Painleve-Gullstrand coordinates
  • Thread starter pervect
  • Tags
    Coordinates
In summary: Otherwise it would be \frac{dr^2}{d tau^2} = - \left( 1+\frac {2m}{r} \right) \left( \frac{m}{r^2} \right) \left( \frac{dt}{d tau} \right)^2+{ \left( r+2\,m \right) \left( \frac{d phi}{d tau} \right)^2
pervect
Staff Emeritus
Insights Author
10,337
1,515
This came up in another thread. I thought I'd make a few notes about them.
It should be spelled Painleve, I can't edit the typo in the title :-(
Google finds http://www.physics.umd.edu/grt/taj/776b/hw1soln.pdf, which, being a homework solution, will probably disappear soon.
The line element is:
[tex]
-{d{{T}}}^{2}+ \left( d{{r}}+\sqrt {{\frac {2M}{r}}}d{{T}}
\right) ^{2}+{r}^{2} \left( {d{{\theta}}}^{2}+ \sin ^2
\theta d {{\phi}}}^{2} \right)
[/tex]
The following coordinate transformation will map PG coordinates into Schwarzschild coordinates:
[tex]
t = T -2\,\sqrt {2\,M\,r}+4\,M\,\mathrm{arctanh} \left(
\sqrt {{\frac {r}{2 \, M}}} \right)
[/tex]
[add]
arctanh(x) is defined only for x<1, while arctanh(x) = 1/2 (ln(1+x)-ln(1-x)), more work needs to be done to deal with the sign issues that arise when making x > 1.The above
The metric is not a function of T, therefore [itex]u_0 = g_{0i} u^i =[/itex] = (-1+2M/r) [itex]dT/d\tau[/itex] + sqrt(2M/r) [itex]dr/d\tau[/itex] = constant, a conserved energy-like quantity of the orbit.
Here [itex]u^i[/itex] is the 4-velocity [itex](dT/d\tau, dr/d\tau, d\theta/d\tau, d\phi / d\tau)[/itex]
Similarly, since the metric is not a function of [itex]\phi[/itex]
[itex]u_3 = g_{3i} u^i[/itex] = r^2 sin^2 [itex]\theta[/itex] [itex]d\phi / d\tau[/itex]= constant
representing a conserved angular momentum-like quantity of the orbit.
Generally, the orbit will be taken to be in the equatorial plane, [itex]\theta = \pi/2[/itex] and the above two conserved quantites plus the metric equation will be sufficient to calculate orbital motion.
OK, it looks like
[tex]
t = T -2\,M\sqrt {2}\sqrt {{\frac {r}{M}}}-2\,M\ln \left( \left| \sqrt {{\frac {r}{2\, M}}}-1 \right| \right) +2\,M\ln \left( \sqrt {{\frac {r}{2\,M}}}+1 \right)
[/tex]
works for the transformation between Schwarzschild and Painleve-Gullstrand inside & outside the horizon, t being Schwarzschld and T being Painleve.
Another source for the above info, including the conversion equation between Schw and PG:
http://arxiv.org/abs/gr-qc/0509030
less likely to go away and more complete than the homework solution (though it's only periphrial to the paper).
Another worthwhile note: the solution for r(tau), T(tau) from a free-fall at infinty:
let Tdot = [itex]dt/d\tau[/itex], rdot = [itex]dr/d\tau[/itex]
The energy equation says
(-1 + 2M/r) Tdot + sqrt(2M/r) rdot = constant
If Tdot = 1 (zero velocity) at r=infinty, this constant must be -1
The metric equation says
[tex]
\left( \sqrt{\frac{2M}{r}} Tdot + rdot \right)^2 - Tdot^2=-1
[/tex]
(just divide both sides of the Lorentz interval by ds^2, and note that [itex]d\tau^2 = -ds^2[/itex] to get the above eq).
Solving, the energy equation and the metric equation gives us the formula for rdot and Tdot. Taking the minus sign for rdot (for radially infalling particles), we get:
rdot = -sqrt(2M/r)
Tdot = 1
This can be integrated to find
[tex]
r = \left( \frac{9M}{2} \tau^2 \right) ^ \frac{1}{3}
[/tex]
and T = [itex]\tau[/itex]
We can further note that [itex]d^2 r / d\tau^2 = -M/r^2[/itex]
Because T=[itex]\tau[/itex], one can re-write r(tau) as R(T) in the above.
Solving the previous two equations, we have a quadratic in tdot = dt/dtau
[tex]
\frac{r-2 m}{2 m} tdot^2 - \frac{E r}{m} tdot + \frac{E^2 r}{2 m} + 1 = 0
[/tex]
This has two solutions. Any horizon crossing solution must satisfy
[tex]
\frac{dt}{d\tau} = {\frac {2\,m+{E}^{2}r}{Er+\sqrt {2}\sqrt {m}\sqrt {-r+2\,m+{E}^{2}r}}}
[/tex]
The form of the required solution is dicated by the fact that the coefficient of r^2 vanishes at r=2m, therefore we must use the 2c/... form of the solution of the quadratic, the ... / 2a solution will have a zero denominator at r=2m
For non-horizon crossing solutions
[tex]
\frac{dt}{dtau} = {\frac {Er+\sqrt {-2\,rm+4\,{m}^{2}+2\,m{E}^{2}r}}{r-2\,m}}
[/tex]
is a possible solution as well.
Sticking with horizon crossing solutions for the moment, we have
[tex]
\frac{dt}{dtau} = {\frac {2\,m+{E}^{2}r}{Er+\sqrt {2}\sqrt {m}\sqrt {-r+2\,m+{E}^{2}r}}}
[/tex]
and
[tex]
\frac{dr}{d tau} = -{\frac { \left( -2\,rm+4\,{m}^{2}+2\,m{E}^{2}r+Er\sqrt {2}\sqrt
{m}\sqrt {-r+2\,m+{E}^{2}r} \right) }{\sqrt {2 r m}
\left( Er+\sqrt {2}\sqrt {m}\sqrt {-r+2\,m+{E}^{2}r} \right) }}
[/tex]
When dr/dtau = 0, one might need to know d^2 r / dtau^2. Solving the geodesic eq directly when dr/dtau = 0 gives
[tex]
\frac{dr^2}{d tau^2} = - \left( 1-\frac {2m}{r} \right) \left( \frac{m}{r^2} \right) \left( \frac{dt}{d tau} \right)^2+{ \left( r-2\,m \right) \left(
[/tex]
note that the above DOES assume that dr/dtau = 0.
FAQ: Painleve-Gullstrand coordinates
What are Painleve-Gullstrand coordinates?
Painleve-Gullstrand coordinates are a coordinate system used in the study of general relativity. They are named after French mathematician Paul Painleve and Swedish physicist Oskar Gullstrand.
How are Painleve-Gullstrand coordinates different from other coordinate systems?
Painleve-Gullstrand coordinates are unique in that they are "slicing" coordinates, meaning they divide spacetime into a series of spacelike hypersurfaces. This allows for a more intuitive understanding of the geometry of spacetime.
What is the significance of Painleve-Gullstrand coordinates?
Painleve-Gullstrand coordinates are significant because they provide a way to visualize and analyze the curvature of spacetime in a more intuitive manner. They have been used in various studies of black holes and gravitational waves.
How are Painleve-Gullstrand coordinates related to the Schwarzschild metric?
The Painleve-Gullstrand coordinates are based on the Schwarzschild metric, which describes the curved spacetime around a non-rotating, spherically symmetric object (such as a black hole). However, the Painleve-Gullstrand coordinates provide a different perspective on the geometry of this spacetime.
Are Painleve-Gullstrand coordinates commonly used in scientific research?
Painleve-Gullstrand coordinates are not as commonly used as other coordinate systems, such as Schwarzschild or Kerr coordinates. However, they have been used in various studies of black holes and gravitational waves, and may be useful in certain situations where a more intuitive understanding of spacetime curvature is needed.
