- 2,750
- 8
Given simple apparatus, how could I detect an intermittent misfire on a spark ignited internal combustion engine?
Novel ideas are welcome!
Danger said:Hmmm... then; just hmmmm...
What about replacing your exhaust runner thermocouples with pressure sensors? Would a fired cylinder have higher exhaust pressure as well as temperature? Or would backpressure from other cylinders mess it up?
I'm just free-wheeling now, guys.
Any chance of X-raying the thing while it's running, or would that be useless?
brewnog said:Thanks for all the great responses guys.
Mech Engineer; thanks for the links! I had no idea those AFR systems were so responsive, I might have a chat with one of the reps.
Danger, good idea with the pressure transducers too, I'll try and have a play.
Wooly, I can't say too much but with this application the fuel side could indeed be a problem! I'm reasonably certain it's not spark or timing, since this system is well proven. It better not be blowby with the amount of time the engine has run!
Thanks for all the help chaps.
Innovate LC-1 Documentation said:6.5.1 Advanced output programming
The normal state of the analog outputs is to update the outputs every time the LC-1 takes a new measurement. The LC-1 is fast enough to distinguish individual pockets of exhaust gas. For many applications this will be too fast. The advanced programming allows to set the analog out
update speed.
The most common signs of an intermittent misfire include a rough idle, hesitation or jerking while accelerating, and a decrease in engine power. You may also notice the check engine light turning on.
An intermittent misfire on a spark can be caused by a variety of factors, including faulty spark plugs, a clogged fuel injector, a damaged ignition coil, or a malfunctioning engine sensor.
To diagnose an intermittent misfire on a spark, you can use a diagnostic tool to scan for error codes, visually inspect the spark plugs and ignition components, and perform a compression test to check the health of the engine.
Yes, an intermittent misfire on a spark can cause damage to your car if left untreated. It can lead to decreased fuel efficiency, engine damage, and even failure of the catalytic converter.
To prevent an intermittent misfire on a spark, it is important to regularly maintain your vehicle by replacing spark plugs and ignition components as recommended by the manufacturer. Additionally, using high-quality fuel and keeping up with oil changes can also help prevent misfires.
