Rolls Royce Trent Engine Technology
In summary, the presentation discusses the various advantages and disadvantages of electric power in aircraft engines. Some good points are made regarding the efficiency of electric engines and the lack of need for oil systems. It is also mentioned that there are some downsides to electric engines, such as the potential for accessory failures. The presentation then goes on to discuss the concept of the blended wing, which seems to use a "gas...electric" mode.
Thanks, Astro. That was really cool.
kach22i said:
I like pages 11 and 34 very much.
Page 34: Electric Jet Engine...where does the juice come from?
It looks like it means driving the compressor (and fan) electrically, presumably from power taken from the main engine shaft.
I suppose this must be more efficient/simpler somehow but I don't see it!
Does the word "GENERATOR" on page 34 answer your question?
The total power output of a large 4-engine a/c at takeoff is about 200 MW. Running an aircraft aircon system isn't a big deal, by comparison.
No, the fan and compressor are still mechanically driven.
The big saving is getting rid of all the mechanical drives for fuel and oil pumps etc. The basic problem there is that the main shafts of the machine are concentric and buried in the middle of all the working parts so taking a mechanical drive off them to run pumps, gearboxes, electrical generators, etc on the outside of the engine is messy.
The lubrication system has the same basic design problem - there's no easy way of getting oil to and from the bearings. The REALLY big prize would be to have no oil system at all - in principle, magnetic bearings don't need lubrication, period.
Ok - I thought it was the next step beyond a three shaft engine was to drive, say the compressor electrically so it's speed can be more quickly and precisely controlled.
ps. Are the generators/pumps etc driven by a right angle side shaft coming out of the central shaft? I can see how that would be fun to install/maintain.
Could you make a generator by fitting magnets/coils to the outer edge of the fans and put fixed coils around the outside, turn the whole engine into a large squirrel cage motor?
You got it. As well as being "fun", accessory failures are a significant cause of engine shutdowns, so zapping them would be very good for reliability.
EEK! The tips of the fan blades have a radial acceleration of something like 9,000g. Putting extra weights on them is probably not a good idea! (Check for yourself - r.omega^2 where r = 50 inches and omega = 3,000 RPM)
Also, you wouldn't want to increase the overall diameter of the intake. The size is limited by ground clearance, for under-wing engines. The engines make excellent vacuum cleaners for keeping airport runways spotlessly clean already - that functionality doesn't need to be improved.
That's only about the same as steam turbines in a power plant - and they are much bigger.
I thought their main use was as buffers for careless luggage cart drivers and to keep the airports free of birds!
I did see a RR Trent being fitted as a backup power generator, basically the only modification was to bolt it down REALLY securely.
And also much heavier!
There is no right angle driveshaft to a remote power source shown.
I could be wrong but what I think I see on page 34 is combustion ignition in the second stage which in turn drives turbines (no compressor ahead of it).
The generator in the tail cone drives aircraft systems by feeding off the compressor shaft.
The electric motor driving the big inlet fan gets it's juice from where?
Page 38 for the blended wing concept seems to have a "gas generator" in the tail section. I'm not sure if I'd call this turbo-fan or turbo-prop, the prop actualy being a ducted fan in this case.
What do you call a gas turbine driven helicopter?
Correct. The point is to get rid of the angle drive shaft that is in most existing gas turbine designs.
Yes, you could be wrong - in fact you are wrong.
I already posted that the fan isn't driven by an electric motor! And I ought to know, I haven't looked at all the slides but I wouldn't be surprised to find that I drew some of them.
Q1: The electric motor connected to the first large inlet fan is actually an electric generator drawing power from the shaft which is turning via the combustion of gases passing through the compressor blades?
Q2: What is the "electric" motor providing power to?
Q3: Generators (not motors) convert mechanical motion into electricity, right?
Statement-1: I thought motors drove things!
The mechanical energy from the turbine drives the compressor/fan and generator. The fan and the exhaust of the turbine provide thrust for forward motion.
Lights, avionics, basically anything electrical or electronic on the aircraft.
Right.
Motors convert electrical energy into mechanical energy, which is the reverse of a generator.
Astronuc said:
The mechanical energy from the turbine drives the compressor/fan and generator...Motors convert electrical energy into mechanical energy, which is the reverse of a generator.
Should the first electric motor be labeled a generator then?
If both motors are acting as generators, why two?
A three shaft engine. We ran one a few years back. Too bad the project got canceled.
Aleph, your new swept fan design is pretty incredible compared to ours. I thought ours were getting a bit radical, but that mid span "bump" in there is quite large. Very cool.
It's "interesting" to see the slide on the tiled wall combustor. :wink:
From another forum I posted this same topic in...Carnuts.US
El.Lobo said:
"Internal active magnetic bearings and motor/generators replace conventional bearings, oil system and gearboxes ...I'm assuming this is for things like starting the engine and perhaps even as a safety measure to keep rpms under that red-line.
So that first motor may act as:
1. Electric transmission (gear reduction unit).
2. Starter motor
3. Generator (like regenerative braking the shaft).
4. RPM regulator
The second unit in the tail cone is just a parasite, converting rotational motion into current.
I believe the purpose of motor/generator sets in forward section has strictly to do with 'active bearings', but I'll defer to AlephZero and FredGarvin on that.
The generator in the aft section provides necessary power, I believe, so it's not exactly parasitic - it provides a necessary function.
For starting, aircraft use external power supplies or on-board auxilliary power systems, i.e. small turbine-generators, usually located in the tail section.
I could take a guess, but we do not have an engine that incorporates those technologies yet, so I leave that to AlephZero.
Astronuc is right. You can think of an active magnetic bearing as a sort of motor. You use electrical power to keep the rotating shaft centralized inside a ring of magnets. But the "motor" does not provide any power to rotate the shaft.
There would be other electric motors to drive engine accessories like the fuel and oil pumps. These are driven mechanically in current engine designs. (Even though magnetic bearings greatly reduce the lubrication requirements, I think it will be a little while before anybody builds a completely "oil-free" engine!)
Also aircraft cabin air would come from an independent electrically powered system, rather than being tapped off from the engine compressors as at present.
The red block at the right of slide 34 is the generator (driven by the engine fanshaft) to power all these devices.
There is no way you would even think about driving the engine fan electrically. The idea of replacing a simple steel shaft with a 50MW electrical generator connected to a 50MW motor is ... well, let's say it's not engineering.
Yeah, we have those as well!
In one of our training/conference facilities there's a little historical museum. Once of the nice exhibits is a complete WWII Merlin piston engine (V-12 arragement, max power about 1MW) next to one of those fan blades (max power per blade about 2MW). Well, that's progress.
Just to point out the date on that presentation is 2000, so it's not giving away any recent secrets. And there are a couple more Trent engines in the family now, the 900 (Airbus A380) and 1000 (Boeing 787).
FAQ: Rolls Royce Trent Engine Technology
What is the Rolls Royce Trent engine and what makes it unique?
The Rolls Royce Trent engine is a series of high-performance aircraft engines developed by Rolls Royce Holdings. It is unique because it uses a three-shaft configuration, which allows for more efficient fuel consumption and lower emissions compared to traditional two-shaft engines.
How does the Trent engine achieve its high levels of efficiency?
The Trent engine incorporates advanced technologies such as hollow titanium fan blades, ceramic matrix composite materials, and a high-pressure turbine blade cooling system. These features allow for a lighter and more efficient engine, resulting in improved fuel efficiency and reduced carbon emissions.
What is the lifespan of a Rolls Royce Trent engine?
The Rolls Royce Trent engine has a lifespan of approximately 30 years, with regular maintenance and overhaul. However, the engine's lifespan can vary depending on factors such as usage, maintenance, and operating conditions.
How does the Trent engine contribute to reducing environmental impact?
The Trent engine's advanced design and technologies significantly reduce fuel consumption and emissions, making it one of the most environmentally friendly aircraft engines in the world. It also has the capability to use sustainable aviation fuels, further reducing its carbon footprint.
What new developments can we expect to see in the future for Rolls Royce Trent engine technology?
Rolls Royce is continuously investing in research and development to improve the Trent engine's performance and efficiency. Some developments to look out for in the future include more advanced materials, new cooling technologies, and hybrid-electric propulsion systems.
