honestrosewater
- 6
Guess what? I made conversation hearts! :!)
INSTRUCTIONS:
0) Quote this post and use only the text following the dotted line below (don't forget to delete the ending [/quote'] tag).
1) Fill out the TO: and FROM: fields.
2) I included three lines for your message (you don't need to use all of them and can add more if necessary). See where the three ['color=#000000][/color'] tags appear in the heart? Type your message there, like so: ['color=#000000]YOUR MESSAGE[/color']. Breaking up your message rather evenly over two or three lines will probably look best.
3) For each line of your message, count the number of characters you've used -- including blank spaces.
4) Get as creative as you like. Change the colors, add patterns, whatever tickles your fancy. But if you change the font, I suggest using a monospace one (where each character has the same width) unless you don't mind having to adjust for the different widths.
INSTRUCTIONS:
a) If this number is even, divide by 2 and delete that many Xs on each side of your message.
b) If this number is odd, subtract 1, divide by 2, delete that many Xs on each side of your message, and delete 1 more X on the left side.
For example, YOUR MESSAGES uses 13 characters, so I delete 7 Xs on the left side and 6 Xs on the right side.b) If this number is odd, subtract 1, divide by 2, delete that many Xs on each side of your message, and delete 1 more X on the left side.
TO:
MXXOO-----MXXOO
MXXXXXOO---MXXXXXOO
MXXXXXXXXOO-MXXXXXXXXOO
MXXXXXXXXXXXXXXXXXXXXXXOO
MXXXXXXXXXXXXXXXXXXXXXXXXO
MXXXXXXXXXXXXXXXX
MXXXXXXXXXXXX
MXXXXXXXX
MXXXX
MXX
M
MXXOO-----MXXOO
MXXXXXOO---MXXXXXOO
MXXXXXXXXXXXXXXXX
MXXXXXXXXXXXX
MXXXXXXXX
MXXXX
MXX
M
