Principle of Conservation of Linear Momentum
In summary, the conversation discusses a problem where a large plate is dropped and breaks into three pieces with given velocities. The total momentum parallel to the floor must remain zero after the collision due to the net external force acting on the plate. The conversation also mentions the use of a formula to solve for the masses of pieces 1 and 2, with two unknowns and the need for two equations.
helen3743
I also need help how to start his problem:
"By accident, a large plate is dropped and breaks into three pieces. The pieces fly apart parallel to the floor, with v1 = 3.10 m/s and v2 = 1.60 m/s. As the plate falls, its momentum has only a vertical component, and no component parallel to the floor. After the collision, the component of the total momentum parallel to the floor must remain zero, since the net external force acting on the plate has no component parallel to the floor. Using the data shown in the drawing, find the masses of pieces 1 and 2."
In the drawing, it shows m1 & m2 falling at an angle to the floor but m3 has no angle, and just has a velocity of 3.07 m/s pointing down with a mass of 1.3kg.
How would the formula look like to solve this problem?
I know the normal formula looks like:
x comp & y comp:
m1vf1 + m2vf2 =m1vo1 + m2vo2
I know how to find velocities incorporation the angles, (like doing m1sin25)but I don't know where to fit in the third mass in the formula.
Do you? Thanks!
You have two unknowns, m1 and m2.
That means you need two equations. Balance the x-momenta for one equation, and balance the y-momenta for the other.
The principle of conservation of linear momentum states that in a closed system, the total momentum remains constant before and after a collision. This means that the sum of the momenta of all objects involved in the collision will remain the same. In this case, the plate and its three pieces can be considered a closed system, as there are no external forces acting on it parallel to the floor.
To solve this problem, we can use the formula for conservation of momentum, which is m1v1 + m2v2 = m1v1' + m2v2' + m3v3', where m1 and m2 are the masses of the two pieces before the collision and v1, v2, v1', v2', and v3' are their respective velocities after the collision. We can also assume that the initial velocity of the plate before it breaks is zero, as stated in the problem.
To incorporate the third mass (m3) in the formula, we can rewrite it as m1v1 + m2v2 + m3v3 = m1v1' + m2v2' + m3v3'. Since we are given the velocities of pieces 1 and 2 after the collision, we can substitute those values in the equation. We are also given the velocity of piece 3 (v3) and its mass (m3), so we can solve for the masses of pieces 1 and 2 using algebra.
The formula would look like this:
m1(3.10 m/s) + m2(1.60 m/s) + m3(3.07 m/s) = m1v1' + m2v2' + m3(3.07 m/s)
We can solve for v1' and v2' using the given velocities and the fact that the net external force acting on the plate has no component parallel to the floor. Then, we can plug those values back into the equation and solve for m1 and m2.
I hope this helps you solve the problem. Remember to always consider the principle of conservation of linear momentum when dealing with collisions in a closed system.
Related to Principle of Conservation of Linear Momentum
1. What is the Principle of Conservation of Linear Momentum?
The Principle of Conservation of Linear Momentum states that the total linear momentum of a system remains constant when there are no external forces acting on the system. This means that the total amount of momentum before an event is equal to the total amount of momentum after the event.
2. Why is the Principle of Conservation of Linear Momentum important?
The Principle of Conservation of Linear Momentum is important because it is a fundamental law of physics that can be applied to a wide range of systems and scenarios. It helps to predict the outcome of collisions and interactions between objects, and is crucial in understanding the laws of motion.
3. How is the Principle of Conservation of Linear Momentum mathematically expressed?
The mathematical expression of the Principle of Conservation of Linear Momentum is:
Σpinitial = Σpfinal
where Σp represents the total linear momentum of a system, and the subscripts "initial" and "final" refer to the initial and final states of the system, respectively.
4. Can the Principle of Conservation of Linear Momentum be violated?
No, the Principle of Conservation of Linear Momentum cannot be violated. This law is based on the fundamental concept of inertia, which states that an object will maintain its state of motion unless acted upon by an external force. Therefore, in the absence of external forces, the total linear momentum of a system will remain constant.
5. What are some real-life examples of the Principle of Conservation of Linear Momentum?
Some real-life examples of the Principle of Conservation of Linear Momentum include a moving billiard ball colliding with another stationary ball and transferring its momentum, a rocket launching into space by expelling exhaust gases at high speeds, and a skater pushing off against a wall to gain momentum in the opposite direction.
