matness
- 90
Can anybody give me an explanation about non coordinate bases and its importance?
matness said:Can anybody give me an explanation about non coordinate bases and its importance?
Such an orthonormal basis can be defined in general by specifying an array of n one-forms (aka contravariant tensors) that map the vectors of the tangent space to n scalars.
Ratzinger said:Weren't one-forms covariant tensors?
The theory itself allows the possibility for 4-manifolds other than R4. Indeed, there are interesting solutions that don't have R4 as the base manifold. An interesting related question is "How can we determine the topology of spacetime?"bchui said:In General Relativity, the manifold [tex]M[/tex] is 4-dimensional, so why don;t we simply take [tex]M=\Re^4[/tex] and use much simplier symbols in the differential geometry?![]()
In General Relativity, the manifold is 4-dimensional, so why don;t we simply take and use much simplier symbols in the differential geometry?
bchui said:Hold on, should Schwarzschild be [tex]S^3\times\Re [/tex] instead, for [tex](r,\theta,\varphi)[/tex] is 3-dimensional spherical plus [tex]t\in\Re[/tex]?
bchui said:Schwarzschild is a metric on the manifold
[tex]M=S^2\times {\bf R}^+\times {\bf R}[/tex], for we have [tex]r>0[/tex] and [tex]t\in {\bf R}[/tex]
So, [tex]M[/tex] is actually the domain of the parameter values, not the "actual space" we want to describe? For, the "actual space" we want to describe is [tex]{\bf R}^4[/tex]?
Does that applies to Robertson-Walker metric and many others?
A noncoordinate basis is a set of vectors that do not have a fixed position in space and are not aligned with a coordinate system. They are usually defined by their direction and magnitude, rather than their specific location.
Noncoordinate bases are important because they allow us to describe and analyze physical phenomena that cannot be easily represented using a fixed coordinate system. They are particularly useful in fields such as relativity and quantum mechanics, where the object of study may not have a well-defined position or may exist in multiple locations simultaneously.
The main difference between noncoordinate and coordinate bases is that coordinate bases are fixed and aligned with a coordinate system, while noncoordinate bases are not. This means that the components of vectors in a noncoordinate basis can change depending on the orientation and position of the basis, while the components of vectors in a coordinate basis are constant.
Examples of noncoordinate bases include the spherical and cylindrical coordinate systems, which are commonly used to describe physical phenomena with rotational symmetry. Other examples include the spin basis used in quantum mechanics, and the tangent space basis used in differential geometry.
Noncoordinate bases are used in scientific research to describe and analyze physical phenomena that cannot be easily represented using a fixed coordinate system. They allow scientists to better understand and model complex systems, and are particularly important in fields such as physics, astronomy, and engineering.
