Question: A metal sphere of radius R carries a total charge Q
In summary, the force of repulsion between the "northern" hemisphere and "southern" hemisphere of a metal sphere with radius R and total charge Q can be found by using the formula df = σdaE, where E = (1/2)((Q/4πε₀R²) + 0) and σ = Q/4πR². This results in an answer of ∫₀²π ∫₀¹/₂ (Q²sinθ/32π²ε₀R²)(sinθcosφe_x + sinθsinφe_y + cosθe_z)dθdφ, with the recognition that the x and y components of F are zero due to axial symmetry.
siddharth
Question: A metal sphere of radius R carries a total charge Q. What is the force of repulsion between the "northen" hemisphere and the "southern" hemisphere?
The force for a small area 'da' on the outer surface should be
[tex] df = \sigma da E [/tex]
What E to use? My guess is that it should be averaged over both sides of the surface.
So,
[tex]E = \frac{1}{2} (\frac{Q}{4 \pi \epsilon_0 R^2} + 0)[/tex]
[tex] \vec{E} = \frac{Q}{8\pi \epsilon_0 R^2} \vec{e_r} [/tex]
and
[tex] \sigma = \frac{Q}{4 \pi R^2} [/tex]
And the answer should be
[tex] \int_{0}^{2\pi} \int_{0}^{\frac{\pi}{2}} \frac{Q^2 \sin\theta}{32 \pi^2 \epsilon_0 R^2}(\sin\theta \cos\phi \vec{e_x} + \sin\theta \sin\phi \vec{e_y} + \cos\theta \vec{e_z}) d\theta d\phi [/tex]
Is my approach correct?
Yes, but you should follow Tesla's advice and recognize from the beginning that the x and y components of F vanish due to the axial symmetry.
Thanks Meir Achuz. That would have been my next step. Stating that F_x and F_y are zero by symmetry.
Related to Question: A metal sphere of radius R carries a total charge Q
1. What is the formula for calculating the electric field of a metal sphere?
The formula for calculating the electric field of a metal sphere is E = kQ/r^2, where E is the electric field, k is the Coulomb constant, Q is the total charge, and r is the distance from the center of the sphere.
2. How does the charge distribution on a metal sphere affect its electric field?
The electric field of a metal sphere is equal to zero inside the sphere, and is only affected by the distribution of charge on the surface of the sphere. The electric field is strongest at the surface where the charge is concentrated.
3. Can the total charge on a metal sphere be negative?
Yes, the total charge on a metal sphere can be negative. This indicates an excess of electrons on the surface of the sphere, giving it a net negative charge.
4. What is the relationship between the radius of a metal sphere and its electric field?
The electric field is inversely proportional to the square of the radius of a metal sphere. This means that as the radius increases, the electric field decreases.
5. How does the total charge on a metal sphere affect its capacitance?
The capacitance of a metal sphere is directly proportional to the total charge on the sphere. This means that as the charge increases, the capacitance also increases.
