kgm2s-2
- 5
When current is allowed to flow through an electric conductor, magnetic fields are produced. What actually causes the magnetic fields to appear?
![Smile :smile: :smile:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
That's a very good question. Unfortunately, neither I, nor anyone has ever found an answer. The "cause and effect" concept is intuitive at the macroscopic level. If you tee up a golf ball, then swing the club, hitting the ball and putting it into flight, it is intuitive that the kinetic energy of the club was partially transferred to the ball, "causing" it to move.kgm2s-2 said:When current is allowed to flow through an electric conductor, magnetic fields are produced. What actually causes the magnetic fields to appear?
cabraham said:snip
ice109 said:lots of philosophical mumbo jumbo but no real substance. there are theorized answers to this question, just because you don't know them ( and coicdentally i don't know them ) doesn't mean you need to resort to saying that it is absolutely unknown.
"The modern understanding of magnetism posits that all magnetic effects are actually due to relativistic effects[4] caused by relative motion between the observer and the charged particles."
what i meant is that i haven't learned the physics yet. there is physics that explains b field. it is not unknown at all. I'm pretty sure quantum field theory explain the electromagnetic force but like i said i don't know it.cabraham said:snip
jostpuur said:In my opinion this matter is highly mystical in main stream science. I can hear everybody explaining, that putting electricity and relativity together will give magnetism, but I have never seen actual proof for this claim. Some years ago, being not satisfied by these "rumours" about magnetism, I tried to deal with this problem myself.
Two facts before getting into business:
1: Somebody might say that you cannot use action at the distance in relativity. Nonsense!
2: You are not supposed to use forces in relativity. Nonsense! Just define [tex]\boldsymbol{F}:=d\boldsymbol{p}/dt[/tex]. It is a good definition, and nobody has right to forbid this concept.
Now consider a following problem. A particle A is moving with velocity [tex]\boldsymbol{v}_A[/tex], and a particle B is moving with velocity [tex]\boldsymbol{v}_B[/tex], and we want to know what force particle A exerts on particle B. Let us assume that the locations in the spacetime are like in the earlier remark, so that the question makes sense.
I understood, that there is no need to postulate this answer. In particular there is no need to postulate magnetic field or Lorentz's force. It is sufficent to postulate Coulomb's force in the A particle's rest frame.
Since we can calculate how four-position and the force itself transforms under boosts, we should be able to solve the force in any other frame. Unfortunately I cannot put in all the details, because the calculation is quite long, but I hope you understood the idea.
For some time I though I had all magnetism now figured out, but I later learned that these equations agree with the Maxwell's electromagnetism only in the special case where particle A is not accelerating, because the radiation terms are missing. And the original assumtion on the Coulomb's force is also wrong for accelerating source. Still, I would argue that these were not useless calculations, because they give good intuition on the nature of magnetism. In my opinion, the popular calculations that deal with lorentz contractions of current carrying wires are too special case like, to truly answer problems of magnetism and relativity.
Why you thing that the electric field lines (electric force) will be compressed?waht said:Magnetic field is just a relativistic effect of the electric field. When the charge is not moving, it has an electric field, and no magnetic field. However when it moves close to the speed or light, the electric field lines will be compressed, and a sort of tidal force will develop, which is the magnetic field. The strength of the magnetic field depends on how fast the charges move.
[tex] B = v * E/c^2 [/tex]
(cross product)
jostpuur said:kgm2s-2, I was just taking part in the discussion, I don't know if my post helped you in any way. At what level are you? How much you know about physics?
There is nothing concretely said there. I just want to know, correctly how it is. I saw on some posts that said that the electric field is compressing and producing tidal force, which is the magnetic force. Can you explain better please. Thank you.jtbell said:I gave an answer in the other thread where you asked this question:
https://www.physicsforums.com/showthread.php?t=175883
So you say that the electron's electric field is converted into magnetic field by the front and back side of the electrons, right? So that's why there is electromagnetic field and not all of the electric field is converted into magnetic, right? I didn't actually understand the last part (bold). Why y-z plane? I can't imagine what do you think.waht said:A tidal force is when there is an uneven distribution of forces. Most common tidal force is exerted by the moon on the oceans on earth.
You can think of a charge at high speeds similarly. Consider an electron at rest, the electric field lines are radially spread out evenly.
If you are familiar with special relativity, then at speeds close to speed of light things experience length contraction (in the direction of motion), time dilation, and mass increase, right?
As a result the electric field lines of an electron traveling close to the speed of light will be squeezed in the direction of motion (by length contraction). So much so, the electric field strength in front of and behind the electron (in the direction of motion call it x) will be much less than in y-z plane. The y-z plane will be a circular disc containing the strongest electric field lines that is perpendicular to the direction of motion.
The converse is also true. If an electron is stationary emanating radially electric field lines, and if you zip by this electron close to the speed of light, by length contraction effect will make you seem the front and back of the electric field are squeezed, and y-z plane disk will contain the strongest electric field densities.
It has been shown that this effect is responsible for the magnetic field. It's all relative.
waht said:Just forget about y-z or x, this is just a 3 dimensional coordinate system.
When you take the away the electron's electric field strength in the direction of motion where else is it going to go?
It's going to concentrate away from the direction of motion and into a form of a disk that is perpendicular do the direction of motion. So an electron traveling close to the speed of light will have the strongest electric field at 90 degrees to the direction of motion.
A magnetic field is just an invented construct designed to help us understand the electric field relativistically.
An electromagnetic field is when an changing electric field induces a magnetic field, and then the magnetic field will induce the electric and so on, it's just like a dog chasing his own tail.
I quote from wiki
" explained in 1905 that a magnetic field is the relativistic part of an electric field.[4] It arises as a mathematical by-product of Lorentz coordinate transformation of electric field from one reference frame to another (usually from co-moving with the moving charge reference frame to the reference frame of non-moving observer).
(However, the Lorentz transformation cannot be applied to electric fields unless it already presupposes the existence of magnetic fields and their inter relationship with electric fields under the terms of Maxwell's equations. As such, the magnetic field can hardly be considered as a by-product of the Lorentz transformation.)
When an electric charge is moving from the perspective of an observer, the electric field of this charge due to space contraction is no longer seen by the observer as spherically symmetric due to non-radial time dilation, and it must be computed using the Lorentz transformations. One of the products of these transformations is the part of the electric field which only acts on moving charges — and we call it the "magnetic field". It is a relativistic manifestation of the more fundamental electric field. A magnetic field can be caused either by another moving charge (i.e., by an electric current) or by a changing electric field. The magnetic field is a vector quantity, and has SI units of tesla, 1 T = 1 kg·s-2·A-1. An equivalent, but older, unit for 1 Tesla is Weber/m2."
Read this from top to bottom a couple of times
http://en.wikipedia.org/wiki/Magnetic_field
As far as I know the magnetic field produces electric field when there is presence of conductor, and magnetic field lines are cutted by conductor. I was interested about the story for compressing the lines of force. What happens with the gravitational field? Is it also compressed by the movement of the moon or what?
As far as I know the equation you propose holds in a given inertial reference frame if we can start with an inertial reference frame in which only an electric field is detected.waht said:Magnetic field is just a relativistic effect of the electric field. When the charge is not moving, it has an electric field, and no magnetic field. However when it moves close to the speed or light, the electric field lines will be compressed, and a sort of tidal force will develop, which is the magnetic field. The strength of the magnetic field depends on how fast the charges move.
(cross product)
waht said:The moon thing is not related to this at all. I've used the term "tidal" because it refers to a net effect caused by asymmetry. In the case of an electron moving at high speeds, there is an asymmetry in its electric field.
But there is a theoretical study of gravitomagnetism that in the case of a mass traveling close to speed of light will induce a fictional force that is analogous to when a magnetic field is induced by an electric charge traveling close to speed light. However this has not been observed experimentally.
Also there is no need for a conductor. By Maxwell's laws, a change in electric field will induce a magnetic field, and vice versa a change in magnetic field will induce an electric field. If you bring a conductor close by, a change in magnetic field will move the electrons in the conductor. The moving electrons will themselves induce their own magnetic field which might oppose the magnetic field you are changing (eddy currents).
But note the magnetic field is only an effect of the electric field relativistically. We call it a magnetic field to distinguish the behavior of the electric field.
hope that helps.
jtbell said:In classical electrodynamics, a spinning object is like a loop of current, which produces a dipole magnetic field:
Magnetic field of current loop
In quantum electrodynamics... ehhh... I'll let someone else tackle that.![]()
