Why is the universe considered to be infinite in size?
In summary: The universe "makes" it own space as it expands it does not expand into anything =) counter intuitive but correct. You may use a sheet of paper as an example but there is nothing outside the sheet of paper . If you finally come to the accommodation , however unreasonable it seems, that there is no outside, you have it .The question on peoples minds is what is it expanding into? The answer is nothing, not really nothing because even nothing is something.. There is no there there, you have to use a Zen mindset to come to grips with it If that happens some of the other weirder concepts of...infinity might make more sense.
deltabourne
72
Infinity is essentially the biggest 'number' there is.. there is nothing greater than infinity, which is why infinity+5=infinity. Now the universe is said to be expanding, meaning it grows in size - if it really was infinity it could not expand at all since it was already at an infinity. It's an inherent contradiction, so is it generally accepted that the universe is infinitely large or it is finite and expanding?
I hope I'm making some sense, I didn't get much sleep last night
Space news on Phys.org
It's not certain but an infinite universe looks to be the best fit for current data and understanding of the cosmos.
Imagine the universe as an infinitely large piece of square paper, when the paper universe expands the squares on the paper get bigger.
Hmm.. seems to make sense, except that what do the squares that get bigger represent? It isn't planets or celestial bodies, since those aren't getting bigger (are they?). However we know they are moving apart from blue shift, but that doesn't necessarily mean the universe is expanding. It's already large enough to have all the planets infinite distances away from each other (since the universe is infinitely large).
meh, I may be talking nonsense/semantics here, but it's just a little quirky idea that was bugging me today
It means that the distance between objects in th euniverse is getting bigger.
Something is redshifted when it moves away from us (compared to blueshifted when it moves towrads us) and yes it does mena that the universe is expanding.
Regions of space.
When we say that the universe expands, we mean that all the galaxies are getting farther away from each other. That can happen whether the universe is finite or infinite. Any two galaxies are always a finite distance from each other, though that distance may increase with time.
Among infinities, isn't it the case that some infinities are larger than others? I remember hearing something along these lines before. Something like the set of reals is a larger infinity than the set of integers.
So we're looking at finite space and saying that finite space is expanding. Overall is the universe getting larger? Or is just the space between things in the universe getting larger?
When we talk about an infinite universe expanding, no new points are being added: the set of points is always the same order of infinity, the cardinality of the reals.
Both. The universe gets larger because the distances between all points in space get larger.
The universe is considered to be infinite because all that exists is contained within it's limits.The fact of differing infinites is a mathematical abstraction based on an understanding of things like set theory and weirder stuff all based on an alphabet of symbols. I.E. There are more numbers between 0 and 1 then between 1 and infinity.
The application when it comes to these symbols and concepts when it comes to reality becomes somewhat stickier. If the universe is infinite how can it be expanding? What is it expanding into? Thats the kicker
The universe "makes" it own space as it expands it does not expand into anything =) counter intuitive but correct. You may use a sheet of paper as an example but there is nothing outside the sheet of paper . If you finally come to the accommodation , however unreasonable it seems, that there is no outside, you have it . The question on peoples minds is what is it expanding into? The answer is nothing, not really nothing because even nothing is something.. There is no there there, you have to use a Zen mindset to come to grips with it If that happens some of the other weirder concepts of QM and even Relitivistic physics becomes less a mind stunner.
We don't actually know whether the universe is infinite. "All that exists" could be contained within the universe, but the universe could still be finite in size.
Well much is not certain, but recent evidance seems to point to omega as ~1 so if correct that means a flat, open , infinite universe dosn't it?
Of course we won't know till the SNAP and Planck probes go up will we?
Excuse my cosmological ignorance. Didn't the universe start out finite? How does something finite become infinite?
Well, that's if Omega is exactly equal to 1. But we can never know if that's true... the universe could be finite, but inflated so much that it's just under 1...
No, not necessarily. If the universe is infinite, then the universe started out infinite. (It's only the finite observable universe that has to start out as a point.)
I don't think anyone can answer that question even though it seems simple on it's face. It has more to do with semantics, language,human cognition,Theosophy and philosophy then science. One concept is that it was not finite as the only existence was included in it's corpus, nothing else existed so to treat it as a point in space is a fallacy, there was no space. The others require the prsupposition of god or other devices to explain them.
Ow... my brain hurts.
What nonsense is this? So every finite element of the universe started out as a point. And to sum all these points an infinite amount of times we get an infinite space. Sounds like 0 times infinity = infinity to me.
Related to Why is the universe considered to be infinite in size?
1. Why do scientists believe the universe is infinite in size?
Scientists believe the universe is infinite in size because of various observations and theories. The expansion of the universe, the lack of observable edge or boundary, and the concept of infinite space in mathematics all support the idea of an infinite universe.
2. Can we ever prove or disprove the infinity of the universe?
At this point in time, we do not have the technology or capability to definitively prove or disprove the infinity of the universe. However, as our understanding of the universe continues to evolve, we may gain more insights and evidence to support or challenge this concept.
3. Is it possible for the universe to have an end or boundary?
Based on current knowledge and theories, it is highly unlikely for the universe to have an end or boundary. The expansion of the universe, coupled with the lack of observable edge or boundary, suggests that the universe is infinite in size.
4. How can we conceptualize or understand the idea of an infinite universe?
The concept of infinity can be difficult to grasp, especially when applied to something as vast and complex as the universe. Some scientists use mathematical models and theories to help understand the concept of infinite space, while others may use analogies or visualizations to aid in understanding.
5. Could there be multiple universes within the infinite universe?
There are various theories and hypotheses about the existence of multiple universes within the infinite universe. However, this is still a topic of ongoing research and debate, and there is currently no definitive evidence to support or refute this idea.
  • Cosmology
  • Cosmology
  • Cosmology
  • Cosmology
