radiogaga35
- 34
Suppose one has a solid metal body (in static eq'm) with a cavity inside it.
Assume the cavity has no charge in it. This is how one could prove that there are no fields inside the cavity: choose two points A and B, both in the solid part of the metal body. Follow a path through the metal (but not through the cavity) - since the electric field is zero throughout the metal, the path integral of the field (i.e. the potential difference) must be zero. Now take a path from A to B that goes THROUGH the cavity -- using path independence of potential diff., the p.d. must for this path also be zero. Hence, no fields in the cavity.
My question is this: why does this same argument not apply to a cavity when you DO have a charge inside it (i.e. you place a charge inside the cavity?). I know that using Gauss' Law, it is easily shown that there will be an equal and opposite charge distributed on the walls of the cavity (though perhaps this is irrelevant?). However, there are fields within the cavity...so where does the "path independence of p.d" fall apart?
Thanks
Thanks
