Weigh the Balls: Find Odd Ball in 3 Weighings
In summary: Case 1.3: the balance tips towards {1,2,3} so one of these balls is the target, which is now known to be light. Balance ball 2 against 3 to find...Case 2: all 4 balls are still in the balance, so there is no target. Label these four balls 1, 2, 3 and 4.Ball 1 is heavier than ball 2, so it is the oddball and therefore the target.In summary, the target ball weighs more than the other 11 balls.
Mattara
348
Ýou have 12 balls.
All of them have the same mass.
Except one.
You don't know if it weighs more or less than the other 11 balls.
Your mission is to find the odd one out, and say if it weighs more or less than the 11 others.
You have a balancescale.
You may use it for three weighings.
The technique must work no mmater where the odd ball is.
EDIT: Added the balance part
I think there's one item missing from the givens. Do you know the weight of the balls, or is that unknown?
There is no need to know the masses of the balls in order to complete the brain teaser.
The correct answer will fill many A4:s of possible weighings.
ex.
If i weigh those balls against those, which one will weigh the most? How and in which weighingss do I get controlballs etc.
I think the missing item could be that it's not a *scale* per se, so much as a balance. So, one weighing might be to have ball A vs. ball B, the result of which would tell you which was heavier, A or B. Doing that, then yes, it's possible within 3 weighs, and no other given information.
If it's really a *scale*... then... hm. Not sure how many weighs you'd need, but I'd bet a bit more than 3. I get between 3 and 6 weighs using a scale, 3 if you make lucky picks, 6 if you're unlucky. Better than 6, anyone?
DaveE
Oh, you meant it that way! Yes it is a balance scale. You get the masses of the balls relative to each other and nothing else. Sorry for the confusion.
Came back to this and noticed it was possible in 5 (assuming a scale, not a balance). Considering that by effectively doing a binary-search-type weighing, you could do weighs of 6 balls, then 3, then 2, then 1, so maybe it's possible in 4 scale-weighs? But 5 might be the minimum considering that you need at least 4 weighs to *find* what you're looking for, plus 1 weigh to find out whether the one you're looking for weighs more or less than the remaining 12.
DaveE
It is a balance.
Mattara said:
It is a balance.
But the scale weighing is much more intersting to me... The balance ones have been way overdone.
The question is with a balance. Solve it. If you want a scale post another brain teaser
It can't be both?
The "find-the-1-of-12-objects-that-weighs-a-different-amount" problem has been done a bunch of times on this forum, so it's entirely possible that you won't see much of a response. The last time someone posted it, you can see the response they got:
https://www.physicsforums.com/showthread.php?t=105118
So, don't feel too bad if there isn't a reply.
I don't remember seeing a *scale* question before, though, so I know at least I was interested (and apparently Moo, too) in seeing a new problem. But, anyway, I'm done. Unless someone wants to discuss the scale problem further...
DaveE
If all you care about is worst case, then the scale is a pretty straightforward binary search.
Ok, i didn't realize that it had been posted to death.
Ok it is a scale instead of a balance
I have just worked it out in 3 steps using a plain balance so you don't really need a scale. (No, I didn't look up the solution.) It's a bit tricky, not just a binary search.
ok, post the answer in the colour ;P
Ok, I'll try COLOR="#e9e9e9" to match the "PF Prime" color scheme. I hope it works well enough with other schemes too...
Eleven balls have mass M, the target ball has a greater or lesser mass.
First, balance four balls against four balls.
Case 1: the balance is level so the target is in the remaining goup of 4. Label these four balls 1, 2, 3 and 4. Set aside ball 4 and balance group {1,2,3} against known balls {M,M,M} from the remaining eight.
Case 1.1: the balance is level so ball 4 is the target. A third balance determines if it is heavy or light.
Case 1.2: the balance tips towards {1,2,3} so one of these balls is the target, which is now known to be heavy. Balance ball 1 against 2 to find out which of these three is the heavy one.
Case 1.3: the balance tips towards {M,M,M} so one of {1,2,3} is the target, which is now known to be light. Balance ball 1 against 2 to find out which of these three is the light one.
Case 2: the first balance was not level so the target is in this group of 8 balls. Label balls on the heavier side {1,2,3,4} and balls on the lighter side {5,6,7,8}.
Now balance balls {1,2,M} against balls {3,4,5}.
Case 2.1: the balance is level so the target is in remaining set {6,7,8} and is known to be light (from the first balance). Balance 6 against 7 to know which of these three is the light one.
Case 2.2: the balance tips towards {1,2,M} so either a ball in {1,2} is heavy or ball 5 is light. Balance ball 1 againt ball 2 to know if one is heavy and which one, or to know that ball 5 is light if the balance is level.
Case 2.3: the balance tips towards {3,4,5} so either ball 3 or 4 is heavy. Balance 3 against 4 to know which one.
I hope I didn't screw up anywhere. :rolleyes: Someome will let me know for sure.
i propose a solution shud be right ...enjoy
i will use W for the word weigh..u remove 2 coins .so u W the 2 piles of 5 coins .if they r the same then the 2 coins contain 1 odd coin so u take them and wiegh them against each other now u no 1 is light or normal or the other is heavy or normal, so now u choose any of them and weigh them against a normal coin.
if the piles of 5 r difirent u name 1 pile heavy pile and 1 pile light similar to wat we did with the 2 coins. we remove a light coin put it aside and we form groups HHL HHL HLL we weigh HHL vs HHL if they weigh diffirent then odd coin is either H ,H or L , ( call normal coin N) so u do HL vs NN leaving out L .. if HHL vs HHL shows they weigh same then odd coin in HLL with 1 wiehing left u do HL vs NN leaving out L ...QED
tell me if u find me incorect.(btw i didnt write all details in last part u can easily fill in the gaps)
hmm
Mattara said:
Ýou have 12 balls.
gosh!
Related to Weigh the Balls: Find Odd Ball in 3 Weighings
1. How does the "Weigh the Balls" puzzle work?
The "Weigh the Balls" puzzle involves finding the odd ball out of a group of identical-looking balls in only three weighings on a balance scale. The key to solving the puzzle is to divide the balls into groups and use the balance scale to determine which group contains the odd ball.
2. How many balls are needed for the "Weigh the Balls" puzzle?
The "Weigh the Balls" puzzle can be solved with any number of balls, as long as there is at least one odd ball. However, the puzzle is typically presented with 12 balls, as this is the minimum number needed to make the three weighings challenging.
3. What is the strategy for solving the "Weigh the Balls" puzzle?
The most effective strategy for solving the "Weigh the Balls" puzzle is to divide the balls into three groups of equal size and weigh two of the groups against each other. If the scale is balanced, then the odd ball is in the third group. If the scale is unbalanced, then the odd ball is in the heavier group. From there, the odd ball can be found in the third weighing using the same method.
4. Can the "Weigh the Balls" puzzle be solved with more than three weighings?
Yes, the "Weigh the Balls" puzzle can be solved with more than three weighings, but the challenge is to find the solution in the fewest number of weighings possible. Using more than three weighings can make the puzzle less challenging and less interesting.
5. Are there any variations of the "Weigh the Balls" puzzle?
Yes, there are many different variations of the "Weigh the Balls" puzzle. Some variations may involve a different number of balls, different types of balls, or different rules for how the balls can be weighed. These variations can make the puzzle more challenging and require different strategies to solve.
  • General Discussion
  • Classical Physics
