How Far Above a Planet's Surface is a Starship if Gravity is Halved?
  • Thread starter Thread starter pureouchies4717
A starship orbiting a planet at an altitude where gravity is half that at the surface requires understanding gravitational acceleration. The gravitational acceleration at the surface is defined as a_g = (G M) / R^2, while at altitude d, it is A_g = (G M) / d^2. The relationship shows that if A_g is half of a_g, then d must equal R multiplied by the square root of 2. The discussion highlights the confusion around interpreting the altitude as a multiple of R and clarifies that the answer can indeed be expressed as a real number multiple. Ultimately, the problem emphasizes the inverse square law of gravity and the mathematical derivation of altitude in relation to the planet's radius.
pureouchies4717
this is the question:
A starship is circling a distant planet of radius R. The astronauts find that the acceleration due to gravity at their altitude is half the value at the planet's surface. How far above the surface are they orbiting? Your answer will be a multiple of R.
using a= (GM)/r^2, i found out that d=2R
this is wrong, though
can someone please help me out?
Explanation.
NOTES:
I will define 'a' as the planet's acceleration.
I will definie 'A' as the spaceship's acceleration.
I will define 'd' as their current altitude with respect to the planet.
a_g = (G M) / r^2
The planet has a r=R, so the 'a' at the planet's surface is:
a_g = (G M) / R^2
They realize that their 'A' at their altitude is 'a/2'
A_g = (G M) / d^2
OR
(a/2)_g = (G M) / d^2
Let's look at this for a second. Everything in this equation is constant except for R^2 and d^2 and acceleration of gravity.
We can summarize this: a_g \sim 1/r^2
The acceleration of gravity is inversely proportional to r-squared. If we double the distance r, the acceleration is 1/4 than it was at a distance r.
So... solving for 'r'.
r^2 = 1/a_g
r = \sqrt{1/a_g}
So if the acceleration is 1/2
r = \sqrt{1/1/2}
r = \sqrt{2}
So there is your answer, mathematically... Now, having your answer as a multiple of r means ANY REAL number, not a whole number.
thank you!
i don't understand... i understand how r = sqrt of 2, mathematically, but how does this equate to being a multiple of r?
nevermind...i see what was going on... tricky problem i entered the square root of 2 twice and now i understand that they ask (how far above)
