Having trouble with circuit to adjust speed of electric motor
In summary: This circuit can be used to control the speed of a DC motor (on a fan). Temperature is also sensed by the PC. Combining the two pieces of information, the speed of the motor is changed (increased/decreased) relative to the temperature in the environment, to maintain a constant temperature.In summary, the device needs to travel much slower than the RPM output the motor has, but I've gotten into some trouble with my circuit trying to slow it down. I'm looking for suggestions on how to fix the issue. The potentiometer I tried was 3W, 200Ohm, and the switch's specifications I don't know. I'm also thinking about building or buying a PWM circuit to
I'm building a device powered by an electric motor, it needs to travel much slower than the RPM output the motor has... I've gotten into some trouble with my circuit trying slow the thing down, hoping for some suggestions...
at the moment my circuit goes: battery, switch, potentiometer, motor, (back to battery). - All connected in series.
Without the potentiometer there's no problems, but I'm finding the once I put one in it overheats within a few seconds...
it's a 12v, 2.3Ah battery
dont know the switch's specifications but i haven't had any problems with it
The motor's specifications I don't know (still in a testing/playing around to see what works phase - I could buy a different motor later if needed)... I took it out of a golf buggy though, so maybe you could make an educated guess about the info you need to help me? :/ sorry...
The potentiometer I tried was 3W, 200Ohm...
Sooo... What can I change to make the circuit function better?
Any help would be greatly appreciated.
If the resisitance of 200ohms is what you need try using one with a larger value say 50w, if you don't know if you need a lower resistance try like a 35ohm or something.
also thinking about building or buying a PWM circuit to turn your motor, its more efficient.
Yeah, I don't think you can effectively slow down your motor by dropping the voltage with a resistor. No wonder stuff is overheating. I believe that PWM is the right way to slow down the motor.
what's a PWM? :(
nevermind, i looked it up... thanks guys you've helped a lot, I'm going to replace the potentiometer with this: http://www.dse.com.au/cgi-bin/dse.storefront/4432937f0304982a273fc0a87f9c06b4
sound good?
If you're interested in learning more, here is a spiffy application of PWM (pulse width modulation) generated by a PC, used to control the speed of a DC motor (on a fan). Temperature is also sensed by the PC. Combining the two pieces of information, the speed of the motor is changed (increased/decreased) relative to the temperature in the environment, to maintain a constant temperature.:smile:
The radio control market has many different speed controllers for remote control vehicles and your battery is within the range of most of those applications.
http://www2.towerhobbies.com/cgi-bin/wti0093p?&C=MJA
There are also variable resistor style speed controls for the small cars (that want to use an inexpensive method with a standard servo) and these are much closer to a rheostat that is designed to handle current (instead of a potentiometer that is NOT designed to handle current). But a PWM motor driving circuit is the way to go.
If you're linking to K3070 on that site, it'll work to a certain extent but is only good to 1A, and with a 12V battery that's 12W. Not a lot of power.
was trying to link to K3072... don't know why that didnt work... but anyway, that one is good to 15A, i'd imagine that'll be enough?
15A should be plenty enough for the size of battery you're running.
eeeeeeeeeexcellent.
thank you very much
The simplest way to generate a variable width PWM (pulse width modulation) signal is with a triangle wave (from an op amp oscillator) going into a second op amp used as a comparator (with potentiometer for voltage level input). FETs can be used for outputs up to about 15 amps, and IGBTs for currents up to 100's of amps.
Related to Having trouble with circuit to adjust speed of electric motor
1. How can I adjust the speed of an electric motor in a circuit?
There are a few ways to adjust the speed of an electric motor in a circuit. One way is to use a variable resistor, also known as a potentiometer, to control the flow of electricity to the motor. Another way is to use a pulse width modulation (PWM) circuit, which rapidly switches the motor on and off to control its speed.
2. Why is my electric motor running at a constant speed instead of adjusting?
If your electric motor is not adjusting its speed, it could be due to a faulty component in the circuit. Check all connections and components, such as the potentiometer or PWM circuit, to make sure they are functioning properly. It is also possible that the motor itself is damaged and unable to adjust its speed.
3. Can I adjust the speed of any type of electric motor?
The ability to adjust the speed of an electric motor depends on the type of motor. Some motors, such as universal motors, are designed to be able to adjust their speed. However, other types of motors, such as AC induction motors, may not be able to be adjusted without additional components or a different type of circuit.
4. How can I make my circuit to adjust the speed of an electric motor more precise?
To make your circuit more precise, you can use a microcontroller to control the speed of the motor. This will allow you to program specific speeds and adjust them as needed. You can also use feedback sensors, such as encoders, to monitor the speed of the motor and make adjustments accordingly.
5. Are there any safety precautions I should take when adjusting the speed of an electric motor?
Yes, there are a few safety precautions to keep in mind when working with electric motors. Always make sure to disconnect power to the circuit before making any adjustments. Be aware of any potential hazards, such as exposed wires or moving parts, and use caution when handling them. It is also important to follow any safety guidelines provided by the manufacturer of the motor or components being used.
  • Electrical Engineering
  • DIY Projects
