Kinetic Energy, Momentum, Projectile Motion ( A real stumper )
In summary: I'm not sure what to do with the 11.6=cos\theta * sin \theta... I can't think of what to do next...In summary, the conversation discusses a problem involving a person standing on frictionless ice and throwing a rock with a certain mass and initial speed. The problem asks for the angle at which the rock was thrown and the speed at which the person is moving after the rock is thrown. The conversation discusses various equations and concepts that can be used to solve the problem, including conservation of momentum and kinetic energy, as well as the fact that the distance between the person and the rock is given and can be used to determine the range of the rock. However, there is some confusion about how to incorporate
xaer04
38
From the text:
"While standing on frictionless ice, you (mass 65.0 kg) toss a 4.50 kg rock with initial speed 12.0 m/s. If the rock is 15.2 m from you when it lands, (a) at what angle did you toss it? (b) How fast are you moving?"
mass of me = 65.0 kg
mass of rock = 4.50 kg
initial velocity = 12.0 m/s
initial height = ?
initial angle = ?
distance = 15.2 m
speed of my body (recoil) = ?
acceleration of gravity = 9.8 m/s^2
time of flight = ?
xo = 0
vo = 0
There is no energy lost to outside forces.
These are simply equations I've tried toying with
Newton's Second Law
F= Ma
Projectile Motion Disregarding time
v^2 = vo^2 +2a(x-xo)
Definition of work
Wnet = Integral(F*dx)
And these are ones i know i'll need later
Conservation of Momentum
m1(v1o) + m2(2o) = m1(v1f) + m2(v2f)
Conservation of kinetic energy
(1/2)m1*(v1o)^2 + (1/2)m2*(v2o)^2 = (1/2)m1*(v1f)^2 + (1/2)m2*(v2f)^2
I have ideas, but none of them seem to work because I'm not given an angle or an initial height to work with (i'm actually supposed to find the initial angle). I just don't know where to begin on this problem. I know that in order to make that specific distance that initial velocity will need to be at a specific angle, and I have the notion that this is either going to be simple and I'm going to kick myself for overlooking it or it's going to be overly complicated... although the latter is less likely. Please help by giving me a concept to use, steer me in the right direction.
Remember that the ratio between your horizontal velocity and the rock's horizontal velocity equals the negative reciprocal mass ratio, due to conservation of (horizontal) momentum.
There being no horizontal forces acting upon either of you, the ratio between your traveled horizontal distance and the rock's traveled horizontal distance equals the same negative reciprocal mass ratio.
Use this to determine the RANGE of the rock first.
The range of the rock is the horizontal distance from the point it was thrown, to the point where it landed, relative to the ground.
alright, i worked out the reciprocal mass ratio, but the range thing... is that not the distance i already gave? (it was given that it landed at 15.2 m) or are you speaking in terms of it being at the same height it was thrown at after a little fly time?
i've thought of something - i think this problem may be unsolvable. I'm asked to give an initial angle, but without an initial height or a flight time that's impossible because it can fly to 15.2 m from different heights, which all would require different angles (within a range).
The problem is quite solvable. Start by figuring out how long the rock was in the air (in terms of its initial speed and angle). Then use that to calculate:
(1) the horizontal distance the rock traveled from the start point
(2) the horizontal distance you traveled from the starting point
Then you can apply the given data to solve for the angle.
*sigh*
my point is, the rock can travel 15.2meters being thrown at 12.0 m/s at different heights with a different angle at each height. flight time, launch height, and launch angle are all dependant on each other, and none are given, so it's impossible to state that for this scenario there is one solveable answer for either part(since part b relies on part a - different launch angles will yield different horizontal momentums, obviously). i think the best i can do is find an equation that works with what i have and what i need, and input different variables to show that without the necessary information there are many answers for this problem.
Okay, let's continue!
Due to mass conservation, your velocity wrt. to the ground is:
[tex]v_{you}=-\frac{4.5}{65.0}*v_{rock}[/tex]
Your position at the time of impact relative to the origin is therefore:
[tex]p_{you}=-\frac{4.5}{65.0}p_{rock}[/tex]
The distance between you and the rock was given to be 15.2m, that is:
[tex]p_{rock}-p_{you}=15.2\to{p}_{rock}=\frac{65.0}{4.5+65.0}*15.2m[/tex]
[itex]p_{rock}[/itex] is the sought RANGE of the rock.
Did you follow this?
oh my, i feel like such a ditz. I'm sorry if got on your nerves... I'm always overlooking how things are worded. i imagined the distance being the distance the rock travelled, not including the displacement of my body:(
*yikes*
i'll rework it and let you guys know how it goes, lol...
To give you a further hint:
Remember that the SPEED of the rock contains both the horizontal&vertical velocity components of it!
Thus, when you are given that the initial speed of the rock is 12m/s, you have to make one of the following interpretations:
1. This is the speed the rock has relative to YOU. This results in nasty implicit expressions
2. 12m/s is the initial speed the rock has relative to the GROUND. This makes your problem relatively easy to solve.
So, choose interpretation 2.
In this case, when solving the rock problem, you have:
[tex]v_{0}=12.0,v_{x,0}=v_{0}\cos\theta_{0},v_{y,0}=v_{0}\sin\theta_{0}[/tex]
where the initial velocity components are determined up to a sine or cosine of the sought launch angle [itex]\theta_{0}[/itex]
Alrighty, I'm working on this problem as well. However, I'm running into a good bit of problem.
I solved time to be [tex]t=\frac{12sin\Theta}{g}[/tex], and [tex]V_{0x}[/tex] to be [tex]12cos\theta [/tex]. But now, I'm running into a bit of a problem.
When i try to plus these values into the equation [tex]x= x_0 + V_{0x} t[/tex], I wind up with [tex]11.6=cos\theta * sin \theta[/tex], and haven't the slightest clue where I went wrong or what to do to fix it. Any pointers would be greatly appriciated.
Luke, I'm having the same problem too. I'm a little lost. I read through this whole post plenty of times and i still can't figure it out.
Is that the total time that it's in the air?
Hint: Review your trig identities; you can replace [tex]cos\theta * sin \theta[/tex] with a single trig function. (You are almost there! :wink: )
Doc Al said:
Is that the total time that it's in the air?Hint: Review your trig identities; you can replace [tex]cos\theta * sin \theta[/tex] with a single trig function. (You are almost there! :wink: )
I do believe it should be the total time in the air. I solved that from [tex]v_y = v_y0 - gt [/tex] , so...Yes, yes it should be the total time in the air.
As for sin*cos, that can be rewritten as [tex]sin(2\theta)= 2sin\theta*cos\theta[/tex], yes? Maybe my algebra/trig is a bit rusty, but I keep getting domain errors and it is making my TI-89 cry...as well as myself.
I guess I should write out what I'm doing so you can steer me in the right direction, haha. Because of the aforementioned identity, i multiplied both sides by 2- giving me [tex]23.6=2sin\theta*cos\theta[/tex], then rewrote it as [tex]23.6=sin(2\theta)[/tex]. From here, my first instinct would be to take the inverse sin of 23.6, but that is a domain error in a big way. SO...help? PS, thanks for the help so far.
Luke, i am completely lost. Could you help me out from what you have so far?
What's the final velocity?
That's what you'll need.
Final velocity...oh! because it's on frictionless ice, it should keep it's [tex]V_{0x}[/tex] value for its final velocity, shouldn't it?
And I'm still hitting a brick wall with the trig.
I'm still talking about [tex]V_y[/tex] that you used in calculating the time. (You made an error that I want you to find.)
One step at a time.
can anybody help me with this problem. I can't find the angle. I understand how to solve for the distance the rock was thrown from the origin. I then solve for time, and i am stuck. any suggestions?
Doc, thank you so much for your help. Unfortunatly, I keep staring at this and can't find my error. I sset it up so that [tex]V_y[/tex], the final Y component of the velocity, is zero. As such, [tex]0 = V_{0x} - gt[/tex], or [tex]0=12sin\theta - gt[/tex]. I then add the gt to the opposite side, divide by g to get my t value. I honestly haven't the slightest clue where I'm going wrong. A gentle nudge would be much appriciated.
So, when you toss a ball in the air its speed is zero when it lands back into your hand? :wink:
so nobody would like to help me solve for the angle?
If you want specific help, show what you did step by step. (Or at least describe the specific step you are stuck on.)
No, you're right. It's speed is most certainly not zero. It's the same it started out with.
But that just seems to be leading me in a weird direction, probably because I'm so frazzled. I rewrote the expression as [tex]-12sin\theta=12sin\theta-gt[/tex]. From there, i added 12sin, and arrove at [tex]0=24sin\theta-gt[/tex], which brought me to [tex]t=\frac{24sin\theta}{g}.[/tex]
I kept going, and plugged that into [tex]x= x_0 + V_{0x} t[/tex], giving me [tex]14.31=\frac{12cos\theta*24sin\theta}{g}[/tex].
I multiplied through by g, then divided by 12 to give me [tex]11.68=12sin\theta*cos\theta[/tex].
I then divided through by 6... giving me [tex]1.944=2sin\theta*cos\theta[/tex], or [tex]1.944=sin(2\theta)[/tex].Now, my double angle trig is a bit flakey...so this might be very illegal. I divided 1.944 by 2, and took the inverse sin...giving me 76.4 degrees. Does my math seem correct? Oh man, you have helped me a TREMENDOUS amount.
for projectile problems, i assume we would use t=x/v0cos(theta)0 so i pluged in the x distance from the origin to the landing (14.2) and i also pluged in 12.0 for v0. Now i am left with two unknowns.
But that just seems to be leading me in a weird direction, probably because I'm so frazzled. I rewrote the expression as [tex]-12sin\theta=12sin\theta-gt[/tex]. From there, i added 12sin, and arrove at [tex]24sin\theta-gt[/tex], which brought me to [tex]t=\frac{24sin\theta}{g}.[/tex]
Good!
Where did you get the 14.31?
Check your arithmetic.
Find the time by considering the vertical motion. Then use that time in calculating the horizontal motion.
The 14.31 came from an earlier post, by arildno. He helped me find the range of the rock by playing with the conservation of momentum equation to give [tex]p_{rock}-p_{you}=15.2\to{p}_{rock}=\frac{65.0}{4.5+65.0}*15 .2m[/tex].
Haha, I see that arithmetic error. A big one ideed. Unfortunatly, now I'm a bit lost...as I now have [tex]11.68=2sin\theta*cos\theta[/tex]...but I can't take the inverse sin of 11.68, or 5.84...ARGGGGHHHHHH.
That's cool.
You still have an arithmetic error.
so vy=vy0-gt?
xXmarkXx said:
so vy=vy0-gt?
Sure. (Read the other posts in this thread!)
  • #31
i have been..i'm really confused.
now i have...
(12sin(theta))/9.8=(14.2)/12cos(theta) does that look ok??
  • #32
Doc...i'm not going to lie, I cannot find the arithmertic error for the life of me.
When I multiply through by g, i wind up with 140.238=12cos24sin. So I factor out a 12, and divide by that... which brings me to 11.68=2 sin x cos x.
Could you please give me a pointer as to where I'm going wrong? I don't just want the answer.
  • #33
Luke1294 said:
...giving me [tex]14.31=\frac{12cos\theta*24sin\theta}{g}[/tex].
Do it step by step:
(1) multiply by g
(2) divide by whatever you need to to get 2 on the right
  • #34
i got 23.2=sin2(theta), but i used 14.2 instead of 14.3
do you agree doc?
  • #35
Hm. So, I was looking at that the wrong way for sure. That can definatly be written as [tex]140.238= 288cos\theta sin\theta[/tex], can't it? So, I divide both sides by 144...giving me [tex].973875=2sin\theta cos\theta[/tex], or [tex].973875=sin(2\theta)[/tex]. I then divide the left by 2, take the inverse sin, and arrive at 29 degrees?
Am i error free?! Finally?!
