Fallen Seraph
- 33
Does gravitational mass increase as inertial mass does in relativistic situations? Or does GR make this idea irrelevant?
Fallen Seraph said:Does gravitational mass increase as inertial mass does in relativistic situations? Or does GR make this idea irrelevant?
Jarle said:May I ask what that is increasing then?
This has been discussed to tedium in the SR forums; an FAQ exists which discusses it further.Jarle said:Has relativistic mass any effect of an object?
Or is it just to explain why it is harder to accelerate an object at high velocities?
Yes. It does. For the calculation which shows this please seeFallen Seraph said:Does gravitational mass increase as inertial mass does in relativistic situations? Or does GR make this idea irrelevant?
If a heavy object with rest mass M moves past you with a velocity comparable to the speed of light, you will be attracted gravitationally towards its path as though it had an increased mass. If the relativistic increase in active gravitational mass is measured by the transverse (and longitudinal) velocities which such a moving mass induces in test particles initially at rest near its path, then we find, with this definition, that Mrel=(1+2)M. Therefore, in the ultrarelativistic limit, the active gravitational mass of a moving body, measured in this way, is not gamm*M but is approximately 2gamma*M.
nakurusil said:
Yes, of course. Unfortunately certain people are still stuck on "relativistic mass", the notion that "refuses" to go away. It is really unfortunate that people still attribute physical meaning to the mathematical entity with no ulterior physical meaning [tex]\gamma*m_0[/tex] that appears the the relativistic momentum [tex]\gamma*m_0*v[/tex] and in the relativistic energy [tex]\gamma*m_0*c^2[/tex]. It would be nice if all textbooks standartised on the use of proper mass [tex]m_0[/tex] ONLY and put an end to the accursed "relativistic mass".Chris Hillman said:Just wanted to point out that this is one example where it would be quite confusing to speak of "relativistic mass" (bad terminology on many levels) instead of "relativistic kinetic energy" (good terminology).
I think the original question was not stated well; a WP article I wrote on the Aichelburg-Sexl impulsive pp wave, an exact axisymmetric vacuum solution which has the character of a gravitational wave, but whcih arises from a (not uniqely defined) limiting process called an "ultrarelativistic boost of the Schwarzschild vacuum" (see http://en.wikipedia.org/w/index.php?title=Aichelburg-Sexl_ultraboost&oldid=45333920 )may suggest how the original poster might rephrase it.
(As usual, note that I linked to the last version I edited; more recent versions might be somewhat better or might be much worse!)
The AS pp wave has some interesting features: its curvature is concentrated in a single wavefront, and within that wavefront it falls of much less rapidly than does the "Coulomb tidal force field" which is characteristic of slowly moving and approximately spherically symmetric massive objects.
quantum123 said:Can an ultra-relativistic mass turn into a black hole?
Interestingly on the referenced webpage is the following statement:jtbell said:
What momentum is ignored in the Schwarzschild solution?Crudely speaking we would say that if an amount of mass, M is contained within a sphere of radius 2GM/c2 (the Schwarzschild radius) then it must be a black hole. But this is based on a particular static solution to the Einstein field equations of general relativity, and ignores momentum and angular momentum as well as the dynamics of space-time itself. In general relativity, gravity does not simply couple to mass as it does in the Newtonian theory of gravity. It also couples to momentum and momentum flow; the gravitational field is even coupled to itself.
pmb_phy said:Yes. It does. For the calculation which shows this please see
http://www.geocities.com/physics_world/gr/force_falling_particle
"Note: G is a 3-vector and not the spatial component of a 4-vector."
quantum123 said:That question belongs more to biology, not physics.
And It may also seem ridicilous.Especially having in mind covariant spirit of General relativity.pervect said:The issue of whether or not the "gravitational force" is covariant may seem abstract, but it is very important.
tehno said:And It may also seem ridicilous.Especially having in mind covariant spirit of General relativity.
MeJennifer said:What momentum is ignored in the Schwarzschild solution?
Right, I simply do not see why momentum is in anyway relevant as the above mentioned quote suggests. Angular momentum, yes, the dynamics of space-time, I suppose that means the initial value problem, then yes, but not momentum.Chris Hillman said:Well, in deriving this we assume that the source of the field is an isolated massive object at rest in our coordinates, so we should expect that in any reasonable sense it will have zero momentum.
Gravitational mass refers to the measure of an object's response to gravitational force, while inertial mass is the measure of an object's resistance to changes in its motion. In other words, gravitational mass determines how strongly an object is pulled by gravity, while inertial mass determines how difficult it is to change an object's state of motion.
According to the equivalence principle in Einstein's theory of general relativity, gravitational mass and inertial mass are equivalent and have the same value. This means that an object's response to gravitational force is dependent on its inertial mass.
Relativistic mass is a concept in Einstein's theory of special relativity that describes the mass of an object as it moves at high speeds. It takes into account the effects of time dilation and length contraction, resulting in an increase in an object's mass as it approaches the speed of light.
According to the equivalence principle, relativistic mass and gravitational mass are equivalent and have the same value. This means that as an object's speed increases, its gravitational mass also increases, resulting in a stronger response to gravitational force.
Yes, there is a significant amount of evidence from experiments such as the Large Hadron Collider that support the concept of relativistic mass. These experiments have shown that as particles approach the speed of light, their mass increases, confirming the predictions of Einstein's theory of special relativity.
