Are Solar Power Satellites the Future of Renewable Energy?
In summary, the Japanese experiment set to launch on January 18 called the Furoshiki experiment will test whether large structures can be constructed in space by having 3 satellites holding the corners of a Furoshiki 20m on each side, and having small robots crawl along and align themselves in order to transmit a signal.
Vast
285
I’ve been wondering for a while now whether there were any projects on the drawing board for Solar Power Satellites, (SPS) and today I came across a Japanese experiment set to launch on January 18, called the Furoshiki experiment. Furoshiki is a Japanese word for a cloth used to wrap up small possession. The experiment will test whether large structures can be constructed in space by having 3 satellites holding the corners of a Furoshiki 20m on each side, and having small robots crawl along and align themselves in order to transmit a signal.
ESA News Release can be found here:
http://www.esa.int/esaCP/SEMHVXVLWFE_index_0.html"
Along with some videos here:
http://www.esa.int/gsp/ACT/power/solar_power_satellites_furoshiki.htm"
And a pdf here:
http://www.esa.int/gsp/ACT/doc/Furoshiki%20IAF04%20Paper%20KayaMankinsSummerer.pdf"
Would anybody know how much solar power could be generated from a SPS? What size would be needed to have any impact at all on our energy needs?
I always thought the problem was how to get the power from "up there" to "down here".
The amount of energy generated will depend upon the specific type of SPS. There are several different possibilities. Unless photovoltaic cells become even more efficient than they are now, I suspect that concentrated sunlight focused on a thermal generator will be the practical way to go.
What problems are you thinking of specifically? My guess would be to first put a satellite into a geosynchronous orbit which would allow it to be stationary over head, and forgive my ignorance, but beam the energy down to a ground station.
Ok, found a little something which describes the process.
http://www.freemars.org/history/sps.html"
While it's theoretically an ideal approach, there are still stumbling blocks regarding beamed power. For one thing, microwaves aren't great at penetrating water. Heavy clouds or rain can interrupt delivery. There's also the necessary size of the receiving array, which is rather sizeable. (It's been suggested that it be elevated with farmland underneath, so that might be a minor problem.) There are probably concerns as well about the effect of a beam upon aircraft systems that happen to get into the path.
One of the biggest obstacles, unfortunately, is political. You know how stupid the general public is when it comes to science. I wouldn't doubt that at least 80% of US citizens would be terrified by the concept of microwaves coming from space and vote out anybody who endorsed it.
Danger said:
While it's theoretically an idea approach, there are still stumbling blocks regarding beamed power. For one thing, microwaves aren't great at penetrating water. Heavy clouds or rain can interrupt delivery.
From the site I linked above, they say the power would be beamed in microwaves at a frequency of 2.45 GHZ which can apparently pass through heavy clouds.
A conventional power plant supplies 1 billion watts, while the SPS they propose would generate 5 billion watts. 10 x 13 kilometers in size is quite sizable, but considering the returns, a project of this size should easily make their money back pretty quickly.
And yet they also say that even at the peak of the beam, the intensity of the microwaves are practically nil. As far as aircraft, I’m not too sure whether it would interfere with instruments, but then just restrict the airspace.
The public are stupid, but unlike things which they have good reason to fear, this is not one of them, and could easily be educated about the misconception.
Well, the mean solar flux at our distance from the sun is 1369 w/m^2. Let's say you could make a parabolic dish and focus solar energy on the Earth and convert it to electricity at 40% efficiency. You'd need 1.8 square km to generate as much energy as a typical nuclear reactor or medium sized conventional plant of 1000 megawatts.
Well, mylar has a mass of 1.3 g/cc. At .1mm thick, that 10x13km collector would have a mass of 160,000 kg and cost roughly $3.7 billion just to launch...
Someone please check my numbers...
I was unaware of that. Good counterpoint.
I wasn't concerned about the cost, actually; it's a matter of where the hell do you put the thing.
I'm not surea about it either, but I suspect that it would interfere with computerized control systems as well as instruments. There's a lot of restricted airspace already, and it's getting worse all of the time. An ocean-based receiver would alleviate the problem.
Just don't try to build it in Kansas.
Russ, I know that you're referring to the solar collector there, and have no idea how to check your numbers. The hugeness that I was referring to is the receiving antenna.
Related to Are Solar Power Satellites the Future of Renewable Energy?
1. What are Solar Power Satellites (SPS) and how do they work?
Solar Power Satellites are satellites that use solar energy to generate electricity and beam it down to Earth using microwaves. SPS consist of solar panels which collect sunlight and convert it into electricity, which is then converted into microwaves and transmitted to receiving stations on Earth.
2. What are the potential benefits of using Solar Power Satellites?
There are several potential benefits of using SPS, including a nearly endless supply of clean and renewable energy, reduced dependence on fossil fuels, and the ability to provide energy to remote or disaster-stricken areas.
3. What are the challenges associated with building and using Solar Power Satellites?
The main challenges include the high cost of building and launching the satellites, the potential risk of damage during launch, and the need for advanced technology to convert and transmit the energy efficiently.
4. How do Solar Power Satellites compare to other renewable energy sources?
Compared to other renewable energy sources like wind and hydro power, SPS have the advantage of being able to provide consistent energy regardless of weather conditions. However, they do come with higher upfront costs and may face technical challenges in their implementation.
5. Are there any potential risks or downsides to using Solar Power Satellites?
While SPS have the potential to provide clean and renewable energy, there are some potential risks to consider, such as the potential impact on birds and other wildlife, as well as the concerns about the long-term effects of microwaves on human health.
  • Astronomy and Astrophysics
