Why is this integral positive or negative
The discussion focuses on understanding the behavior of the integral of x cos x over specified intervals. It is established that the integral from 0 to pi/2 is positive due to the function being above the x-axis in that range, while from pi/2 to pi, it is negative as the function falls below the x-axis. Participants suggest using graphical analysis and integration by parts to evaluate the indefinite integral of x cos x. The conversation emphasizes the importance of recognizing the sign of the function within the given intervals to determine the overall integral's value. The thread concludes with encouragement to further explore integration techniques for clarity.
Natasha1
I have been asked to explain without evaluating the integrals why
1) the integral of x cos x from 0 to pi/2 is positive and the integral of x cos x from pi/2 to pi is negative. And also would I expect x cos x from 0 to pi to be positive, zero or negative? And why ?
2) to find the indefinite integral of x cos x dx and hence the exact values of values of x cos x from 0 to pi/2, cos x from pi/2 to pi and x cos x from 0 to pi?
Any help would be must appreciated. I know I haven't done anything so far so no need to have a go at me for it but I just wanted some help with it and even better the solutions obviously as this blimming thing is for in a few days time. Many thanks in advance
Nat
1) What are your thoughts on this? Have you drawn the graph?
2) Have you learned about integration by parts?
\int x\cos(x)dx
By parts, u=x dv=cos(x)
du = 1 v = sin(x)
\int udv= uv - \int vdu
You can take it from there.
#1, What can you say about the integral of \int \limits_{\alpha} ^ {\beta} f(x) \ dx (i.e greater or less than or equal to 0), if:
(i) f(x) > 0 , \ \forall x \in ( \alpha, \ \beta )
(ii) f(x) < 0 , \ \forall x \in ( \alpha, \ \beta )?
You can draw a graph to see this. Remember that definite integral of some function from a to b will give you the area under the graph of that function from x = a to x = b.
#2, as others have pointed out, this should be done by Integration by parts.
You can either read the article there, or look at your textbook. There should be something about Integration by parts.
Can you go from here? If you still have problems, just shout out. :smile:
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 19 ·
