Scalar Gravitational Theory with Variable Rest Mass
The discussion centers on a new gravitational theory that proposes a scalar potential relation affecting rest mass, which aligns with General Relativity (GR) predictions in weak fields but diverges significantly in strong fields, particularly at the Schwarzschild boundary where rest mass approaches zero. This theory suggests that instead of black holes, massive objects could convert mass into gamma rays. Critics raise concerns about the mathematical validity of the proposed equations, particularly the interpretation of tensors and energy conservation assumptions. The conversation also touches on the distinction between inertial and gravitational mass, indicating potential differences in how mass interacts with gravitational fields. Overall, the theory presents an alternative view on gravitational dynamics, inviting further scrutiny and discussion.
How do you find this paper?
  • Bad theory badly developed
    Votes: 0 0.0%
  • Bad theory ok development
    Votes: 0 0.0%
  • Good theory poorly developed
    Votes: 0 0.0%
  • Good theory ok development
    Votes: 0 0.0%
  • Total voters
dtfroedge
ABSTRACT
In this paper we will present the mechanical dynamics of a gravitational system resulting from a specific, rest mass, scalar potential relation, that is equivalent in predicting orbital and photon motion to that of General Relativity in the weak field solutions. The weak solutions of General Relativity do not appear to be contradicted by this development, and in this range the physical difference may not be measurable. The strong field solutions will be significantly different, however since, in this scalar relation, the rest mass goes to zero at at Scwarzschild boundary. The consequences of the mass dependence gravitational potential results, for large masses, not in the prediction of black holes, but rather mass to Gamma ray converters.
Revised version
Due to the helpful input of several readers this paper has gone through a series of revisions, the latest of which is located at:
http://www.arxdtf.org/css/grav2.pdf
The math in this paper has been gone through multiple times by myself and others, but errors are not inconceivable. The most notable differences in this paper with GR are in the predicted properties of black holes, and should be the most likely avenue of success or crash for the paper.
Technical does not mean sensible
Hello:
Equation 1 looks like nonsense to me. In standard GR, we have a few well defined tensors.
The Riemann curvature tensor:
R^{\alpha}_{\beta \mu \nu}
The Ricci tensor, a contract of the Riemann curvature tensor:
R_{\mu \nu}
The Ricci scalar, a contract of the Ricci tensor:
R
The metric tensor
g_{\mu \nu}
And the stress energy tensor:
T_{\mu \nu}
One starts with the Hilbert action:
S = \int \sqrt{-g} d^4 x R
and by varying this action with respect to the metric tensor, one gets three terms. One of these is zero (I think it is the boundary of a boundary term based on a theorem by Gauss). The result is the Einstein field equations:
R_{\mu \nu} - \frac{1}{2}g_{\mu \nu}R= 8 \pi T_{\mu \nu}
As I vaguely understand it, should you choose not to work with the Ricci scalar, it can in a way be moved over to the other side of the equation.
Anyway, that is a brief description of the road to the Einstein field equations.
Here is equation 1, taken directly from the paper:
R^t_t = 8 \pi (T^t_t - T)
By Einstein's summation convension, the left hand side should just be the Ricci scalar, and the right hand side should be zero. The Ricci scalar can equal zero, but that is not too interesting. At this point I stop reading.
doug
I found this a bit difficult to follow. Do you use Newton's definition of the grav field to calculate \alpha ? What is \mu ?
We will take Eq.(3) to be the defining relation for the motion of the particles in the system, and presume that the total energy of a particle in a conservative system to be constant.
(my emphasis) Conservation of energy should be guaranteed, not assumed.
You do not mention inertial vs gravitational mass. I think you might be saying that the mass which generates the field is different from the mass that 'feels' the field.
I don't think it's right, but it is interesting to see another theory of gravity.
sweetser said:
Hello:
doug
sweetser:
Apologies and thanks for the 1/2 typo which has been corrected.
R^t_t = 8 \pi (T^t_t - 1/2T)
This historical reference to negative Komar mass is on well worked out physics available in most texts, and I didn't think the notatio needed to be that precise, I just used the short notation used by Ansorg in the paper cited.
http://arxiv.org/PS_cache/gr-qc/pdf/0607/0607091v2.pdf
My apologizes if it triggered misgivings.
\mu is just the gravitationla radius Gm/c^2
The presumption is that particle energy
mc ^{2} = m_{\o}c^{2} + G M m/r = m _{\o}c^{2} +1/2mv}^{2} =constant
, is not the normal assumption. The normal assumption is that gravitational energy is being contributed by the gravitational field as the particle decends. The present presumption is that the total particle energy is constant, with no contribution by the field. The source of the kinetic energy being extracted from the loss of the rest mass
I do not have a good working knowledge of physics yet. I tried to piece this together but after researching this, I couldn’t figure out the correct laws of physics to combine to develop a formula to answer this question. Ex. 1 - A moving object impacts a static object at a constant velocity. Ex. 2 - A moving object impacts a static object at the same velocity but is accelerating at the moment of impact. Assuming the mass of the objects is the same and the velocity at the moment of impact...
  • · Replies 17 ·
