maverick280857
- 1,789
- 5
Hello
I am teaching myself Quantum Mechanics from Griffiths. I have run into a mathematical problem which I need help with. As I have found no convincing answer, I am posting all the details here.
Ref :Section 1.5 (Momentum) in "Introduction to Quantum Mechanics (2nd Edition)" by David J Griffiths
[tex]\frac{d<x>}{dt} = \int_{-\infty}^{+\infty}
x\frac{\partial}{\partial t}|\psi|^2 dx=
\frac{i\hbar}{2m}\int_{-\infty}^{+\infty} x\frac{\partial}{\partial
x}(\psi^{*}\frac{\partial \psi}{\partial x}-\frac{\partial
\psi^{*}}{\partial x}\psi)dx[/tex] (1)
If we denote the integral by [itex]I[/itex] then
[tex]\frac{d<x>}{dt} = \frac{i\hbar}{2m}I[/tex] (2)
Integrating by parts,
[tex]I = x(\psi^{*}\frac{\partial \psi}{\partial
x}-\frac{\partial \psi^{*}}{\partial x}\psi)|_{-\infty}^{+\infty} -
\int_{-\infty}^{+\infty} \frac{\partial}{\partial
\psi^{*}}{\partial x}\psi)dx[/tex] (3)
The second term in (3) is easily handled based on the steps described on Page 28 (a second integration by parts). However, the first term in this equation is the troublesome term.
The expression in parentheses of the first term goes to zero as [itex]x\rightarrow \pm \infty[/itex]. As [itex]x \rightarrow \pm \infty[/itex] the first term in (3) is of the form [itex]\infty * 0[/itex]. This term would tend to zero as [itex]x \rightarrow \pm \infty[/itex] only if the terms in the parentheses were to go to zero faster than [itex]x[/itex] goes to [itex]\pm \infty[/itex].
The first term in (3) has been stated in the book to be equal to zero at [itex]x = \pm \infty[/itex] in its entirety. Is this because [itex]\psi(x,t)[/itex] is square integrable and must go to zero faster than [itex]1/\sqrt{|x|}[/itex] as [itex]|x| \rightarrow \infty[/itex] (as given in the footnote to section 1.4 on page 25)?
Or is this because all physically meaningful wavefunctions behave this way? Am I integrating correctly?
Mathematical Counterexample
If
[tex]f(x) = x^{-a}[/tex]
where [itex]1/2 < a < 1[/itex]
then
[tex]xf(x) = x^{1-a}[/tex]
and [itex]0<1-a<1/2[/itex] so as [itex]x\rightarrow \pm \infty[/itex], [itex]xf(x)[/itex] can tend to [itex]\pm \infty[/itex]. Of course I understand that [itex]f(x)[/itex] cannot be a wavefunction because it is discontinuous at [itex]x = 0[/itex]. This is just a counterexample.
Note to the Moderator: Please shift this post to the correct forum if this is not the right location.
If
then
