INTRO TO PHYSICS: Impedence, pitch, vibration, reasonance
In summary: The mass of the string. As the mass of the string gets bigger, the waves move slower and the pitch gets lower.3. After playing a long piece of music, the pitch of the string in a violin will be lower.Why does the pitch change?You can adjust the violin so that it plays the correct pitch.
Dunkaroos
EASY STUFF: Impedence, pitch, vibration, reasonance... Please Help!
I would really appreciate it if you guys could take a look at these problems I have difficulty with. Thanks a lot. My answers are in red.
1. As impedance decreases, frequency decreases?
2. For the vibration spectrum (of frequency and amplitude) of a plucked spring, why are there spaces between the lines? Why are most frequencies zero amplitude?
What can you do to adjust the violin so it plays the correct pitch?
4. Why does our voice sound different when we have a cold? Sinuses are stuffed. But how can this be explained by physics?
5. Identify if the following situations are Forced Vibration or Reasonance:
1. The sounding board of a piano makes the sound louder. forced
2. A piano strikes a chord and breaks a dish in the next room. resonance
3. One barking dog causes the doorbell to ring, but another does not. resonance
4. An earthquake can cause the dishes onn your shelves to vibrate. forced
5. Sometimes, if the wind instruments hit a particular note, the snare (a metal attachment) on the snare drum will begin to hum. forced
6. In a flight, you can permanently deafen someone by hitting both of his ears simultaneously with your open hands. Explain.
No one? :rolleyes:
no need to answer all
every little bit would be appreciated
thanks. o:)
1. Is correct - Impendanace and frequency are directly related
4. Your voice sounds different because your vocal cords swell changing the vibractions. http://www.entnet.org/healthinfo/throat/Your_voice.cfm Found that to be pretty interesting if you would like to know more about the subject.
About #1...
Let Impedance =Z
p==pressure
v=velocity
Z = p/v and v=f(lamda)
So Z= p / (f(lamda))
Isn't Impedance inversely proportional to frequency?
bumpy bump bump
If the string (or spring?) is fixed at both ends it can't vibrate in any old way, but only in a linear combination of eigenmodes with frequencies that are integer multiples of some fundamental frequency.
[\QUOTE]
The pitch is related to the speed at which the waves propagate. What determines this speed?
FAQ: INTRO TO PHYSICS: Impedence, pitch, vibration, reasonance
What is impedance in physics?
Impedance is a measure of the opposition to the flow of an alternating current (AC) in a circuit. It is represented by the symbol Z and is measured in ohms (Ω). In simple terms, it is the total resistance to the flow of electricity in a circuit, which includes resistance, inductance, and capacitance.
How is pitch related to physics?
Pitch is a perceptual property of sound that is related to the frequency of the sound wave. In physics, pitch is directly proportional to frequency, meaning that as the frequency of a sound wave increases, the pitch also increases. This is because our ears perceive higher frequencies as higher pitches.
What is vibration in the context of physics?
In physics, vibration refers to the rapid back-and-forth motion of an object or medium. This motion can be described in terms of frequency (the number of vibrations per second) and amplitude (the size of the vibrations). Vibration is an important concept in understanding various phenomena in physics, such as sound, light, and electricity.
How does resonance occur in physics?
Resonance is a phenomenon that occurs when an object is subjected to a periodic force that has a frequency equal to its natural frequency. This results in a large amplitude oscillation of the object. In physics, resonance can be observed in various systems, including mechanical, electrical, and acoustical systems.
What is the reasonance effect in physics?
The resonance effect in physics refers to the amplification of a vibration or oscillation of a system that occurs when the system is driven at its natural frequency. This effect can be seen in various systems, such as musical instruments, where the natural frequency of the instrument is amplified to produce a louder sound. It is also an important concept in the study of waves and other phenomena in physics.
