Calculating Probability of Simple Harmonic Oscillator in Phase Space
A+δA)^2-(mwA+δ(mwA))^2]Simplifying, we get:πA√(A^2-x^2)δA/2Therefore, the probability of the oscillator being between x and x+dx is given by:P(x)dx = (πA√(A^2-x^2)δA/2)/(πA√(A^2-x^2)δA/2) = 1/π√(A^2-x^2)dxIn summary, the probability of the oscillator being between x and x+dx is given by P(x)dx = 1/π√(A
quasar987
32
Consider a simple harmonic oscillation in 1 dimension: x(t)=Acos(wt+k). If the energy of this oscillator is btw E and E+[itex]\delta E[/itex], show that the probability the the position of the oscillator is btw x and x+dx is given by
[tex]P(x)dx=\frac{1}{\pi}\frac{dx}{\sqrt{A^2-x^2}}[/tex]
Hint: calculate the volume in phase space when the energie is btw E and E+[itex]\delta E[/itex] and when the position is btw x and x+dx, and compare this volume with the total volume when the oscillator is anywhere but in the same energy interval.
For a given energy E, it's easy to see that the path of the oscillator in phase space is an ellipse of semi axes A and mwA.
I could write the semi axes of the ellipse representing the energy E and E+[itex]\delta E[/itex] by A+[itex]\delta A[/itex] and (m+[itex]\delta m[/itex])(w+[itex]\delta w[/itex])(A+[itex]\delta A[/itex]) but I fear that would not be very practical... :/
I could then find an expression for the difference in area of the 2 ellipses as a function of x, differentiate that, multiply by dx and finally divide by the total difference in area of the 2 ellipses and I would be done.
Actually I already tried that with the case where only A was "allowed" to vary and not m or w, and it did not work. So I'm very much open to any suggestion!
Thank you for your post and for considering the simple harmonic oscillator in 1 dimension. The probability of the oscillator being between x and x+dx can be calculated by looking at the phase space volume for the given energy interval.
To start, let's consider the phase space volume for the oscillator when it is at energy E. As you mentioned, this volume is an ellipse with semi-axes A and mwA. The total area of this ellipse is given by πA√(A^2-x^2). Now, when the energy is varied by a small amount δE, the semi-axes of the ellipse will change by δA and δ(mwA). Therefore, the new area of the ellipse will be given by π(A+δA)√[(A+δA)^2-x^2]. Similarly, the phase space volume for the oscillator at energy E+δE will be given by π(A+δA)√[(A+δA)^2-x^2].
Now, to find the probability of the oscillator being between x and x+dx, we need to calculate the difference in area between the two ellipses at energies E and E+δE. This difference in area will be given by:
π(A+δA)√[(A+δA)^2-x^2] - πA√(A^2-x^2)
Expanding the terms and keeping only the first-order terms in δA, we get:
π(√(A^2-x^2) + δA/2) - πA√(A^2-x^2)
πA√(A^2-x^2)δA/2
Now, to find the probability of the oscillator being between x and x+dx, we need to divide this difference in area by the total volume of the phase space, which is given by the area of an ellipse with semi-axes (A+δA) and (mwA+δ(mwA)). The total area of this ellipse is given by:
π(A+δA)√[(A+δA)^2-(mwA+δ(mwA))^2]
Again, expanding the terms and keeping only the first-order terms in δA, we get:
FAQ: Calculating Probability of Simple Harmonic Oscillator in Phase Space
What is a simple harmonic oscillator?
A simple harmonic oscillator is a system that experiences a restoring force that is directly proportional to the displacement from its equilibrium position. This type of system is found in many physical phenomena, such as a mass attached to a spring or a pendulum swinging back and forth.
What is phase space?
Phase space is a mathematical concept that represents all possible states of a system. In the context of a simple harmonic oscillator, phase space is a two-dimensional space that shows the position and momentum of the oscillator at any given time.
How do you calculate the probability of a simple harmonic oscillator in phase space?
The probability of a simple harmonic oscillator in phase space can be calculated using the Wigner function, which is a mathematical representation of the quantum state of a system. The Wigner function takes into account both position and momentum to determine the probability of finding the oscillator at a specific point in phase space.
What factors affect the probability of a simple harmonic oscillator in phase space?
The probability of a simple harmonic oscillator in phase space is affected by the temperature of the system, the properties of the oscillator (such as mass and frequency), and the initial conditions of the system. Additionally, any external forces acting on the oscillator can also affect its probability in phase space.
Why is calculating the probability of a simple harmonic oscillator in phase space important?
Calculating the probability of a simple harmonic oscillator in phase space is important because it allows scientists to understand and predict the behavior of these systems. This information can be applied to various fields, such as quantum mechanics, statistical mechanics, and thermodynamics, to study and explain the behavior of physical systems.
