How much does the spring compress when an elevator cable breaks?
In summary, an elevator cable breaks when a 920kg elevator is 28m above a huge spring (k=2.2x10^5 N/m) at the bottom of the shaft. The work done by gravity on the elevator before it hits the spring is 2.5x10^5 J and the speed of the elevator just before striking the spring is 23m/s. To calculate the amount of spring compression, the equation used is 1/2mv^2 +mgy + 1/2ky^2 = 1/2mv2^2 + mgy2 + 1/2ky2^2. To solve for this, the initial values for spring compression and elevator speed are
Neerolyte
An elevator cable breaks when a 920kg elevator is 28 m above a huge spring
(k=2.2 x10^5 N/m) at the bottom of the shaft.
Calculate a) the work done by gravity on the elevator before it hits
the spring b) the speed of the elevator just before striking the spring
and c) the amount of spring compresses
( note that work is done by both the spring and the gravity in this part )
I've calculated part a) and b)
answer for a) is 2.5x10^5 J b) 23m/s
For part C) what i think is
Einitial = Efinal
E(ball touches spring) = E(spring compresses)
Apparantly that's the equation in the book, but i have no idea how to do the question
Thanks!
sc: spring compression
ev: elevator speed
ea: elevator accelleration
sf: total force on elevator
What you need to do is:
Start with sc1 = 0 m and ev1 = 23 m/s,
Turn travel to force, sf2 = 220000 * sc1
Turn force to accelleration, ea2 = 9.81 + sf2 / 920
Turn accelleration to speed, ev2 = ev1 + ea2 * dt
Turn speed to travel, sc2 = sc1 + ev2 * dt
Advance time a bit,
And repeat until ev is 0.
Its very easy. take initial to be at the moment the cable snaps, where we only would have potential energy or mgh which u calclated to be 2.5x10^5 + mgy that would be Einitial. Efinal is after the spring compresses as much as it can, so that means the velocity2 is zero, and potential energy 2 is zero so we are left with the term for compression of the spring 1/2ky2^2. the term mgy is taking into account that the potential difference from the point 1 to point 2 and that difference includes the compression of the string not only the distance from initial pt to the spring. sometimes this value can be neglected.
FAQ: How much does the spring compress when an elevator cable breaks?
What is the basic concept behind an elevator?
The basic concept behind an elevator is to use a motorized system to lift and lower a platform or car within a shaft, allowing for vertical transportation between different levels of a building.
How does an elevator stay level with the floors?
An elevator stays level with the floors by using a system of counterweights and a governor. The counterweights help balance the weight of the elevator car and the governor monitors the speed of the elevator, ensuring a smooth and level ride.
How do springs play a role in elevator design?
Springs play a crucial role in elevator design as they help to control the movement and speed of the elevator car. They are typically used in the suspension system to cushion the impact of the car when it reaches the top or bottom of the shaft and to provide a smooth ride for passengers.
What is the purpose of the safety brake in an elevator?
The safety brake in an elevator is designed to stop the elevator car in case of an emergency, such as a cable failure or power outage. It is a failsafe mechanism that ensures the safety of passengers and prevents the elevator car from free-falling.
How do elevators use electricity?
Elevators use electricity to power the motor that moves the elevator car up and down the shaft. They also use electricity for various safety features, such as the lighting and emergency communication systems. Some elevators also use regenerative braking systems, which convert the kinetic energy of the descending car into electricity to be reused for the next ascent.
