Attempts to make the Born rule emerge explicitly from outcome counting
In summary, we discussed attempts to make the Born rule "emerge" explicitly from outcome counting, including Graham's 1973 paper, Robin Hanson's "mangled worlds" paper, Michael Weissman's paper, and David's work-in-progress. We compared and contrasted these schemes based on factors such as the underlying theory (linear or nonlinear), any "ontological" concerns raised by the modification, experimental tests, and explanations for the underlying postulates. We also discussed the possibility of modifying these schemes to yield a different exponent in the probability calculation.
straycat
184
Attempts to make the Born rule "emerge" explicitly from outcome counting
I would like to compare and contrast the various attempts to date to reconstruct the MWI so that it: 1) assumes outcome counting instead of the Born rule, but also 2) makes correct experimental predictions. This is an offshoot of the discussions:
"my paper on the Born rule..."
https://www.physicsforums.com/showthread.php?t=95585
and
"Are World Counts Incoherent?"
https://www.physicsforums.com/showthread.php?t=101339
These two threads discuss arguments for and against outcome counting (= the APP); on this thread, we can just assume the APP and take it from there.
As far as I know, the only serious attempts to do this explicitly are Graham's 1973 paper, Robin Hanson's "mangled worlds" paper, Michael Weissman's paper, and my own work-in-progress. (Many-minds might also be thrown into the mix, but I think not ...) Since Mike and Robin are both here, we should have a good discussion!
Here are some points of comparison that occur to me:
1) Is the underlying theory linear or nonlinear, and which would we expect/prefer?
2) Are there any "ontological" concerns raised by the modification?
3) Are there any experimental tests?
4) How do we explain the underlying postulates?
5) Does it involve pruning or extra branching?
6) Are the number of branches (allowed to be) finite or infinite? Discrete or continuous?
If anyone knows of any other attempts, or can think of other ways to compare/contrast these schemes, then post!
David
In a sense, Robin's scheme employs pruning, if "mangling" and "destroying" are equated with pruning. I am not sure I understand, though, what mangling means exactly. If mangled worlds continue to exist, but they have been changed so that we can ignore them by (say) an anthropic principle argument, then we have not actually "pruned" branches in the sense that they "no longer exist from a God's eye view." This is good, b/c I'm not sure what that would mean or how that could occur. So I suppose I would say that mangled worlds does not technically prune, but it does employ a "pruning-equivalent."
In my scheme, I do not employ pruning or branching. But again, I do employ what might be considered to be a "pruning-equivalent" in the first part of the tree diagram of Fig 1 E. Basically, the idea is that a particular chunk of the tree diagram can be ignored in the approximation because it is simply improbable that its branches will ever be reached. So the basic mechanism behind my pruning equivalent is essentially 1) the APP itself, plus 2) the micro-structure of the tree diagram.
Mike's involves "anti-pruning," ie extra branching, as he states in message #71 of Patrick's thread. I still have more to read of his paper to understand how this works though! :biggrin:
David
alternate scheme for alternate PP?
Here's a question that is related to post 79 in Patrick's thread "my paper on the Born rule."
Let's suppose that ordinary QM were described by the rule: probability = |a|^n, instead of the Born rule: probability = |a|^2. Would it be possible to modify any of the schemes that are the topic of discussion in this thread accordingly? And what would be the underlying "explanation?"
In my scheme, the reason that 2 shows up in the exponent is that there are assumed to be two "special" paths from source to detector associated with the particle. So to change the exponent from 2 to n, we could simply postulate that there are n "special" paths. If we have n=1, then the one "special" path could be thought of as "the real path that the particle takes through spacetime." To get n=2, we postulate that from the "god's eye view" perspective of the particle through 4-d spacetime, the particle has the topology of a torus; ie, it looks like a big loop of string, which traverses the source as well as the detector, and so the two special paths correspond to the two ways around the loop.
Hopefully Robin and Mike can comment on how their schemes could be modified to yield |a|^n instead of |a|^2. :biggrin:
David
linear or nonlinear?
The introduction to Mike's paper contains an argument that we should expect our outcome-counting schemes to be characterized by nonlinearity. So do they?
Mike's scheme is nonlinear, as it says in the abstract.
After discussion with Mike, I've come to think that my scheme is fundamentally nonlinear as well. This is because the evolution of the observer through time is governed by general relativistic laws, and Einstein's equation is nonlinear. This is a quick and dirty argument, though -- hasn't really been vetted thoroughly yet.
Robin, is your scheme linear? You seem to imply this in your introduction with the statement: "I suggest how one can derive the prediction that observed long run measurement frequencies are given by the Born rule, while still insisting that only the standard linear evolution rule always and exactly determines evolution ..." If so, does this conflict with Mike's argument that the underlying scheme need be nonlinear? Or have I misunderstood something?
David
In my sheme n depends on where the mangling cutoff is in the distribution of worlds. If the cutoff is at the median world, n = 0, while if it is at the median measure, n=2. Other positions yeild other n. But the cutoff isn't intended to be a free parameter - it is expected to be derived from the rest of quantum mechanics.
FAQ: Attempts to make the Born rule emerge explicitly from outcome counting
What is the Born rule and why is it important in quantum mechanics?
The Born rule, also known as the Born interpretation, is a fundamental principle in quantum mechanics that relates the mathematical description of a quantum system to the probabilities of measurement outcomes. It states that the square of the amplitude of a wave function at a particular point is proportional to the probability of observing that point as the outcome of a measurement. This rule is important because it allows us to make predictions about the behavior of quantum systems, which are inherently probabilistic.
How is the Born rule currently used in quantum mechanics?
The Born rule is currently used as a postulate in quantum mechanics, meaning it is assumed to be true and is used to make predictions about the behavior of quantum systems. It is not derived from other principles or equations, but has been confirmed through numerous experiments and is considered a foundational principle of quantum mechanics.
What do you mean by "outcome counting" in the context of the Born rule?
In the context of the Born rule, outcome counting refers to the process of counting the number of possible outcomes of a measurement and using that information to calculate the probability of each outcome occurring. This is a key component of the Born rule, as it allows us to connect the mathematical description of a quantum system to the physical measurements we can make.
Can the Born rule be derived from other principles or equations?
There have been many attempts to derive the Born rule from other principles or equations in order to provide a more fundamental understanding of its origins. However, these attempts have not yet been successful and the Born rule remains a postulate in quantum mechanics. Some theories, such as the many-worlds interpretation, attempt to explain the Born rule as a consequence of the structure of the multiverse, but this is still a subject of debate among scientists.
What are some current theories or approaches attempting to explicitly derive the Born rule from outcome counting?
One current approach is the decision-theoretic approach, which uses decision theory to connect the mathematical formalism of quantum mechanics to the probabilities of measurement outcomes. Other approaches include the information-theoretic approach, which relates the Born rule to the amount of information gained from a measurement, and the thermodynamic approach, which links the Born rule to the principles of thermodynamics. However, none of these approaches have been universally accepted as a successful derivation of the Born rule.
