Commutators and physical interpretation
In summary, the conversation discusses the relationship between measurable quantities and their commutator, specifically when the commutator is not equal to zero. This implies that the uncertainties of the two measurements are not independent and thus cannot be measured simultaneously. This concept is known as the Heisenberg Uncertainty Principle and has significant physical implications.
vsage
An interesting question was posed, and since I have many problems of this type I'll just make the question general:
Suppose you have operations A and B, if [A, B] != 0, then what can you conclude about a simultaneous measurement of A and B? For example, if A was momentum in the x direction's operator and B was the position operator, what does a nonzero commutator mean?
The best answer I can guess is that depending on which operator is done first, the result will be different and therefore a simultaneous operation to get the information from both operators is impossible, or more accurately gives physically meaningless or incorrect results. Thoughts?
Since the commutator of measurable quantities commutes, then we are able to measure both quantities simultaneously. On the other hand, when the commutator between measurables does not commute we are unable to measure both with any certainty. The famous Heisenberg Uncertainty Principle (HUP) is exactly this statement regarding position and momentum. If I remember correctly, the result of the HUP is actually just a mathematical fact, but has profound physical significance.
xman is correct. The commutator defines the uncertainty in the two measurements; specifically, the product of the uncertainties of each measurement. If the commutator is zero, the uncertainty of each variable is zero and so both can be measured with complete certainty simultaneously.
If the commutator is not zero (say as in your example), the uncertainty in position can be expressed as the commutator divided by some arbitrary uncertainty in momentum. If you give the momentum an uncertainty of zero, the uncertainty of position becomes infinite and so you have no idea where the particle is; and vice versa.
Duely noted. I sort of understood the answer but was unsure of how to articulate it correctly. Thanks for the insights.
FAQ: Commutators and physical interpretation
What is a commutator in physics?
A commutator in physics is a mathematical operator that represents the difference between two physical quantities. It is used to describe how two observables interact with each other and is an essential tool in quantum mechanics.
What is the physical interpretation of a commutator?
The physical interpretation of a commutator is that it represents the degree to which two observables do not commute with each other. In other words, it describes the extent to which the order of measurements of two observables affects the final result.
How is a commutator calculated?
A commutator is calculated by taking the product of two operators and subtracting the product of the same operators in reverse order. Mathematically, it can be represented as [A, B] = AB - BA.
What is the significance of a non-zero commutator?
A non-zero commutator indicates that the two observables do not commute with each other, and their measurements will be affected by the order in which they are measured. This is a fundamental concept in quantum mechanics and plays a crucial role in understanding the behavior of particles at a microscopic level.
Can commutators be used to make predictions in experiments?
Yes, commutators can be used to make predictions in experiments. By understanding the commutator of two observables, scientists can determine the order in which they should be measured to obtain accurate results. Commutators also help in predicting the behavior of particles in quantum systems and are an essential tool in theoretical physics.
