Massless Charged Particles: Fact or Fiction?
In summary, the conversation centers around the possibility of the existence of massless charged particles and how they would behave and interact with electromagnetic fields. The concept is explored through various theoretical perspectives and references to past research are mentioned. It is mentioned that there is currently no evidence for the existence of such particles, but there are theoretical possibilities for their existence, such as through supersymmetry or broken symmetries.
pseudovector
46
I've been studying the Yang-Mills theory, which predicted the existence of massless charged particles. That theory was later proven to be wrong, but it made me wonder nevertheless - can there ever be massless charged particles? And if such particle exists, how will it behave? How will it interact with electromagnetic fields?
By massless, one would expect you mean "rest mass." In that case, the particle would probably behave most like a photon, traveling at speed c in free space.
Unlike a photon, however, such a particle would be affected by electromagnetic fields. One could only speculate, but I imagine if the particle were traveling through a field E which would do work on the particle, the energy and momentum of the particle would change in such a way as to increase (or decrease) the frequency (a photon with a variable wavelength, so to speak). That's just gut feeling though...
Perhaps a treatment with QM could reveal some answers.
By "massless" I did mean "rest mass zero". Also, in addition to the particle's interaction with electric fields, I considered its interaction with magnetic fields, and my guess is that such particle would come to a half in the presence of magnetic fields.
But the thing that bothers me most is the fact that no such particle has been observed (as far as I know), so there has to be some law prohibiting the existence of such particles. I think it has something to do with the "optic boom" such particle will make, similar to the sonic boom caused by objects that travel at the speed of sound. This also means that such particle could feel its own electric field.
I think it's an open matter. It involves the existence of consistent cross-couplings between a massless gauge abelian one-form field and an arbitrary massless field and then interpreting the nonzero coupling constant as the particle's electric charge. Something could however go wrong: the appearance of consistent self couplings of the massless field resulting in the appearence of a mass term...
Daniel.
There was a fundamental work by Coleman and Eric Weinberg in the early seventies where they show that massless scalar electrodynamics does not exist; I do not know if the fermionic case is too trivial or too difficult.
Yes, It is the vacuum. What looks an utter triviality- either the vacuum is invariant or it is not-contains, however, a rich physics.
If the vacuum was invariant under, say, the SU(2) gauge group, the charged vector bosons ([itex]W^{+},W^{-}[/itex]) would have to be massless, and the [itex]Z^{0}[/itex] would be , almost, identical to the photon.
Remember Sidney Coleman's theorem;
"Symmetries of the vacuum are symmetries of the world"
If the vacuum is invariant, Coleman's theorem shows that the associated currents are conserved. The symmetry is exact and unitarily implemented by operators, at least, on a dense subset of the Hilbert space including the vacuum.
Fortunately, we live in a world where the weak interaction has a very short range! i.e. the SU(2) gauge group is not exact symmetry( SU(2)-charges do not annihilate the vacuum), otherwise, I think, the world will be very bright and over populated with neutrinos.
regards
sam
Arivero, either way, i'll make the calculations. One thing's certain, though:it's not difficult at all to obtain a result.
Daniel.
You need to get a copy of Sidney Coleman and Erick Weinberg "Radiative Corrections as the Origin of Spontaneous Symmetry Breaking", Phys. Rev. D 7, 1888–1910 (1973), which is -as I told- about scalar massless charged particles. The file is available from prola, http://prola.aps.org/abstract/PRD/v7/i6/p1888_1 , to aps subscribers.
There's a follow-up on this from Weinberg together with Eldad Gilderner:
Symmetry Breaking and Scalar Bosons
Phys. Rev. D 13, 3333–3341 (1976)
But then, the relatively low Higgs boson masses predicted in this later
document (including the "scalon") have not been found.
Regards, Hans
I'll look up that article. Thanks for your help.
Daniel.
On the one hand there is the experimental fact; "we see mass without charge, but no electric charge without mass", on the other hand, theoretically, 4 dimensional, massless QED with invariant vacuum is possible. That is, theoretically, nothing wrong with massless fermions.
Weinberg-Witten theorem;
Limits on massless particles,
Phys. Lett. B96 (1980), 59-62.
puts sharp restrictions on the possible massless field, they cannot be completely arbitrarly as you suggest.
Basically, In dimension [itex]n\geq4[/itex], the spin of a massless particle is classified by a representation of the little group SO(n-2). If a local, conserved, symmetric and gauge-invariant stress tensor exists, the allowed representations for massless fields are the spinor representation(s)[there are two of these if n is even and one if n is odd], and the exterior powers of the fundamental (n-2)-dimensional representation including the trivial(scalar) representation.The theorem shows that Poincare invariant global charges vanish except for massless particles in the trivial or spinor representation;([itex]j=0,\pm1/2[/itex]).
Without adjusting some parameters to make the particles massless, Massless particles must be massless for a reason.One possible reason is supersymmetry. But there are othere possible reasons;
Scalar particles are massless when there is a broken symmetry(Goldstone).
Fermions in four dimension are massless when they are chiral, that is, when there is unbroken chiral symmetry.
If the massless, spin1/2, particles transform in a representation[itex]R[/itex] of some unbroken symmetry group G, then the massless particles of spin(-1/2) transform, according to the CPT theorem, in the conjugate representation [itex]R^*[/itex]. If [itex]R[/itex] and [itex]R^*[/itex] are distinct, then this spectrum cannot be perturbed in a G-invariant way to give masses to the fermions. So, nothing will "go wrong" and you won't get a mass term.
This shows that massless QED is possible, that is, we cannot, using the tools of QFT, show that massless charged fermions do not exist.
However, the question, which I don't know the answer to, is; Is classical electrodynamics of massless charge possible?
regareds
sam
It is neither trivial nor difficult. It is impossible to show that massless QED does not exist. see post#11.
There is the so-called Schwinger model. It is the 2-dimensional massless QED. It is exactly solvable and physically equivalent to the 2-dimensional free masive vector field theory, as found by Schwinger;
J. Schwiger, Phys. Rev. 128, 2425(1962).
regards
sam
Classically, if you boost the electric field of a stationary (massive) electrically charged particle, you get a magnetic field. I think I've seen speculation that the natural massless charged particles are therefore magnetic monopoles, but I don't recall where.
Carl
QUOTE=CarlB]Classically, if you boost the electric field of a stationary (massive) electrically charged particle, you get a magnetic field. I think I've seen speculation that the natural massless charged particles are therefore magnetic monopoles, but I don't recall where.
Carl
[/QUOTE]
Can anybody explain to me the physics (if any) in the above quote?
I just can not understand what he is saying!:wink:
regards
sam
Related to Massless Charged Particles: Fact or Fiction?
1. What are massless electric charges?
Massless electric charges are hypothetical particles that have no mass but carry an electric charge. They are considered to be point particles, meaning they have no physical size or volume.
2. Do massless electric charges exist?
At this time, there is no experimental evidence to suggest that massless electric charges exist. However, they are often used in theoretical physics and in models of the universe.
3. How are massless electric charges different from massive electric charges?
The main difference between massless and massive electric charges is their mass. Massive electric charges have a measurable mass, while massless electric charges have no mass. This means that massive electric charges interact with the Higgs field, which gives particles their mass, while massless electric charges do not.
4. Can massless electric charges be created or destroyed?
According to current theories, massless electric charges cannot be created or destroyed. They are considered to be fundamental particles, meaning they cannot be broken down into smaller components.
5. What is the significance of massless electric charges?
Massless electric charges have important implications in theoretical physics and the study of the universe. They are often used in models to explain the behavior of particles and the interactions between them. They also play a role in the search for a unified theory of physics, such as the theory of everything.
  • Classical Physics
  • Beyond the Standard Models
