Can Tabular Integration Be Used for Integrating Functions That Go to Zero?
  • Thread starter b2386
  • Tags
    Integrate
In summary, integrating a function of the form x^2e^{-b^2x^2}dx can be simplified to 2\int_{0}^{\infty} x^2e^{-b^2x^2}dx by utilizing the fact that the function is even. Integration by parts can also be used, but there is a faster method using a trick with polar coordinates. This trick involves setting u = b²r² and using tabular integration.
b2386
35
How do I integrate this? It is not of any form with which I am familiar.
[tex]\int_{-\infty}^{\infty}x^2e^{-b^2x^2}dx[/tex]
[tex]\int_{-\infty}^{\infty}x^2e^{-b^2x^2}dx = 2\int_{0}^{\infty} x^2e^{-b^2x^2}dx [/tex] because the function is even.
Then use integration by parts.
Thanks for the replies.
hmmm...
Quasar, could you please explain the steps in your link. I looked over it but do not fully understand what is going on. Let's start here: [tex] \int_{-\infty}^{\infty} e^{-\frac{x^2}{2\sigma^2}} = \sqrt{2 \pi \sigma^2} [/tex]
How do we know this?
By parts it's u=x, dv=xexp{...}dx
Of course if you do not know a priori that
[tex] \int_{-\infty}^{\infty} e^{-\frac{x^2}{2\sigma^2}} = \sqrt{2 \pi \sigma^2} [/tex],
this complicates things, as you won't be able to do the integral by parts either. Is this for a QM course? In this case, it is probably assumed that you know the result of the above integral. If you don't and want to know how to do it, here it is roughly. It's a beautiful and ingenious trick, watch. If I remember correctly, it goes like...
[tex] \int_{-\infty}^{+\infty} e^{-b^2 x^2}dx=\sqrt{\left( \int_{-\infty}^{+\infty} e^{-b^2 x^2}dx \right)^2} = \sqrt{\left( \int_{-\infty}^{+\infty} e^{-b^2 x^2}dx \right)\left( \int_{-\infty}^{+\infty} e^{-b^2 y^2}dy \right)}=\sqrt{ \int_{-\infty}^{+\infty}\int_{-\infty}^{+\infty} e^{-b^2( x^2+y^2)}dx dy }[/tex]
Now switch to polar coordinates: r²=x²+y², [itex]dxdy=rdrd\theta[/itex] r going from 0 to infinity, theta going from 0 to 2pi [in order to cover the whole R² plane]:
[tex]\int_{-\infty}^{+\infty} e^{-b^2 x^2}dx = \sqrt{\int_{0}^{+\infty}\int_{0}^{+2\pi} re^{-b^2( r^2)}dr d\theta }=\sqrt{2\pi\int_{0}^{+\infty}re^{-b^2( r^2)}dr}[/tex]
Set u=b²r² ==> du=2rb²dr ==>rdr=du/2b²:
[tex]\int_{-\infty}^{+\infty} e^{-b^2 x^2}dx=\sqrt{\frac{\pi}{b^2}\int_{0}^{+\infty}e^{-u}du} = \sqrt{\frac{\pi}{b^2}\left[-e^{-u}\right]_0^{+\infty}}= \sqrt{\frac{\pi}{b^2}\left[0-(-1)\right]} = \sqrt{\frac{\pi}{b^2}}[/tex]
Phew that was longer than I tought it would be!
Tabular integration is the easiest method here. when you think your gunna use integration by parts, if one of the functions (when differentiated many times) goes to zero, then tabular integration will work. just look it up. its easy enough to understand
FAQ: Can Tabular Integration Be Used for Integrating Functions That Go to Zero?
How do I integrate data from multiple sources?
To integrate data from multiple sources, you can use a variety of methods such as data merging, data blending, or data warehousing. These methods allow you to combine data from different sources into one cohesive dataset.
What is the best approach for integrating new data into an existing system?
The best approach for integrating new data into an existing system depends on the type of data and the system itself. Some common methods include manual data entry, batch processing, or real-time data streaming. It is important to carefully consider the data and system requirements before deciding on an approach.
How can I ensure data integrity during the integration process?
Data integrity can be ensured by using data validation techniques, such as data cleansing and data quality checks. It is also important to have a well-defined data integration process and to regularly monitor and maintain the data to ensure accuracy and consistency.
What are the benefits of using an integration platform?
An integration platform provides a centralized and standardized approach to data integration, making it easier to manage and maintain data from various sources. It also allows for automation and scalability, reducing the time and effort required for integration tasks.
How do I choose the right integration tool for my project?
When selecting an integration tool, it is important to consider factors such as your data sources, data volume, integration complexity, and budget. You should also research and compare different tools to find one that best fits your specific project needs.
