Is Mars' High CO2 Atmosphere a Good Model for Earth's Greenhouse Effect?
In summary, the conversation is discussing the relationship between CO2 and global warming, specifically looking at the effect of CO2 on temperature on Earth and Mars. The conversation also mentions the lack of studies on the greenhouse effect of CO2 on Mars and the potential implications for Earth's greenhouse effect.
Andre
4,311
74
Although the titel suggests that the thread is about another planet, the real subject is the forcing character of CO2 greenhouse gas and so it's about global warming and hence it should belong in the Earth forum.
If you write a Assessment Report for the IPCC about greenhouse effect on Earth, with much uncertanties, you would certainly want to compare with other cases like Mars to validate assumptions. That's Science and the scientific method, assuming that the same physical laws are correct on Mars as well.
There isn't any. Not a single study.
Hans Erren calculates the CO2 forcing like this:
http://members.lycos.nl/ErrenWijlens/co2/howmuch.htm
The effect of CO2 on temperature is the Arrhenius law. dE=[alpha]ln([CO2]/[CO2}orig), where alpha is 5.35 (Myhre et al.) http://www.grida.no/climate/ipcc_tar/wg1/222.htm
E is change in forcing
using the derivative of Stefan-Boltzmann:
dT/dE = 1/(4[sigma] T^3)
gets:
dT=[alpha]ln([CO2]/[CO2}orig)/(4[sigma] T^3)
This is the equation without all feedbacks.
Substituting a doubling CO2 level (unrealistic, according to Lomborg) and substituting T= 15 degrees C = 288.16K
dT=5.35*ln(2)/(4*5.6705E-08*(288.16^3))
or
dT=0.6833 centigrade for a doubling of CO2 !
Now if you would really want to calculate greenhouse gas forcing, there is a splendid object for that. Mars and its CO2 atmosphere. So let’s do an attempt.
Mars fact sheet:
http://quest.nasa.gov/mars/background/vitals.html
Maximum Surface Temperature 310 K
Minimum Surface Temperature 150 K
(Thus median value: 230K)
Atmospheric Pressure 0.007 bars
Black Body Temperature 216.6 K
Carbon Dioxide CO2 95.32%
Median value is not necessarily the average value so let’s peek some more for an average temperature:
http://science.howstuffworks.com/terraforming1.htm
The average surface temperature on Mars is a frigid minus 81 degrees Fahrenheit (-62.77 degrees Celsius)
On the other hand it’s -55C in several other sources like:
http://www.nineplanets.org/mars.html
So let's use both values, then the average Mars temperature is about 210K/218K; 6 degrees lower or 2 degrees warmer than Black body but Mars albedo is 0.16. Suppose that relationship was linear (it probably isn’t), then the basic temp of a 16% reflecting body could be (273-217)*0.16= 9 degrees lower, hence 208K.
So, if that’s to be correct, then the greenhouse gas effect on Mars is 2K or 10K degrees. But I’m sure that this linear relationship that I assumed is wrong. Who can help?
Now, 95% of the 7 millibar atmosphere is CO2, let's say: 7 millibar CO2.
Earths atmosphere contains 380 ppmv CO2 (0.38 pptv) in a one bar atmosphere, this is equivalent to 0.38 millibar. So, You’d need a little more than 4 times doubling (0.38 -> 0.76 -> 1.52 -> 3.04 -> 6.08) to get to the Mars CO2 concentration. So Mars greenhouse effect of CO2 is over 4 times as strong as on Earth.
But the greenhouse effect appears to be only 2K or 10K degrees, hence Earths greenhouse effect in total for CO2 should be one fourth of that: 0,5K or 2,5K?
But then again, is there greenhouse effect on Mars?
http://www.deccanherald.com/deccanherald/feb282005/snt2.asp
Conclusion. There is no chapter in the Third Assessment Report of the IPCC about greenhouse effect of CO2 on Mars, to validate Earth greenhouse effect because the greenhouse effect on Mars is negliglible, despite the strong CO2 concentration.
So, one more example of the negative scientific value of the IPCC Third Assessment Report.
Mars fact sheet:
Lets imagine we could have taken a reading of the Earth's atmosphere 3600 - 20,000 years after what is thought to have been the dinosarid extiction event 65 million years ago... (<>100 kilometer sized asteriod collides with Earth at the gulf of mexico). Not only would there be a great release of ejecta, crust and substrate because of this collision but also a lot of fires burning down forests around the world. Massive release of CO2, CO and so on.
I'm giving the timeframe of between 3600 to 20,000 years ago because it was inside this time period that Mars experienced a similar collision with a similarily large, greater than 100 kilometer, sized object. This collision was so massive that it took half the Martian crust off and created huge other features that I can't name right now.
Would the measurements of our atmosphere's CO2 content, 20,000 years after our entire planet was on fire, read "7 millibar CO2" as is indicated by readings taken on Mars?
Thank you for sharing your calculations and thoughts on the greenhouse effect on Mars. While it is true that Mars has a much higher concentration of CO2 in its atmosphere compared to Earth, the differences in atmospheric pressure, albedo, and other factors make it difficult to directly compare the greenhouse effect between the two planets. Additionally, as you mentioned, there is still much uncertainty and debate surrounding the exact impact of CO2 on Earth's climate. As scientists continue to study and gather data, it is important to look at other examples and cases, like Mars, to help validate assumptions and better understand the complex phenomenon of global warming.
FAQ: Is Mars' High CO2 Atmosphere a Good Model for Earth's Greenhouse Effect?
What is global warming in Mars?
Global warming in Mars refers to the gradual increase in the average temperature of the Martian surface and atmosphere over time. It is caused by the buildup of greenhouse gases, such as carbon dioxide, in the atmosphere, which trap heat and raise the overall temperature.
What evidence supports the existence of global warming in Mars?
Scientists have observed changes in Mars' atmosphere, such as the disappearance of some polar ice caps and the presence of dust storms, which indicate a rise in temperature. Data from orbiters and rovers also show a decrease in the planet's overall albedo, or reflectivity, which is a result of the melting of ice and darkening of the surface due to increased temperatures.
How does global warming in Mars compare to Earth's global warming?
While both Mars and Earth experience global warming, they have different causes and rates. Mars' global warming is primarily a result of natural processes, such as changes in its orbit and tilt, while Earth's global warming is mainly caused by human activities, such as the burning of fossil fuels. Additionally, Earth's global warming is occurring at a much faster rate than Mars' due to the significant difference in greenhouse gas levels between the two planets.
How does global warming in Mars impact the planet's habitability?
The effects of global warming in Mars on the planet's habitability are complex and still being studied. However, it is believed that the loss of polar ice caps and changes in atmospheric composition could potentially make it more difficult for life to exist on Mars, as it would become more challenging to sustain liquid water and a stable climate.
What is being done to address global warming in Mars?
Currently, there are no active efforts to directly address global warming in Mars. However, scientists continue to study the planet's climate and gather data to better understand the phenomenon and its potential impacts. This information can also be used to inform future missions and potential human colonization efforts on Mars.
32K
45K
78K
