Need Help with Central Forces? Let's Tackle These Physics Questions Together!
In summary: The first condition is so that the particle doesn't suddenly start orbiting in the opposite direction, since that would violate the conservation of angular momentum.In summary, the questions are as follows:-What is the equation of motion for a particle orbiting a central mass?-What is the relationship between the velocity of the orbiting particle and the central force?-What is the general solution to the equation of motion for a particle orbiting a central mass?-What is the particular solution to the equation of motion for a particle orbiting a central mass when r=3a?
Bunting
85
Hello
Im currently working my way back through a few past papers to ready myself for the new physics year, and was wondering if anybody could help me with a few puzzling questions that have me and my lecture notes stumped!
I have created a image file with my questions and how far I have got into each particular one - black indicates a question, blue something I think I understand (but feel free to correct me!) and red indicates where I am completele at a loss!
http://www.sweeto.org/wow/orbits.jpg
edit: by the way, if there's not enough working or whatever you would like to see there, then let me know and ill try fleshing it out a bit more.
Only thing I can see is that the constant h would have been uselessly defined by
[tex]h=\frac{L}{m}[/tex]
because what my notes tell me is that the radial part of the equation of motion in terms of the function [itex]u(\phi)[/itex] is
[tex]\frac{d^2u}{d\phi^2}+u=-\frac{m}{L^2u^2}f(1/u)[/tex]
[where L is the angular momentum of the orbiting particle (it is a constant of the motion if you choose the origin of your coordinate system to be where the inert mass is since a central force exerts no torque about the location of the inert mass)]
I wrote f(1/u) because initially, f is know as a function of r, and since r=1/u, the function f in terms of u is found by substituting all r by 1/u, hence f(1/u).
Derive a relationship between the velocity of the particle in a circular orbit of radius r=1 and f.
Your answer, the way you describe it, doesn't give the desired result. Yes, take the radial part of the equation of motion, yes, [itex]r''=0[/itex], but don't substitute [itex]\phi '[/itex] for h/r². Instead, SOLVE for [itex]\phi '[/itex] and subtitute THAT into v=r[itex]\phi '[/itex].
What condition must f satisfy for a circular orbit to be possible?
I would say that this is the only condition as well.
The rotation curve [...] how must the modified force depend on distance
You are supposed to have derived the relationship btw the velocity of the orbiting star in function of the central force 2 questions before. If you solve this equation for F=grav force, you would get that it predicts that for circular orbits,
[tex]v=\sqrt{\frac{-aF(a)}{m}}=\sqrt{\frac{GM}{a}}[/tex]
I.e. it predicts a continuous decrease of the velocity. We don't want that; we want the velocity to stabilize at large 'a'. If we add a constant term, it does that. The new term should be small at solar system scale, but large enough at galaxy scale to account for the large speed of the distant stars in a galaxy. So I would propose a modification of the type
[tex]F = -GMm \left( \frac{1}{r^2}+k \right)[/tex]
where k is very tiny such that for M = solar mass, kMm is negligible, but for M = mass of galaxy , kMm is a respectable constant that account for the large v of distant stars.
-----Editing LaTeX-------
Question 2
I think it just means, "write [itex] \vec{F} = m\vec{r}''[/itex]". But it doesn't mean to draw a graph, where did you get that idea? The Earth's atmosphere [...] circular orbit.
I don't get what these physicists were thinking. After the storm, the new orbit is an ellipse, and r=3a is its aphelie, so r'=0 there naturally! They don't have to exert no force to put its radial velocity to 0 "instanteneously"; it already is. The only way to restore the new orbit is by instantaneously restoring its angular velocity when the satellite is at r=3a.
By solving the equation [...] occur).
If we break down the equation of motion written in the last question into radial and angular part, we get the two ugly coupled following ode:
[tex]-\frac{\lambda}{r^2}-kr' = r''-r(\phi ')^2[/tex]
[tex]-kr\phi '=r\phi '-2r'\phi '[/tex]
Setting k =0, they become instead
[tex]-\frac{\lambda}{r^2} = r''-r(\phi ')^2[/tex]
[tex]0=r\phi '-2r'\phi '[/tex]
Now, we are told that the new angular momentum is half the old one: [itex]L_f = L_i/2[/itex]. Angular momentum in polar coordinates is simply [itex]L=mr^2\phi ' \Leftrightarrow (r\phi ')^2=L^2/(m^2r^3)[/itex]. So we can substitute [itex](r\phi ')^2[/itex] in our first equation for [itex](L_i/2)^2/(m^2r^3)[/itex] and it becomes
[tex]r'' = -\frac{\lambda}{r^2} + \frac{(L_i/2)^2}{m^2r^3}[/tex]
which is an equation for r only, hurray. Now, we assume that r can be written as a function of phi, and we make the good old substitution r=1/u. Now the equation is just that of a forced harmonic oscillator:
[tex]\frac{d^2u}{d\phi^2}+u=-\frac{m\lambda}{(L_i/2)^2}[/tex]
It's an inhomogeneous ode of second order with constant coefficient, so the general solution is just the solution of the associated homogeneous equation + a particular solution of the inomogeneous one. The homogeneous equation associated is just that of an harmonic oscillator of unitary angular frequency:
[tex]\frac{d^2u}{d\phi^2}+u=0[/tex]
We know the general solution to be [itex]Acos(\phi + \phi_0)[/itex].
Meanwhile, an obvious particular solution to [itex]\frac{d^2u}{d\phi^2}+u=-\frac{m\lambda}{(L_i/2)^2}[/itex] is just [itex]u=-\frac{m\lambda}{(L_i/2)^2}[/itex], making the general solution
[tex]u(\phi) = -\frac{m\lambda}{(L_i/2)^2}+Acos(\phi + \phi_0)[/tex]
Choose a coordinate system such that when r=3a, [itex]\phi = 0[/itex]. Then you have the "initial" conditions
[tex]u(0)=\frac{1}{3a}[/tex]
[tex]\frac{du}{d\phi}(0)=0[/tex]
The second condition is because when the orbit was a circle of radius r=3a, [itex]\frac{du}{d\phi}[/itex] was always 0 (otherwise the orbit would not be a circle).
From these, you can find A and [itex]\phi_0=0[/itex].
Hopefully, you've seen this derivation before and you know that in general, the orbit can be either an ellipse, a circle, an hyperbolea or a parabola depending on the energy of the particle (ellipse corresponding to lowest energy, circle higher even, hyperbolea higher even and parabola highest). We know that initially, the orbit was a circle (which is a kind of ellipse). Then rose the atmosphere which induced friction on the satellite, exerting negative work on it and thus diminishing its total mechanical energy. So the new orbit will necessarily be an ellipse, with the inert mass located at one of the foci!
Hopefully, you also know that the equation of an ellipse of half major axis b (along the x axis), semi minor axis [itex]\sqrt{a^2-(a\epsilon)^2}[/itex] and focal distance [itex]2b\epsilon[/itex] in polar coordinates is
[tex]\frac{1}{r} = \frac{1}{b(1-\epsilon^2)}+\frac{\epsilon}{b(1-\epsilon^2)}cos(\phi)[/tex]
(with [itex]0 \leq \epsilon \leq 1[/itex] [the circle corresponds to the limiting case [itex]\epsilon = 0[/itex]])
Compare the general equation of the ellipse with your general solution for u and solve for [itex]\epsilon[/itex] and b. Now you have all you need to draw the ellipse. Finally, the last question is to determine wheter in this new orbit, the satellite will be further influenced by the atmosphere. This is equivalent to asking "is the perhelie of the orbit lesser than 'a'?", right? The perihelie is defined as the point of the orbit closest to the inert mass. So it is a minimum of the function [itex]r(\phi)[/itex] and thus a max of [itex]u(\phi)[/itex]. Find it. Is it greater than 'a'? If so, great, the satelite won't fall on our heads! (Not until the next freak solar storm at least. :smile:)
Wow, that was a very detailed answer, I was only looking for a pointer in the right direction but thanks :) It'll take me a while to wade through it all but I had a few questions to the previous posters first as a responce! (oh, it was all you! jeepers!)...
h - I am really looking for the physical interpretation of this - or in this case would the physical interpretation be specifically what the equation suggests? i.e. Angular Momentum per unit mass.
Ok, so i tried "solving" for this and came out with v = sqrt ( -rF / m ) which would seem wrong. I got this by simply rearranging radial eom ( r'' - r*phi'^2 = F / m ) to give me the phi' on its own then bunged that into v = r phi'. As this creates either non numbers or complex numbers I am guessing somewhere along my line of working I've misinterpreted your meaning of "solve" :) edit: just re-read your next post and see that you got exactly the same - I hate to be a burden but do you understand how this works ? edit2: attactive forces are relatively negative in this sense. doh!
I see what you mean and managed to follow your working, though I am going to do a bit of reading up on the equation and how it works before I comment further being as I don't specifically see the significance of GmM further than what each of the respective symbols stand for and mean. Feels a bit harsh having this as a 1 mark answer though :(
The next bit will take me a while, but thanks very much for your replies - sorry it took so long to reply back to here (I work a lot :)) but I really do appreciate it :)
The significance is this: Newton, after defining "force" by equating it with ma, discovered that in order to satisfy the celestial observations, the gravitationnal force btw two bodies would have to be proportional to the product of their masses, inversely proportional to the square of the distance btw them, and all that multiplied by a constant G which would take care or producing the observed acceleration and adjusting the units of the force to [kg m/s²]. He also noted that the force was attractive so he threw a "-" sign in there.
Well this might not be exactly how Newton himself tought, but that is how someone would proceed today if he wanted to re-invent Newtonian gravity. In any case, I wouldn't "waste" time too much thinking about the "physical significance" of GMm.
Same thing for h. It is the angular momentum per unit mass. Or, since [itex]\vec{L} = m(\vec{r} \times \vec{v})[/itex], you can call h the moment of velocity.
small correction: indeed the hyperbolic orbit is of greater energy than the parabolic one!
FAQ: Need Help with Central Forces? Let's Tackle These Physics Questions Together!
What are central forces?
Central forces are a type of force that acts between two objects and always points towards a fixed point, known as the center. Examples of central forces include gravitational and electrostatic forces.
What is the difference between central and non-central forces?
The main difference between central and non-central forces is that central forces always act towards a fixed point, while non-central forces can act in any direction. Another difference is that central forces do not depend on the relative orientation of the two objects, while non-central forces do.
What are some examples of central forces?
Examples of central forces include the gravitational force between the Sun and planets in our solar system, the electrostatic force between an electron and a proton in an atom, and the magnetic force between two magnetic poles.
How do central forces affect the motion of objects?
Central forces cause objects to move in circular or elliptical paths around the center point. This is because the force always acts towards the center, causing the object to continuously change direction and move in a curved path.
Can central forces be repulsive?
No, central forces are always attractive in nature. This means that they always pull objects towards the center and never push them away. Repulsive forces are considered non-central forces.
