Maximizing Garden Area with Algebra: Step-by-Step Solution
  • Thread starter MM92
  • Tags
    Algebra
In summary, Melissa plans to put a fence around her rectangular garden. She has 150 feet of fencing material to make the fence. If there is to be a 10 foot opening left for an entrance on one side of the garden, what dimensions should the garden be for maximum area? This question has to be answered in vertex form. For a parabola, the vertex is the point where the y-coordinate and the x-coordinate meet (h,k). To find the dimensions of a standard parabola, you would take the slope intercept form of the equation of a line (x-h)^2 + (y-k)^2 = r^2
MM92
Hi everyone, I am new to this site. I was wondering if anyone here can help me answer a question, in order for me to study correctly for my math test tomorrow.
Here's the question:
If anyone can answer this and explain it step by step to me that would be great!:smile:
You have to show some at least some attempt at doing it yourself before anybody can help you.
This is what I tried so far:
2L+2W=150ft.- 10ft. / = divide
2L+2W=140ft.
2W/2=140ft-2L/2
W=140ft-L
A=LW
A=L(140ft.-L)
A=140-L*squared
A(L)=-L*squared+ 140L
Hold on. Let's go back up here:
2L+2W=150ft.- 10ft.
2L+2W=140ft.
2W/2=140ft-2L/2
W=140ft-L
for a second. There is something wrong here. If you divide 1 term by 2, you must divide ________ terms by 2. There is also something else wrong here.
You are told you originally have 150ft of fencing material. You want to leave a 10ft opening for the door. Does the door require any fencing material? I think you need to look at what the definition of a perimeter is again. Find out what exactly we are doing by going 2L + 2W.
Well I assume you have to find the largest rectangular area. As KoGs has said there are a few flaws in your original equation. The actual perimeter will be 160 feet as you have 150 feet of fencing plus a 10 foot opening for a drive or whatever.
You will have:
[tex] 2L + 2W = 160[/tex]
[tex] L+W= 80[/tex]
Now
[tex] A= LW[/tex]
So you need to arrange your equation for perimeter to get rid of one of these terms.
[tex] W=80-L[/tex]
therefore [tex]A=L\times (80-L) = -L^2+80L [/tex]
Now you have to solve for the vertex which will maximise the area and the length. I will give you the equation and leave the rest to do for yourself.
[tex] h = \frac{-b}{2a} [/tex]
where a & b are the coeficients in the above quadratic equation.
h=-b/2a is not allowed by my teacher. She said I have to put it in vertex form which I don't know how to.
Complete the square
A = 80L - L^2.
A = -1( L^2 - 80L)
A= -1 (L^2 - 80L +1600) +1600
//note it's +1600 at the end because we have to multiply it by -1.
So we are left with:
A = -1(L - 40)^2 +1600.
Now it's clear to see that to maximize A, we have to minimize the -1(L - 40)^2 term. Which of course means L = 40.
//and in fact this also even gives us what the maximum area is, namely 1600.
Now we have L, we plug that back into our perimeter formula to get W.
I'm confused what your teacher means by vector form. Vectors are used to represent positions. But we do not have a single position, what we have is a rectangle.
haha oh Vertex form.
Well what points make our Area maximum, and what points make our Area minimum?
And in fact that is vertex form what I have.
A = -1( L - 40)^2 + 1600 IS vertext form.
Does it remind you of something?
hint: equation of a straight line.
y = mx + b.
Now what does an equation of a parabola look like?
So the answer would be the dimensions equal 40by40
A parabola would include the axis of symmetry and the vertex right?
Pretty much, the standard (vertex) form of a parabola is like the slope intercept form of a line
y-k = a(x-h)^2 where (h,k) is the vertex. The x coordinate of the vertex in a standard parabola IS the axis of symmetry
It somewhat resembles a circle equation, too. You can graph a parabola easily just by looking at the standard form
(x-h)^2 + (y-k)^2 = r^2 (equation of a circle)
Related to Maximizing Garden Area with Algebra: Step-by-Step Solution
1. What is algebra and why is it important?
Algebra is a branch of mathematics that deals with symbols and the rules for manipulating these symbols to solve problems. It is important because it helps us understand and solve real-world problems, and is the foundation for more advanced mathematical concepts.
2. What is the difference between algebra and arithmetic?
While both algebra and arithmetic deal with numbers and mathematical operations, algebra involves the use of symbols and variables to represent unknown quantities, while arithmetic focuses on specific numbers and their relationships.
3. What are the basic operations in algebra?
The basic operations in algebra are addition, subtraction, multiplication, and division. These operations are used to manipulate and solve equations and expressions.
4. How do I solve algebraic equations?
To solve an algebraic equation, you need to isolate the variable on one side of the equation by using the inverse operation of the given operation. This means that if the variable is being added, you subtract it from both sides. If it is being multiplied, you divide it from both sides.
5. Can algebra be applied in real life?
Yes, algebra has a wide range of applications in real life. It is used in fields like science, engineering, economics, and more to solve problems and make predictions. For example, algebra can be used to calculate the trajectory of a rocket or to determine the cost of a product based on production and sales data.
  • General Discussion
