I WANT to build a nuclear reactor.
In summary, building a nuclear reactor is a very difficult and expensive task. If you try to do it yourself, you will need a license from the Nuclear Regulatory Commission and will likely need to buy insurance from the federal government.
amberb617
Ok so I know that this seems like an absolutely absurd and almost impossible idea but I want to build a nuclear reactor to enter in the state science fair next year.
I know that it takes time, wit and money but I'm completely prepared to take on the challenge.
So the point of posting this bulletin is to call on the help of the wonderful members of this Physics Forum.
I need to be enlightened.
Help me.
:rolleyes:
I'm usually very supportive of ambitious projects but honestly, choose something else to do. The litigation is too much and the safety and security is nothing a single person can handle.
Do google "build your own nuclear reactor".
will give you lots of hits.
but the thing is, how are u getting hold of radioactive materials?
I would recommend building a cyclotron or an accelerator, which could actually work pretty much better than an entire reactor...
If you're in the US, whatever you end up building (whether a reactor or cyclotron), if it has the potential to produce ionizing radiation, it will require a radioactive materials license which can be quite expensive depending on where you live. The licensing requires that you have a radiation protection program, are qualified by education and experience to possesses radioactive materials or radiation producing machines, etc. As was stated, you're probably better off trying something else. Unless, of course, you mean you want a non-working model of a reactor, in which case it's doable, though still quite an undertaking.
Amber,
I'm sorry - but a reactor is NOT a suitable "science fair" project.
If you had the technical accumen to handle this project, you would be working for a
reactor manufacturer or at a national lab; not entering a science fair.
Additionally, it would be illegal for you to build a reactor. In order to build a reactor, you
have to have a license from the USA's Nuclear Regulatory Commission. They will want
copious amounts of documentation on the safety of the reactor design. As a
requirement under the Price-Anderson Law, you would need to buy insurance from the
federal government, the minimum yearly premium is $2 Million.
Owning a nuclear reactor is a financial stretch even for a University. In fact, many
Universities have shutdown their reactors because it became too expensive; the
University of Michigan is one such case that comes to mind.
Building a reactor as a science fair project would be like building a jet airliner as a
science fair project; it's way too ambitious.
Set your sights on something more reasonable; you'll learn more, and have more fun.
Good luck.
Dr. Gregory Greenman
Physicist
Amber,
I like the suggestion of "daveb" - that you make a model of a reactor.
That way you can learn about them; without having the daunting challege of producing
a working reactor. You could have a little model with control rods that you could withdraw
by hand; and that would cause a light bulb to go on/off. Put some type of blue filter
surrounding the light bulb to give the appearance of the blue Chrenkov radiation emitted
by an operating reactor:
http://web.mit.edu/nrl/www/reactor/core_description.htm
http://nscr.tamu.edu/
http://www.mne.ksu.edu/research/centers/reactor/Reactor%20Facilities/
There are lots and lots of books on nuclear reactors. You might also check to see if
any University in your region has a nuclear research reactor that you could tour.
Good luck with the science project.
Physicist
I concur with Morbius.
One needs a license to purchase or obtain and use "Special Nuclear Material" (in this case fissile material), and sorry, but students do not qualify. It takes years to get a license, and the NRC is not about to expedite one's application. It also takes years to become qualified to what one proposes.
NO - it is an absolutely absurd and impossible idea.
Best just to build a model as Morbius suggests.
What about a fusor? Those can produce neutrons and plenty of x-rays and I don't think they are illiegal...
The construction of a farnsworth fusor wouldn't be absurd and can achieve nuclear fusion (even better than fission!). A hand full of amateurs have successfully built working (fusing) fusors in this country, including some very young people (well, not 6 year-olds). This would be an ambitious, but doable project IMHO.
You could also built a fusor demonstrator, a far less dangerous and costly version of the real thing, that would none-the-less show the principles behind electrostatic confinement. Basically you need a vacuum chamber and vacuum pump, a high voltage power supply, some stainless steel wire to make your anode and cathodes, and the knowledge to put it together.
What do the rest of you think?
-Alan
Alan,
If it produces ionizing radiation, then YES - IT IS ILLEGAL!
You have to be licensed by the NRC to operate an X-ray machine,
an accelerator, or possesses a radioisotope.
This is the only way that one can be sure that someone isn't producing
radiation that is irradiating unspecting people because the operator of
the source didn't consider proper shieldig...
If you don't know the laws, please refrain from giving advice to yourg
students who may follow it and get into trouble.
Physicist
I'm surprised that no one has mentioned the rather obvious problem with this:
Even in the preliminary steps of designing and creating this, you will acquire the full and complete attention of several branches of government including the FBI and DND as a "person of interest."
Dave,
Yes - the creation of a source of ionizing radiation is something that a terrorist; either
foreign or domestic; might try to accomplish for the purpose of terrorizing the populace.
Therefore, it is quite reasonable for the FBI and Homeland Security to be on the look-out
for any activities of this type.
Physicist
Even more surprising is the fact that most science fairs have explicit rules about things like nuclear material, human tissue samples, etc.You might want to look them up. Chances are, you'll never be able to get anything resembling a "homemade nuclear reactor" in the door, and you might well be disqualified.
You do not have the education required to safely handle radioactive material. You should not even be attempting this, since it will endanger your life and the lives of everyone around you.
If you want to be ambitious, try building something just as complex but less dangerous, like a linear particle accelerator.
- Warren
Yeah, I built one of them last weekend. Made it completely out of MDF, amazing what you can do in a garden shed...:rolleyes:
Next time try it with your garden hose and aluminum foil works much better :smile:
Under the Radiation Control for Health and Safety Act, the Public
Service Act, and the Federal Food, Drug, and Cosmetic Act, the
Assistant Secretary for Health in the Department of Health in the
Department of Health and Human Services (HHS) (which has been delegated
to the Food and Drug Administration), was given the responsibility to
develop a program of radiation protection which, in part, included
research and training concerning radiation hazards, recommendations for
radiation users, advice to States, information for the public,
performance standards for electronic products that emit radiation, and
regulations for the sale, distribution, and use of medical devices.
These programs are described in 21 CFR 1000 to 21 CFR 1050. Additional
information may also be found on the Center for Devices and Radiological Control Web site.
http://hps.org/publicinformation/ate/q2547.html
http://www.fda.gov/cdrh/radhealth/products/xrayparticulate.html
The AEC (predecessor to NRC and DOE) used to have authority for regulation of X-ray devices, but it was moved under HHS/FDA. Nevertheless, anything that produces ionizing radiation is regulated and one must comply with Federal and State laws. Ignorance of the law is no excuse. States have an office which regulates manufacture and use of devices, which produce ionizing radiation, so one should check with one's state government.
Hey, don't laugh. All you really need is a cavity, a Sears vacuum pump, and some relatively simple electronics. I'm not talking about MeV here, but a couple of hundred eV would be attainable, and measurable.
- Warren
The ITER Newsline recently referenced a high schooler who built a machine that causes fusion.
The article it references is here: http://search.ft.com/ftArticle?queryText=fusor&aje=true&id=070126006711
Candyman,
Yes - I read about him while visiting my home town of Rochester Hills, Michigan:
http://research.lifeboat.com/teen.goes.nuclear.htm
This student attended the same school district that I attended. In fact, his school,
Stoney Creek High School; is about a mile from the neighborhood that I spent my
childhood years.
http://www.rochester.k12.mi.us/index.asp?school=23&name=Stoney Creek High School
Stoney Creek, the third high school in the system was not part of the district when I attended high
school. I'm a member of the 2nd graduating class of the district's 2nd high school; Rochester Adams Senior High.
[ For you pop music fans - that's Madonna's alma mater. ]
http://en.wikipedia.org/wiki/Rochester_Adams_High_School
http://www.rochester.k12.mi.us/index.asp?school=22&name=Adams High School
Physicist
Whoa... a particle accelerator in your garage? whoa! that's so cool...:approve:
Can you send me a link where they show you how to do it hoot? would appreciate it much...:rolleyes:
And the guy who built the fusion reactor... Anyone know what became of him? what does he do now? that's so cool man... a custom made fusion reactor... :approve:
Morbius said:
Alan,
Physicist
If it is illegal (a fusor), then apparently nobody cares, considering I have recently read about a teenager who built a fusor being profiled in popular science or mechanics. If it was a bust your door down offense then I doubt they would have published the article and not mentioned his arrest as a terrorist.
From fusor.net:
"The Neutron Club"
These people have operated a neutron producing fusor or fusion system.
(normally d-d fusion):
Richard Hull - 10e5 neutron mark 3/99
Scott Little
Joe Zambelli - Half mega mark 12/01
Tom Ligon
Michael Li - winner $75k Intel scholarship (fusor)
Mike Amann
Jon Rosenstiel - Mega neutron mark 10e6 11/02
Gerardo Meiro - First non-US neutron Club member
Phillip Fostini
Carl Willis - advanced activation work
Larry Leins - pulsed fusor work
Craig Wallace - winner $1.5k Intel 2nd place (Fusor)
Frank Sanns
Brian McDermott
Fergus Noble & Henry Hallam - first UK neutron members
Adam Parker - winner of $10k Alabama scholarship in science
Mark Langdon
Thiago Olson
Wayne Rodgers
Eric Stroud
Wilfried Heil & Noemi Zudor - Smallest fusor ~3" diameter
Raymond Jimenez
Notice the people who won money and scholarships with their neutron producing fusor.
It is a perfectly viable project for anyone ambitious enough to tackle it.
-Alan
Well, whether it's illegal or not depends on a few things. If the levels of radiation are low enough, the fusor may not require a license. Since radiation producing machines and accelerator produced material are regulated by the state regulatory agencies it would depend on the state the person lives. I believe Wyoming, e.g., doesn't really have any operating regulatory agency (or at least not one that regulates nuclear pharmacies). As for any material, if the activity is below the exempted quantity, then anyone can possesses it (e.g., no one needs a license for Cs-137 in activity less than 10 microcuries). I couldn't find information on neutron source strength for a fusor, but if it's low enough, the regulatory agency won't be concerned about it.
Alan,
There was a case a few years ago of a teenager who was attempting to build a nuclear
reactor by assembling a bunch of radioactive material that he obtained by opening the
sealed sources inside home smoke-detectors, for example.
http://www.dangerouslaboratories.org/radscout.html
When it was ultimately found out what the teenager was doing, the autorities did check out
his work and found that he had contaiminated his garage, his home, and his school with
radioactivity. Clean-up crews had to come in and decontaminate the mess that this
teenager made. Because nobody discouraged this teenager from conducting his ill
conceived science project, many people were exposed to radioactivity that they should
not have been exposed to, as well as the large cost of cleaning up a radioactive
mess.
Independent of what the law says, I hesistate to recommend a project that involves
potentially harmful activities to a student that I don't know. The teenager in Michigan
evidently pulled off this project successfully. That doesn't mean any teenager can do
the same.
I think it would be irresponsible to recommend a potentially harmful project to a student
that I didn't know well and knew that they had the technical acumen and maturity to
handle the project.
Physicist
Thinker,
The November 2006 article I posted from the Detroit Free Press listed him as a 17 year
old high schoold student. I would assume that he's finishing his senior year in high school.
I wouldn't call the "fusor" a "fusion reactor". The amount of energy that one gets from the
fusion reactions is dwarfed by the amount of energy one has to put into the device in the
form of electricity to make it operate.
The fusor is a little neutron-producing accelerator. Science has known how to do that
for decades. Accelerating particles enough to cause fusion isn't all that tricky. One
will find little neutron pulse generators such as these in practically any nuclear lab.
[ The "Neutron Club" that Alan mentions includes THOUSANDS of university students
that have taken nuclear laboratory courses. ]
The real problem is how to create fusion and come out with a net production of energy.
THEN you will have a device that deserves to be called a "reactor".
Physicist
Although I understand that that's a mainstream notion, it seems rather odd to me to require that a 'fusion reactor' release net useful energy, while there are plenty of examples of 'reactors' that don't ranging from the Princeton tokomak test reactor, to chemical reaction vessels, to the infamous scavenger hunt breeder reactor build in the 1999 University of Chicago scavenger hunt, or the more famous pile that was set up there at Stagg field in 1942. Moreover, fusors do, in fact, release energy, so an (admittedly highly unlikely) improvement in energy capturing technology would move them from 'not nuclear reactors' to 'nuclear reactors' which strikes me as rather odd.
Honestly, I don't think that a fusor is a particularly good idea for a high school science experiment. There are hazards from high voltage and radiation (if you actually get it up and running), and they're likely to be expensive (in the thousands of dollars.) Meanwhile, there are plenty of easier, more original, and more practical experiments possible.
A pot of boiling water releases energy, but not more than is added.
A fusor does not produce much more energy than put in.
Say this kid got 1 million neutrons (IIRC, the article claimed 200 K) and assuming that is half of the reactions, there would be 2 million reactions producing about 4 MeV/reaction for simplicity.
2 million reactions * 4 MeV/reaction * 1.602 x 10-13 J/MeV = 1.282 x 10-6 J
If the student applied, let's say 10 kW for 1 s, then the system used 10 KJ.
Now compare 10 kJ with about 1 micro-J. How practical is that for an energy source?
Fusors are fancy neutron generators, not energy sources.
Nate,
The 1942 Stagg Field reactor WAS a CRITICAL system.
It was in EVERY sense a REACTOR. It produced more energy than input. In fact, to
operate a critical fission reactor - there's ZERO input energy needed.
Additionally, because it was a critical system, the Stagg Field reactor could put out ANY
amount of power as long as it was cooled. There was no cooling system on this reactor,
which limited it to very low powers. But if the Stagg Field reactor were surrounded by
some type of vessel through which coolant could be pumped then it could have
generated much more power.
In fact, the Stagg Field reactor was a prototype, which led to the X-10 reactor at
Oak Ridge, which was a prototype for the production reactors at Hanford. The Hanford
production reactors produced significant amounts of power, and had cooling systems;
and they were just "scaled up" versions of the Stagg Field reactor.
So Fermi's Stagg Field reactor was a reactor in that it really could have produced power,
if you put a cooling system on it.
That's NOT true of the fusor. The output energy is INSIGNIFICANT compared to the
energy one puts into it. The fusor is an energy "sink" not a "source".
As Astronuc stated, a "fusor" is a nice little neutron source; but it's NOT a reactor.
Physicist
I know all about the nuclear Boy Scout. And I never suggested anyone build a fission reactor or take apart thousands of smoke detectors. Obviously, that is the first thing people thought of when the OP said he wanted to build a nuclear reactor. I would discourage anyone from doing what the “nuclear Boy Scout” did.
A fusor, however, IS a reactor. If energy balance is the only reason a person can come up with to disqualify it as a nuclear reactor then you have also disqualified all the experimental fusion reactors ever built to date. Apparently, a reactor only "deserves" to be called one if real live Physicists work on it, spending billions of dollars building a big giant energy sink. It would be silly to expect a desktop device to produce net energy, and it is completely irrelevant to the discussion. Nobody ever said they wanted to produce net energy or that a fusor does.
The list I mentioned wasn't exhaustive... but those people BUILT the device that produced nuclear fusion. They didn't just turn on a device that someone else built.
Just because you don't know somebody isn't a reason to say that it is impossible or absurd to build a reactor, when in fact it is not (the fusor being the only example I know of). Many people have done it safely with very little money (a few thousand dollars) and if someone has their heart set on it they can do it. Warn them of the dangers, sure; say there are better projects, fine; but don't sit around and discourage people from doing things that you have never done yourself just because you think it is dangerous. IMO there are far too many people on the internet whose only response to inquisitive minds is "YOU"LL KILL YOURSELF!"
-Alan
Your school should buy one of these!
Here's a nice garage-size reactor. One-man operation, and it runs on regular house current!
http://coldwar-c4i.net/EW-1957-01-28/059.html"
Albert LaFrance
real cool when the doe turns your house into a superfund site! :rolleyes:
NO - a fusor is NOT a reactor!
Actually, I don't consider the experimental magnetic fusion devices "reactors" either.
I don't expect a desktop device to fly and transport people either - but that doesn't
mean that it is OK to call some desktop device an "airliner".
I don't expect a fusor to produce net energy - so I don't expect to be able to call
it a "reactor" - something it definitely is NOT.
That's also what I'm talking about - people building things. You don't learn much in
a nuclear lab just by turning on a device.
Don't you understand - it is IRRESPONSIBLE for a professional in a field that could hold
dangers to suggest to someone that they don't know and don't supervise to encourage
them to undertake a project that has inherent dangers such as radiation and high voltage.
Just you hold it right there Alan! You don't know me - you don't know what I have done.
Don't cop this attitude that I'm saying this because I can't do it! For your information,
I'm part of the only design teams that have gotten NET thermonuclear energy production.
I've designed experiments MUCH more complex than a fusor.
So where do you get the AUDACITY and UNMITiGATED GALL to suggest that it's
because I haven't done something myself?
The Internet is NOT the place for a young student to get advice and guidance on this
matter. In case you don't know; there's no QUALITY CONTROL on the Internet.
A student that is interested in this type of project needs to check out their local laws,
and get the guidance of a TEACHER! If a local high school teacher isn't qualified; then
perhaps a professor at a University - but for Heaven's sake NOT the Internet
I would expect that a student that has the capability to undertake such a project; would
also have the ambition to research this in the library, with local officials, with teachers,
with professionals in the area that can give them the type of guidance that is required.
Unfortunately there ARE too many cases of young scientists injuring themselves because
they didn't have the proper supervision.
As a professional, as an employee of the University of California; I'm bound by certain
ethics, and moral codes that you are evidently unaware of.
Suppose I encourage somebody, and they injure themselves. They could file a lawsuit
against the University of California, saying "Your employee who is a professional
physicist encouraged this young impressionable student to undertake this dangerous
project [ a project he knew to be dangerous because he is a professional ] and he had
no way of supervising the potentially dangerous activities of this young student".
Therefore, I am FORBIDDEN from this type of encouragement!
If you don't like it - take it up with the LAWYERS! However, the legal matters
are secondary - what is REALLY important is this student's SAFETY.
Although this type of project can certainly be done safely; I can't encourage it
unless I know the student has the proper support to carry it off safely.
However, until this young student has the degree of "hands-on" supervision that is
required for a project dealing with radiation and high-voltage; I would have to discourage
them from undertaking such a project unless it can be done PROPERLY with the
right supervision.
Physicist
  • #31
That was 1957. Such a device would not be permitted in a high school, and only in a univeristy with a license, and that program would be audited for compliance with NRC rules and regulations.
When I was in grad school, we had to do a detailed review (accounting) of all radioactive sources and nuclear material. Operators of the training reactor were certified and re-certified, and that was reviewed by the NRC.
There are very strict rules with respect to the production and use (legally that is) of devices that produce nuclear reactions. I have to wonder of those people who have reported building fusors have complied with all pertinent laws.
Also, one can build a plane or car, but planes have to be tested and certified by FAA, and cars have to be street legal to take on the road. Nuclear systems are much more stringently regulated.
  • #32
Albert,
In order to legally own and operate such a device; the owner / operator would need a
Class 104 operating license from the Nuclear Regulatory Commission:
http://www.nrc.gov/reading-rm/doc-collections/cfr/part050/part050-0021.html
Physicist
  • #33
"That word, I do not think it means what you think it means." - Fezzig, the Princess Bride
In general a reactor is an isolation vessel in which a controlled contained reaction takes place. Based on that notion, a functional fusor qualifies as a reactor. Moreover, fusion reactions take place in a running fusor, so it qualifies as a fusion reactor.
I'm guessing that when you write 'reactor' you're thinking of something more specific and technical - perhaps involving self-sustaining reactions.
  • #34
Nate,
In the 'nuclear" field - a "reactor" is self-sustaining.
Yes - in I know that in the field of chemical engineering a reactor is a vessel for
isolating and conducting chemical reactions on a large scale.
Just because there are nuclear reactions going on in the fusor is NOT enough to call
it a reactor. You can have nuclear fusion reactions in little tubes that look like vacuum
tubes that give you a pulse of neutrons when high voltage is applied. I don't call them
"reactors". They are NOT reactors - and NEITHER is a "fusor".
It confusing to people who hear about "fusors" referred to as reactors - it gives them the
impression that it is an energy source via nuclear fusion. It isn't - it's a dead end.
I've gotten questions like this from friends and neighbors that read this and ask,
"Why are you spending all this money for a big facility like the National Ignition
Facility; when a teenager can do the same thing in his garage?"
The point is - the teenager CAN'T do the same thing in his garage. The "fusor" will
NOT reach thermonuclear ignition. A facility like NIF is required for that. So to
keep the public well informed - let's NOT give them the impression that the "fusor"
is anything but a "toy".
Physicist
  • #35
I don't know if this has been stated before. Check the rules. Some don't allow certain temperatures to be attained. I remember reading about a high school student doing this. His name was Brian something I believe. Google Brian nuclear reactor and I'm willing to bet you'll get his page.
  • Nuclear Engineering
  • STEM Career Guidance
27K
