Can Uniform Relative Motion Turn a Wormhole into a Time Tunnel?
In summary: However, if there is a similar wormhole, of equal or greater length in a different frame, then at a certain relative velocity a closed time loop does form. This is called a "Roman ring".
plasmon
36
Consider a wormhole. Suppose its two mouths have no relative motion with each other.
Therefore no time difference exists across its ends. It provides a mean to travel faster
than "light in normal space". Imagine this wormhole to be at rest in frame "S"
(say). If there is another frame "W"(say) in relative motion (much closer to the speed of
light) w.r.t. frame "S". An observer in frame "W" will view the wormhole (rest in frame "S")
as a time tunnel. Therefore accelerating another end of wormhole is not the only way to
convert a wormhole to a time tunnel. Uniform Relative motion is just enough to create
such a scenario.
It depends on what you mean by time travel. Usually people mean closed timelike curves exist, and this won't happen in your example. If there are no closed timelike curves in S, there will be no closed timelike curves in S'.
each other. Therefore no time difference exists across its ends. It provides a
mean to travel faster than "light in normal space". Imagine this wormhole to be
at rest in frame "S"(say). If there is another frame "W"(say) in relative motion
(much closer to the speed of light) w.r.t. frame "S". An observer in frame "W"
will view the wormhole (rest in frame "S") as a time tunnel. If there is a similar
wormhole, of equal or greater length in frame "W", then at a certain relative
According to Matt Visser, a Roman ring is a configuration of *several* wormholes such that the whole configuration is a time machine, but such that no pair of mouths for a single wormhole is a time machine.
As in your example, in all frames, there is a spacelike identification between mouths of each individual wormhole, so each individual wormhole is not a time machine. In order for a single wormhole to be a time machine, the identification between mouths has to be timelike. See the second link I give in post #3 of this thread.
Roman ring
So the configuration outlined above does form a time machine. i.e. Whenever
two wormholes of equal length are in uniform relative motion (close to speed
of light)and are sufficiently close to each other, such a configuration will form
a closed time loop. A signal starting from any mouth of wormhole can easily
loop back to a time long before it was sent.
Yes, it's possible two create a time machine with two wormholes that all have mouths moving inertially, but in your previous two posts you said explicitly that it could be done with only one wormhole that had mouths moving inertially.
You are correct, only the configuration consisting of two wormholes having uniform relative motion with each other and sufficiently close, can form a time machine. This example clearly shows how much problematic is the idea of wormholes with relationship to causality.
How does one deal with the paradoxes associated with time travel? Matt Visser has written interesting stuff about this. He talks about four possibilies:
1. Radically rerwite physics from the ground up;
2. Permit time travel, but also invoke consistency constraints;
3. Quantum physics intervenes to prevent time travel;
4. the Boring Physics Conjecture, where we assume (until forced not) that our particular universe is globally hyperbolic, and thus doesn't have closed timelike curves.
In the past 4. was often assumed, but since global hyperbolicity is a very strong global condition and Einstein's equations are (local) differential equations, many physicists have moved to 2. and 3. Stephen Hawking likes 3., for example, and has formulated the Chronology Protection Conjecture, "It seems that there is a Chronology Protection Agency which prevents the appearance of closed timelike curves and so makes the universe safe for historians."
This roughly states that near a chronology horizon (horizon at which spacetime becomes causally ill-behaved), expectation values of stress-energy tensors for quantum fields blow up, thus preventing (by wall-of-fire barriers) physical objects from crossing chronology horizons. There seems to be some semi-classical evidence for this conjecture, but a more refined analysis by Kay, Radzikowski, and Wald muddies the picture a bit. Their analysis shows that the semi-classical stress-energy tensor is ill-defined, but not necessarily infinite, at a chronology horizon.
This may be just an indication that the semi-classical theory breaks down at chronology horizons, and that full quantum gravity is needed for definitive predictions.
Isn't it enough to assume that suitable energy condition holds?
is mathematical equation always correct
It appears to be difficult to do this, though.
From http://www.mcs.vuw.ac.nz/~visser/research.shtml (this may be slightly outdated as the webpage warns)
visser said:
In the interface region between quantum field theory and general relativity I (ed: Visser, not me!) have been heavily involved in trying to get a deeper understanding of the energy conditions and the extent to which they should be trusted. (Not only do one-loop quantum effects violate all the energy conditions, but even certain quite seemingly sensible looking classical systems violate all the energy conditions.) The implications are potentially disturbing.
The usual example of the problem of believing that the energy conditions always hold is the Casimir effect. Other examples include the space-time outside but near the event horizon of a black hole. If it didn't have negative energy density, hawking radiation would be impossible. We don't have any experimental confirmation of Hawking radiation, of course, but we do have experimental confirmation of the Casimir force.
I'm not sure what Visser means by "sensible looking classsical systems" violating the energy condition, though.
As far as I know, any traversable wormhole violates at least one of the energy conditions.
He means classical scalar fields.
According to Barcelo and Visser's Twilight for the energy conditions?, the trace energy condition is forgotten, the null, weak, and dominant energy conditions are all moribund, and the strong energy condition is dead.
I believe (3) may hold in the end. i.e. A correct theory of Quantum Gravity may prevent a wormhole to become traversable in the first place. If there is no travel possible through wormhole, no space like intervals appear in any frame of reference thus effectively excluding the possibility of closed time like curves.
Ok, I'm not able to contribute much. I have read that negative energy in all known forms seems to be unable to produce time travel possibilities. My guess is that this will hold in a TOE, too. Some cool equation will appear there to prove it.
FAQ: Can Uniform Relative Motion Turn a Wormhole into a Time Tunnel?
What is a wormhole and how does it work?
A wormhole is a hypothetical tunnel-like structure that connects two distant points in space-time. It is a shortcut through space-time, allowing for near-instantaneous travel between two points that would otherwise be separated by vast distances. The concept of wormholes is based on Einstein's theory of general relativity, which suggests that space and time can be bent and warped by massive objects like stars and black holes.
Can humans travel through a wormhole?
Currently, there is no scientific evidence to suggest that wormholes exist, much less that they are safe for human travel. The extreme forces and conditions required to create and stabilize a wormhole would make it extremely dangerous for any human to attempt to travel through one. However, scientists continue to explore the possibilities and potential challenges of wormhole travel.
How does relative motion affect a wormhole?
Relative motion refers to the movement of an object in relation to another object. In the case of a wormhole, the relative motion of the two points that are connected by the tunnel would determine the distance and time required to travel between them. The closer the two points are in relative motion, the quicker and easier it would be to travel through the wormhole.
What is the difference between a wormhole and a black hole?
While both involve intense gravitational forces and distortions of space-time, a wormhole and a black hole are two different phenomena. A black hole is a region of space where the gravitational pull is so strong that nothing, including light, can escape it. A wormhole, on the other hand, is a hypothetical tunnel that connects two distant points in space-time and may allow for travel between them.
Are there any real-life examples of wormholes?
There are currently no confirmed examples of wormholes in the universe. However, scientists have discovered potential candidates, such as the supermassive black hole at the center of our galaxy, that could potentially create and sustain a wormhole. Further research and technological advancements may one day lead to the discovery and exploration of a real-life wormhole.
