Physics
11K
  • Quantum Physics
