Balancing the Cards: An Exploration
  • Thread starter Thread starter barbiemathgurl
    Cards Exploration
The discussion focuses on the mathematical problem of dividing 14 cards, each numbered between 1 and 1000, into two piles with equal sums. Initial misconceptions about the problem's formulation are clarified, emphasizing that the correct interpretation involves selecting subsets from the set of cards. The Pigeonhole Principle is applied to demonstrate that, given the number of possible subsets exceeds the range of possible sums, two distinct subsets with equal sums must exist. A specific example illustrates that selecting cards 1, 2, and 3 can yield equal sums when divided appropriately. The conversation concludes with a question regarding the calculation of the largest possible sum, highlighting the need for accuracy in the problem's parameters.
barbiemathgurl
so embarrased askin so much :redface:
On a table there are 14 cards. On each card there is a number between 1 to 1000. Show it is possible to divide the cards into two piles so that the total sums are the same.
Mathematics news on Phys.org
Let card #1 to #13 all have the number 1 and let the 14th card have number 1000. 13 is not the same as 1000. Maybe you read or wrote the problem wrong?
Though I think she means that all cards have a different number assigned to them, it doesn't take away the fact that the hypothesis presented is wrong. Suffice to have among the fourteen cards an odd number of cards having odd numbers assigned to in order for it to be impossible.
As the two posters said you have indeed made a mistake.
The correct version of the problem should be:
"Given 14 cards with numbers from 1 to 1000 on them show that you can choose some of those cards to be divided into two piles with equal sums"
For example, as Werg22 said let the cards be:
1,2,...,13,1000
Then your original formulation is false. By the correct formulation on top you can choose some of those cards, i.e. 1,2,3 and divide those into two equal piles, i.e. (1+2) and (3).
To prove this we need to state this problem in a different manner involving sets.
"Let S be a set of 14 numbers, with each number between 1 and 1000. Show that there exists two proper disjoint subsets A and B such that sum(A) = sum(B)"
There are 2^14 - 2 = 16382 possible subsets. Each subset will be assigned a number, that number is the sum of its elements. Now the lowest possible sum is 1 and the largest is 1000+999+...+992 = 8964. So there are 8964 possible set sums. Since 16382 > 8964 there exists two distinct (but not necessarily disjoint) sets A and B with sum(A) = sum(B) by the Pigeonhole Principle. If A and B are disjoint then we are done. If not the remove the elements that they have in common, that will preserve their sums (and the sets do not vanish because they are distinct). So we will end up with two disjoint sets with equal set sums.
Kummer,
in your solution, why does the largest sum only have 9 numbers in it? Shouldn't it be the sum of the largest 13 numbers?
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation has no solutions with positive integers if It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
