Magnetic vector potential of infinite wire
In summary, the conversation discusses finding the vector potential at a distance r from an infinite straight wire carrying a current I. The traditional integral formula does not work in this case, so an alternative method is proposed using the relationship between B and A. However, there is some question about the correctness of this method and the direction of A in relation to the current. A solution is offered by extracting a finite part from the divergent integral, which is a common technique in dealing with infinite geometries. The relevant physics can still be extracted from the formally divergent integral, demonstrating the power of this methodology. Finally, the conversation touches on the gauge freedom of A and how it often points in the direction of the current in the Coulomb gauge. The conversation
siddharth
I don't know if this thread belongs in Introductory Physics or here, so please feel free to move it if you wish.
The question is
Find the vector potential a distance [itex] r [/itex] from an infinite straight wire carrying a current [itex] I [/itex]
I know that the vector potential can be given by
[tex] \frac{\mu_0}{4 \pi} \int \frac{I \vec{dl}}{r} [/tex]
The problem is that in this case, the wire goes to infinity. So that that doesn't work.
I tried it in another way. Since [tex] B = \nabla \times A [/tex] and the direction of A is generally the direction of the current, it reduces to
[tex] \left(\frac{d A_r}{dz} - \frac{ d A_z}{dr}\right) \hat{e_{\phi}} = \frac{\mu_0 I}{2 \pi r} \hat{e_{\phi}} [/tex]
ie,
[tex] \frac{d A_z}{dr} = -\frac{\mu_0 I}{2 \pi r} [/tex]
and
[tex] A = -\frac{\mu_0 I}{2 \pi} ln\left(\frac{r}{r_0}\right) \hat{e_z} [/tex]
Is that right? Also, how can we generally say that A is along the direction of the current?
No, it's fine here.
The question is
Yes, it does. The improper integral you would obtain does in fact converge.
ie,
and
Is that right?
I don't think so, but it looks like it's close. What's [itex]r_0[/itex]?
You needn't say that at all. Remember that the potentials are related to the physical fields via differential operators. That relationship affords you some gauge freedom. You can replace [itex]\vec{A}[/itex] with [itex]\vec{A}+\nabla\chi[/itex] provided that [itex]\chi[/itex] is continuously differentiable. You will get the same magnetic field, even if [itex]\nabla\chi[/itex] isn't in the direction of the current.
Does it?
Doing it that way, I get
[tex] A = \left(\frac{\mu_0 I}{4 \pi}\right) ln(\sec \theta + \tan \theta) [/tex]
where [itex] \theta [/itex] is the angle made between the lines joining the point where I'm finding the potential to the center of the wire and the ends.
So as [itex] \theta [/itex] goes to pi/2 or -pi/2, doesn't it diverge?
[itex] r_0[/itex] is some point where I have defined A to be 0.
Yeah, I understand. But the thing is, in most cases A in fact does point along the direction of the current.
Hi siddharth,
The integral defining A does indeed diverge, however it is possible to extract a finite part which produces the correct physics. Extracting the finite parts from such integrals is a fairly common technique for dealing with these infinite geometries.
In your case the integral you want to do (after a change of variables) is [tex] \frac{\mu_0 I}{4 \pi} \int^{\Lambda}_{-\Lambda} dz \frac{1}{\sqrt{\rho^2 + z^2}}, [/tex] which you can write as [tex]\frac{\mu_0 I}{2 \pi} \int^\Lambda_0 dz \frac{1}{\sqrt{\rho^2 + z^2}} = \frac{\mu_0 I}{2 \pi} \log{\left(\frac{\Lambda}{\rho} + \sqrt{1 + \frac{\Lambda^2}{\rho^2}} \right)} [/tex]. For large cutoff you can approximate the argument of the log as [tex] \frac{\mu_0 I}{2 \pi} \log{\left(\frac{2 \Lambda}{\rho} \right)} = - \frac{\mu_0 I}{2 \pi} \log{\left(\frac{\rho}{\rho_0}\right)} + \frac{\mu_0 I}{2 \pi} \log{\left(\frac{2 \Lambda}{\rho_0}\right)} [/tex]. Now look what has happened! Yes, the vector potential is formally infinite if you let the cutoff go to infinity, but all the physical results (magnetic field) are independent of the cutoff. You are able to extract the relevant physics from a formally divergent integral. Needless to say, this is a very powerful methodology that you will meet again and again as you progress through physics.
Also, the vector potential often points along the current because in the Coulomb gauge one has the formula [tex] \vec{A} = \frac{\mu_0}{4 \pi} \int d^3 x' \frac{\vec{J}(\vec{x}')}{|\vec{x}-\vec{x}'|} [/tex]. It's clear then that as long as the current points in one direction, A will point in that direction in the Coulomb gauge.
Hope this helps.
Likes weezy
That's fantastic!
I'm curious, why does it work? How come the relevant physics comes out so nicely?
Thanks a ton for your help.
siddharth said:
Does it?
I was wrong about that, as PM pointed out. You have to do some mathematical trickery that I had forgotten about (it's been a while).
As I said, that's a choice. You can choose the gauge that's convenient for you.
siddharth said:
That's fantastic!
Isn't it cool! Physics is so awesome.
What's going on is essentially a separation of different scales. As far as charged particles close to a long wire are concerned, it doesn't matter how long the wire is as long as it's very long. You could never figure out what the length of the wire is by performing local experiments. Since the length of the wire is unobservable, you might suspect that it enters the vector potential only as a pure gauge term. This suspicion is confirmed when you carry out the calculation, and you can easily check for yourself that is indeed possible to eliminate [tex] \Lambda [/tex] by choosing a different gauge. It is quite instructive to carry out calculations of this type for a variety of infinite geometries. You will find that the infinite geometry gives you some divergence, but the divergence is always unobservable. Such calculations give you glimpse of the very subtle and deep nature of field theory. It's all very beautiful stuff really.
FAQ: Magnetic vector potential of infinite wire
What is the magnetic vector potential of an infinite wire?
The magnetic vector potential is a mathematical vector field that describes the magnetic influence of a wire. In the case of an infinite wire, the magnetic vector potential is given by:
A = μ0I/2πr
where μ0 is the permeability of free space, I is the current in the wire, and r is the distance from the wire.
How is the magnetic vector potential related to the magnetic field?
The magnetic vector potential is related to the magnetic field by the equation:
B = &nabla x A
This means that the magnetic field is the curl (or rotational) of the magnetic vector potential.
Can the magnetic vector potential of an infinite wire be negative?
No, the magnetic vector potential of an infinite wire cannot be negative. This is because the permeability of free space and the current are both positive values, and the distance from the wire is always positive. Therefore, the magnetic vector potential will always be a positive value.
How does the magnetic vector potential of an infinite wire change with distance?
The magnetic vector potential of an infinite wire decreases with distance from the wire. This is because the equation for the magnetic vector potential (A = μ0I/2πr) shows an inverse relationship between the potential and the distance from the wire. As the distance increases, the potential decreases.
Is the magnetic vector potential of an infinite wire affected by the direction of the current?
Yes, the direction of the current in the wire affects the direction of the magnetic vector potential. The right-hand rule can be used to determine the direction of the potential, with the thumb pointing in the direction of the current and the fingers curling in the direction of the potential.
